Loader Parked Above Other Equipment
   / Loader Parked Above Other Equipment #1
downslope
Platinum Member
NY
MF TO-35, Ford(s) 2000, 8N, 9N, White 2-70, NH TD75D, JD 5045D
I have a New Holland 820 TL loader installed on 75 hp NH tractor.
I need to park the tractor indoors with the loader raised above another tractor. I've been doing this for 10 winters with no problems but as the equipment is aging (hoses, cylinders, etc.) I'm getting a little nervous about it possibly creeping or crashing down and causing damage to my classic.
There's been no indication of it doing this yet. I have a 14 foot ceiling and can raise almost full height. I will be able to check daily.
Any suggestions on how I can rig some kind of safety support so as to prevent a catastrophe, or would this even be necessary?
   / Loader Parked Above Other Equipment #2
A piece of angle iron cut to length to lay on the lift cylinder ram one of the oldest tried an true methods out there.
   / Loader Parked Above Other Equipment #3
That is a very commonly used, and effective loader safety solution.
   / Loader Parked Above Other Equipment #4
I wish I had a picture of this. There wouldn’t need to be so many words .
When I have a load of split firewood on my trailer and do not have the time or energy to unload and stack it right away, I back it into my woodshed that doubles as my tractor shed. With the trailer there the tractor won’t fit unless I raise the loader up above the trailer box. If the loader fell overnight it wouldn’t hurt the wood, but parts of the frame would damage the trailer jack and hitch.
I’ve got a 8’ length of 4 x 4 bolted to a piece of 2 x 10 about 3’ long that I use as a jack stand under one of the loader arms. I place the T with the 2 x 10 on the floor and gently bleed the loader down so the weight is on the stand and not the hydraulics.
Good luck.
Frank
   / Loader Parked Above Other Equipment #5
Just be sure it is heavy wall. I folded a this wall piece like it was warm butter.
I rebuilt a Case 530CK engine in the chassis a ways back and used a 4X4 post to hold the loader up.
   / Loader Parked Above Other Equipment #6
A wood post is just not practical, if you need clear space under the loader.
   / Loader Parked Above Other Equipment #8
A piece of angle iron over the cylinder is the easiest method. My M59 has a built in safety stand. The downside is it only goes in at almost full height.
   / Loader Parked Above Other Equipment #9
Cut a narrow side off a section of rectangular tubing. Drill a pin hole or two so it can't be bumped off.
Bruce
Bruce
I have some lengths of 4" and 3" well pipe lying around. I was thinking the same thing, maybe cut a slot in it wide enough to fit over cylinder pistons.
Could these solutions with the angle iron or tubing/pipe possibly damage the cylinder seals if they press on them unevenly? The rectangular tube you show in the picture looks nice because it seems to have a flange at each end.
2024 Icon I40L Electric Cart (A50324)
2024 Icon I40L...
Electric Mobility Scooter (A51694)
Electric Mobility...
2013 INTERNATIONAL MA025 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
2021 VOLVO A40G (A52472)
2021 VOLVO A40G...
TAKEUCHI TL6R SKID STEER (A51246)
TAKEUCHI TL6R SKID...
Toro Workman Utility Cart (A51694)
Toro Workman...
