Loader Parked Above Other Equipment
/ Loader Parked Above Other Equipment #1
downslope
NY
MF TO-35, Ford(s) 2000, 8N, 9N, White 2-70, NH TD75D, JD 5045D
I have a New Holland 820 TL loader installed on 75 hp NH tractor.
I need to park the tractor indoors with the loader raised above another tractor. I've been doing this for 10 winters with no problems but as the equipment is aging (hoses, cylinders, etc.) I'm getting a little nervous about it possibly creeping or crashing down and causing damage to my classic.
There's been no indication of it doing this yet. I have a 14 foot ceiling and can raise almost full height. I will be able to check daily.
Any suggestions on how I can rig some kind of safety support so as to prevent a catastrophe, or would this even be necessary?
/ Loader Parked Above Other Equipment #2
A piece of angle iron cut to length to lay on the lift cylinder ram one of the oldest tried an true methods out there.
/ Loader Parked Above Other Equipment #3
That is a very commonly used, and effective loader safety solution.
/ Loader Parked Above Other Equipment #4
I wish I had a picture of this. There wouldn’t need to be so many words .
When I have a load of split firewood on my trailer and do not have the time or energy to unload and stack it right away, I back it into my woodshed that doubles as my tractor shed. With the trailer there the tractor won’t fit unless I raise the loader up above the trailer box. If the loader fell overnight it wouldn’t hurt the wood, but parts of the frame would damage the trailer jack and hitch.
I’ve got a 8’ length of 4 x 4 bolted to a piece of 2 x 10 about 3’ long that I use as a jack stand under one of the loader arms. I place the T with the 2 x 10 on the floor and gently bleed the loader down so the weight is on the stand and not the hydraulics.
Good luck.
Frank
/ Loader Parked Above Other Equipment #5
Just be sure it is heavy wall. I folded a this wall piece like it was warm butter.
I rebuilt a Case 530CK engine in the chassis a ways back and used a 4X4 post to hold the loader up.
/ Loader Parked Above Other Equipment #6
A wood post is just not practical, if you need clear space under the loader.
/ Loader Parked Above Other Equipment #8
A piece of angle iron over the cylinder is the easiest method. My M59 has a built in safety stand. The downside is it only goes in at almost full height.
/ Loader Parked Above Other Equipment #9
Cut a narrow side off a section of rectangular tubing. Drill a pin hole or two so it can't be bumped off.
Bruce
Bruce
I have some lengths of 4" and 3" well pipe lying around. I was thinking the same thing, maybe cut a slot in it wide enough to fit over cylinder pistons.
Could these solutions with the angle iron or tubing/pipe possibly damage the cylinder seals if they press on them unevenly? The rectangular tube you show in the picture looks nice because it seems to have a flange at each end.
/ Loader Parked Above Other Equipment #11
You don't want it to press on the seal. Only on the gland nut that's why there is a flat plate welded on the tube...
/ Loader Parked Above Other Equipment #13
Here's what I made for my Kubota BX2230. The curved end is a shaft collar that I cut up who's ID was the same of the OD of the cylinder's pin boss, and slotted a 1" flat washer for the other end. Didn't have round tube, so I cut one side out of some 1 1/2" square 11ga tube I had.
/ Loader Parked Above Other Equipment #14
Here is my version made out of some salvaged aluminum 2x4's.
Raise loader, apply safety block, turn off engine, slowly lower the loader boom.
I had already bought a pair of shaft collars like my friend BravoXray above when I found the aluminum and then I changed directions.
I used a 2" hole saw in the Bridgeport mill to make the semicircular cutouts to fit around the rod end trunnion and cut the opening lengthwise on the table saw...yes, you can cut aluminum on a table saw with a triple chip grind tooth pattern blade.
2018 Dodge Charger Sedan (A66738)
2018 Dodge Charger...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
2000 Hino (A64194)
2000 Hino (A64194)
2014 MAGNUM FRAC MANIFOLD TRAILER (A67714)
2014 MAGNUM FRAC...
2025 JMR Tree Boom Mini Skid Steer Attachment (A66734)
2025 JMR Tree Boom...
2000 STERLING LT8500 SERIES WATER TRUCK (INOPERABLE) (A67714)
2000 STERLING...
