Spade/Trencher for M59
   / Spade/Trencher for M59 #1
caballero59
Buena Vista, CO
Kubota L39, M59, ZD326, Deere 6415
I'm needing to dig a shallow ditch for electrical and don't want to use the 24" bucket. Does anyone know of a company that makes a ripper/ditcher/spade attachment that replaces the bucket? It appears that Bro-Tek is only building wheel spacers now...
   / Spade/Trencher for M59 #2
How deep and wide? Maybe make something with angle iron to attach to the backhoe bucket...
Just wide enough so the dipper stick clears the trench.
   / Spade/Trencher for M59 #4
Ok that's wider then I was thinking....
   / Spade/Trencher for M59 #5
are you putting in conduit or direct burial wire and what size?
I'll put it in conduit. I see some rippers available but none that I've found for the M59. Great tractor by the way.
   / Spade/Trencher for M59 #7
Be interested in what you come up with.
Need a ripper for both the m59 and b26. Bought the qa ears for b26 for fabrication. Mainly for roots and rocks. BroTek design had a flatbar on the back of the ripper that helped open the ripper trench if I recall correctly. An option I like.
Have laid some direct burial cable with a subsoiler and J-tube. Thinking something like that. Rip the ground first, attach the J-tube and lay cable or pipe. Still on the drawing board.
Have/had 12” buckets on the Ford 4500 and b26. Still a lot of spoil to deal with and clay soils with head size rocks like to pack narrow buckets.
There is company that fabricates rippers for $1200 for backhoes I see advertising in CL. My m59 bucket is pin on. I think the bucket yoke and change to qa ears to get quick attach. The qa on the b26 is the best I have ever seen.
If not going deep maybe something that attaches to your bucket?
   / Spade/Trencher for M59 #8
I never did understand what a ripper tooth could do that a narrow bucket couldn't do better, but there must be some reason they are sought after...
A friend built a ripper for his M59 and was surprised to find out how much $$ he had into it when done. Here's a photo of one of the QA ears he ordered from Kubota for the project.
Nice build! The primary (and weighty) reason to steer away from a narrow bucket is the difficulty of unloading them in sticky soil.
   / Spade/Trencher for M59 #10
Mobile Transformer and Power Substation Portable Power Supply (A55302)
Mobile Transformer...
183 (A52705)
183 (A52705)
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
2018 John Deere 2025R Tractor - 647 Hours (A56435)
2018 John Deere...
