Loader Parked Above Other Equipment
   / Loader Parked Above Other Equipment #11
You don't want it to press on the seal. Only on the gland nut that's why there is a flat plate welded on the tube...
   / Loader Parked Above Other Equipment #13
Here's what I made for my Kubota BX2230. The curved end is a shaft collar that I cut up who's ID was the same of the OD of the cylinder's pin boss, and slotted a 1" flat washer for the other end. Didn't have round tube, so I cut one side out of some 1 1/2" square 11ga tube I had.
   / Loader Parked Above Other Equipment #14
Here is my version made out of some salvaged aluminum 2x4's.
Raise loader, apply safety block, turn off engine, slowly lower the loader boom.
I had already bought a pair of shaft collars like my friend BravoXray above when I found the aluminum and then I changed directions.
I used a 2" hole saw in the Bridgeport mill to make the semicircular cutouts to fit around the rod end trunnion and cut the opening lengthwise on the table saw...yes, you can cut aluminum on a table saw with a triple chip grind tooth pattern blade.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A58375)
KNOW BEFORE YOU...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
2006 Toyota 7FGU60 11,250lb Propane Forklift (A55973)
2006 Toyota 7FGU60...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
