Generator Selection?
/ Generator Selection? #201
Being in the midst of some severe smoke at the moment, I can say that unless the flames are on your generator, it won't be an issue. Our AQI is 220+ at the moment, and the CO monitor is still zero.
All the best,
Peter
Good to know as some generators were right at the fireline powering pumps...
Potential ship date now of Thursday the 8th for the transfer switch. If it happens, I should have it next Tuesday or so.
/ Generator Selection? #203
Good job for Wifey. Just tell her not to touch anything. lol
Isn't running a PTO set unattended like running ones tractor, taping over the gauges, not being able to detect smoke and no being able to hear what's going on? I kind of think so. I did have the hydraulics quit for no reason on another tractor running this same generator. Sheit happens.
I cant bring myself to run a tractor unattended let alone a PTO generator. It would rob me the benefits of having one here in Maine. Besides most of the storms where I lose power I need the tractor anyway for clearing snow.
/ Generator Selection? #204
Come to think of it, I don't really like running my 15" PTO chipper with the tractor. Much of the time, the tractor screaming away, doing nothing as you fetch another log. I know, any Diesel chipper would be the same, but somehow this seems different.
/ Generator Selection? #205
and if you were running HEPA air purifiers in your home like many do, good that they keep running too...
/ Generator Selection? #206
Unless you have a cheap diesel running your tractor, it is different! Your tractor engine is probably much pricier than the diesel engine in the chipper. So an engine hour on the tractor probably costs more.
That said, I run my chipper with my tractor, mainly because a chipper of equivalent performance costs more than my tractor. YMMV... I did look into repowering it with a leftover diesel from somewhere, but I wasn't able to find a cheap engine.
All the best,
Peter
/ Generator Selection? #207
Peter
Why would I worry about that? According to the guys on TBN, these tractors will run 15,000 hours with only oil changes, is your power going to be off THAT much? Will you live long enough to wear one out??
SR
/ Generator Selection? #208
I feel like it's a no win situation. Buy a chipper with a fairly worn diesel and possible have trouble and expense, or use my low hours John Deere for a PTO chipper. I'm a little worried about the DEERE PTO clutch. It takes a lot to get the 1000# cutter wheel turning, The clutch on the chipper is just screaming! The chipper is geared up in speed with belts. You don't really want to start and stop it more than you have to.
/ Generator Selection? #209
Well I see the National Weather Service has issued a high wind warning for my area so I guess tomorrow I'll get one of the tractors unhooked and ready to go on the generator if needed, and if needed I'll sleep just fine with it running unattended.
/ Generator Selection? #210
My biggest problem with the tractor powered generators is the rain associated with a power outage. I had (about 35 years ago) a PTO generator but it could only be used outside in good weather, I now have a stationary dedicated generator for the house. (I've not checked to see if the newer ones have this limitation.)
/ Generator Selection? #211
Mine has been used in numerous rain and snow storms over the years with no issues, I do have a piece of plastic over the control and connection panel,
I have considered putting a calf hutch over the generator.
/ Generator Selection? #212
Same here, it's a non issue...
I never have figured out why folks pay the bucks to house a dedicated generator, but they always tell you about how the pto generator is in the back of the barn somewhere, next to impossible to get out and use...
There's no reason a pto generator can't be housed near your house, in an enclosed cabinet with all the wiring there, ready to be plugged in, or to just leave it plugged into a transfer switch, just like a dedicated genset...
SR
/ Generator Selection? #213
With portable generators and bad weather, check out GenTent. They build tents for generators that are supposed to stand up to just about any kind of weather. I have one on my Honda.
Overview
/ Generator Selection? #214
SR
It's not unusual to see one of these housing a generator;
Calf Hutches - Calf Hutch
/ Generator Selection? #215
SR
I know a guy that has his in a shed, fastened down near the outside wall with a hole in the wall for the PTO shaft. He must have made up a longer shaft. Pretty obvious but clever.
/ Generator Selection? #217
I've seen that myself...
SR
Called blue box store again last week and they didn't know why the transfer switch didn't ship. They called G again and got a new ship date of the 15th. It's now late on the 16th and still no ship.
I called G and got someone who was willing to call blue box store and 'get their permission' to talk to me since I'm their customer, not G's. Once done, G now tells me early next week, but can't say for sure when.
At least I'm getting people in the States when I call both places and not somebody off-shore somewhere.
/ Generator Selection? #220
You sure? I've talked to a guy in Mumbai named "Rick" :laughing:
Quick Attach Backing Plate (A65579)
Quick Attach...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
INOP Kodiak Four-Wheeler (A65579)
INOP Kodiak...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
6ft. Telehandler Forks (A65640)
6ft. Telehandler...
