4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 19,214
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
I would absolutely recommend a concrete tank over the plastic type.
In some areas you can buy a concrete tank with a "Heavy top".
This is a good idea, if the tank is somewhere in your yard where you might occasionally drive a CUT or a car over it.
In a normal drive over area, you need a HEAVY tank, for delivery type trucks.
Plus they’re cheaper at least here and they stay in the ground better. A plastic one needs to be 100 percent full to not float out. The only advantage of a plastic one is they can be set with small equipment when it’s not possible to get the crane trucks into place. Also a plastic one isn’t approved for a pump tank. That might not be code everywhere but the same problem applies everywhere.
