Anyone here install their own septic
/ Anyone here install their own septic #61
I did my septic system about 2 years ago. Called around and got prices first, ranging from $8500 down to the lowest at $6500. Called the state environmental dept and found that for $100, you can take a simple test and get a permit. That $100 also includes 3 on site inspections. My total costs for 1000 gal tank, all the pipe, and all the stone was $1800. Our soil is sandy loam, not a rock to be had.... for a 3 BR house, only needed 200' of laterals 4' deep x 2' wide.
The specs will vary greatly from region to region, state to state, and even county to county. It was a no-brainer for me... just due to the cost savings...
if you can do it...go for it. The guys i know that do this work have dump trucks, trailers, excavators, insurance, etc to pay for. plus laborers, gravel delivery and usually less than good working environments....especially when having to repair failed systems.
personally, the guy i work with knows not to bother calling me for old systems. i wont work on any old, failing systems. not enough money in the world.
/ Anyone here install their own septic #62
Many years ago, my sister worked for a septic installer and she had some real nasty stories too. :yuck:
/ Anyone here install their own septic #63
I would seriously think about having a system designed by an approved engineer. It shouldn't be too expensive and they know what to watch out for. When I installed my septic the guy came and made a map of my property with the locations of any wells and other features that could be impacted. That included a surface well my neighbor has. After I did the work of installing it my neighbor had a question about if his well was downstream. A simple call to the engineer was all it took. Had I done it on my own hen I would have been on the hook for trying to prove it was correct. Plus with an engineer you get a print of exactly what to do.
/ Anyone here install their own septic #65
My guy charged $ 800 bucks, that included the well, perk test (I dug the holes), drawing out the septic system, filling out the permits, and inspections. Money well spent...
/ Anyone here install their own septic #66
Your $800 fee would be at least $5,000 short in the Northeast!
/ Anyone here install their own septic #67
Here the the county perk test the lot ( for a fee of course ) and draws the system to the specs they think necessary. I’ve never heard of anyone paying an engineer to design one and I doubt the county inspector would approve it even if they did.
/ Anyone here install their own septic #68
That's exactly how it was done here. God knows what they do in the next county over... :confused3:
/ Anyone here install their own septic #70
We have to have a site plan drawn up by a soil scientist, then get the town CEO (Code Enforcement Officer) approve it. All for a fee, of course. Permits are then filed with the state, and put into a database so that you can tell 30 years later if a septic was legally installed. Yes, it's bureaucracy at work but if you're buying a home at least you can tell whether the system is functional in the long term, or just a pipe dumping into a tank made of hemlock with an overflow out the other end. And I've seen the latter...
/ Anyone here install their own septic #71
An engineer designed/stamped plan is required in many parts of the USA.
/ Anyone here install their own septic #72
Talk about engineers, perk tests and fees etc, the latest is getting certificate of conformity from the city in order to get a mortgage.
Just another fee to add to the stack.
/ Anyone here install their own septic #73
CT is pretty strict too. Need to replace the septic at my father-in-law's house. $3,600 for soil tests, contour survey and mapping, engineered plan and permits. Then $29,000 for digging, sand, tanks, pipe, back-filling, grading and replanting grass. Has to be done by a licensed installer. The installer is a friend, so he may let us so most of the earth work with our backhoe to lower the cost.
/ Anyone here install their own septic #74
I think that is a good idea.
My farmhouse had no records of installation nor location.
/ Anyone here install their own septic #75
If your system functions with gravity, there is NO NEED for a pump!
That's kinda what I thought.
What will be will be. I hired the guy with the best rep. in the area. I'm sure I'm not the first to do this and i really have no other choice.
/ Anyone here install their own septic #76
A lakeside property just sold via public auction,
Very worrisome as the house is on a point of land, on solid bedrock, and septic is hand dug pit 5-6 ft from shore and sports an overflow to lake feature.
While in a very dilapidated state it has 2 loo's of the high volume flush generation.
This has been abandoned for 25 years and hopefully the city will closely monitor the situation.
However if no complaints the city rarely takes any action so it is up to a neighbor to start the ball rolling and unfortunately few ever do so.
/ Anyone here install their own septic #77
Around here that home would have to have a holding tank type septic and have it pumped every few months.
/ Anyone here install their own septic #78
I live on a city owned lake. All systems installed since 1982 have to be 300 feet from the water. All systems must be inspected and pumped every 3 years and paper work turn into the city by the company that pumped it. This is for anything within 1 mile of the lake. If there is a house it will be inspected.
/ Anyone here install their own septic #79
Yep, that's what we have here also.
Residential 2 year pumping and 4 yrs for seasonal.
Inspection is basically left to the licensed pumpers.
As an association we go for group rates and have been successful so far with $160./event for last 6 years.
/ Anyone here install their own septic #80
Our rate is from $300 to $375
2004 John Deere 8320 (A63688)
2004 John Deere...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2019 John Deere M15 Batwing Mower (A66285)
2019 John Deere...
