Still trying to pick a quick hitch
/ Still trying to pick a quick hitch #1
Engine Mike
Member
Rochester hills michigan
Kubota B2320
It appears that Pat痴 quick hitch is the best choice for me. After looking at the Harbor Freight quick hitch I think it will take too much modification to work on my snowblower and carryall. Pat痴 will work for my snowblower right out of the box. I am concerned that there is not enough clearance between the lower arm pin and the carryall box to connect Pat痴 properly. Does anyone know how much clearance is required? I have scoured the internet and cannot find this spec. If it is too tight can you simply carve out the box to create clearance? Anyone痴 thoughts are appreciated!
/ Still trying to pick a quick hitch #3
Having Pat's on the three point arms is mostly like connecting the pins of the implement into the three point arms directly. They just extend the arms a couple of inches longer. I did need to get a longer top link to compensate for the added length of the arms. The length will also reduce your specified lift capacity a bit.
/ Still trying to pick a quick hitch #4
I have the Pat's and agree with Roadworthy. I also needed to get a PTO extender. Very pleased with the Pat's and have been using it for a number of years with no issues.
/ Still trying to pick a quick hitch #5
As for a "Quick Hitch" (not Pats Easy Change) there is probable 25 to chose from, biggest issue is top hook is probable not extended enough to clear upper part of implement, you will need to get extended hook or adapter to fit implement....
Dale
/ Still trying to pick a quick hitch #6
There was a comparison of quick hitches that pointed out the Speeco hitch doesn't require bushings. If you have several attachents that could be a factor.
Doug in SW IA
/ Still trying to pick a quick hitch #7
Dale
if extended top hook needed 'google' 873-HF141137
TOP HOOK FOR CAT 1 QUICK HITCH | Quality Farm Supply
Land Pride also makes a non-standard (no bushings) QH
/ Still trying to pick a quick hitch #9
I thought about getting a quick hitch for the Toolcat but the 3pt attachments are on dollies, so easy to position for hook up. And the counterweight stays on most of the time, so I decided I didn't need the quick hitch.
Landhonor Quick Attach Hydraulic Forks (A66285)
Landhonor Quick...
SKID STEER AUGER ATTACHMENT (A62613)
SKID STEER AUGER...
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
John Deere Lift Arms (A65640)
John Deere Lift...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
