Spade/Trencher for M59
   / Spade/Trencher for M59 #11
   / Spade/Trencher for M59 #12
Those ears do not look at all like the ones on my L48.
I love the ones I have.
Same as mini ex I think.
My M59 buckets are different from my KX-040. BTW practically every different class mini takes a different bucket.
   / Spade/Trencher for M59 #13
I'm needing to dig a shallow ditch for electrical and don't want to use the 24" bucket. Does anyone know of a company that makes a ripper/ditcher/spade attachment that replaces the bucket? It appears that Bro-Tek is only building wheel spacers now...
   / Spade/Trencher for M59 #14
I bought a ripper/trencher for my L45 from Michigan iron and equipment. I use it for ripping out big stumps and trenching for conduit. Its works great for both. With a bit of practice, its amazing how fast you can trench for conduit.
   / Spade/Trencher for M59 #15
How deep can you bury pipe with a ripper?
   / Spade/Trencher for M59 #16
I would estimate I could bury small conduit about 14" or so pretty efficiently. Much deeper than that and I would spend too much time cleaning the bottom of the ditch out with the back side of the ripper.
What do the good forum folks think about a 12" bucket as a substitute? Do they only unload in perfect soil conditions?
   / Spade/Trencher for M59 #18
Even if only half unloads, it’s better than a shovel.
Digging trenches so much easier than around stumps.
Had so much play with 4500 Ford BH it could really shake the dirt out of the 12” bucket.
Often thought of a bucket clean out stand or tool designed to drag around to clean a bucket from the operator station.
Reverse thumb to expel bucket material instead of clamping.
Seen a few attempts to mount a trencher on a backhoe or excavator. Seen a few worn trenchers come through the scrapyard that could be donor candidates.
Vibratory plow to cut and pack the sides of a trench.
Two large disk blades mounted concave to roll a trench.
Many possibilities to ponder.
The half mile of 13.8kVA line to my house was suppose to be 4’ deep in conduit. Mostly with trencher and mini-ex at the junction boxes.
   / Spade/Trencher for M59 #19
I have a 12” on my mini x. In perfect conditions it unloads but it definitely sticks worse than the 16” on my other machine.
2013 Ford F-250 Super Duty Service Truck, VIN: 1FT7X2BT7DEB91437, Extended Cab, 4x4, 6.7 L Power (A59076)
2013 Ford F-250...
2011 John Deere 5085 70HP Utility Tractor (A55973)
2011 John Deere...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
SKID STEER GRAPPLE BUCKET (A58214)
SKID STEER GRAPPLE...
2019 GENIE S-45XC TELESCOPIC BOOM LIFT (A52709)
2019 GENIE S-45XC...
2013 JCB 3CX Extendahoe Loader Backhoe (A55973)
2013 JCB 3CX...
