Anyone have good luck using electrolysis to remove rust from wheels?
/ Anyone have good luck using electrolysis to remove rust from wheels?
I finally got the wheels primed. Took the travel trailer to PA for 9 days, and been cutting a lot of firewood. The plan is to put the finish coat on next weekend and mount the tires after we get back from NH....but we all know how plans go.
/ Anyone have good luck using electrolysis to remove rust from wheels? #62
Looks real good !
If anyone is still interested, I got the finish coat on today. How long should the paint dry before remounting the tires? I do anticipate some touchup work but would like to keep it to a minimum.
/ Anyone have good luck using electrolysis to remove rust from wheels? #64
What kind of paint did you use? Acrylic? If so and I imagine these are too big for your oven but baking them at 250degF or so for about an hour should fully cure/harden them. I use my wife's oven when she isn't looking. Be sure it is dry to the touch before baking.
I used CNH Acrylic enamel. Supposedly "chip and abrasion resistant"
/ Anyone have good luck using electrolysis to remove rust from wheels? #66
Boy if you could fit them in an oven you might get a harder and shinier finish.
I don't think they'll fit in the oven. If they did fit, I'd go with it's easier to beg forgiveness than ask permission.
/ Anyone have good luck using electrolysis to remove rust from wheels? #68
Ha ha... that's what I did. Here is a picture of four 'boots' with swivel casters I made for a steel table that I rescued and restored. They did fit in my wife's oven and she did wonder what the smell was when she came home. I had to confess.
/ Anyone have good luck using electrolysis to remove rust from wheels? #70
Nice work :thumbsup: I'm sure the outfeed table serves double duty as an assembly table.
Thank you... Yep! It serves as my 4ft by 8ft welding table, add a sheet of 1/4in plywood and it is my outfeed/assembly table for wood projects, add a panel of pink foam insulation and it is my sheet goods break down table.
61586674821__A04BAB13-9A32-4ADE-92B9-0BF96D36A50D.jpeg 61387589404__65392774-D49D-491F-992E-09B1B4461B6B.jpeg
The table was apparently stored outside and the bottom portion of the 2in square tube legs somehow had filled up with some water and must have froze causing them to bulge at the bottom. I cut the legs and made the swivel boots that allow me to drop shims to adjust height. Plan to add other features but it serves me well!
/ Anyone have good luck using electrolysis to remove rust from wheels? #71
its humbling to see that many shelves empty. wont happen around here.
/ Anyone have good luck using electrolysis to remove rust from wheels? #72
Ha ha. Those adjustable shelf units are for my wife's shoes! I'm building her a clothes closet.
/ Anyone have good luck using electrolysis to remove rust from wheels? #73
That would be a good start for Imelda :shocked:
As with several things in life. it's 1 step forward, then stumble back. I painted the center discs, ordered 2 tubes and mounted the tires. I filled the tires to 14psi, which is what the owner's manual recommends. I was going to let the tires set for a week or so before having ballast added. I check the air pressures, one tire is 14psi, one was at 0psi. My son and I break down the tire, remove the tube and discover some failures where the valve stem is bonded to the main tube. Do I replace both tubes or just the failed one. They are Air-Loc brand tubes, made in Korea, which gave me more confidence than made in China.
It's finally over!! :dance1: The pics are self explanatory. The 2 with the stump are a tad blurry, I was so excited to get some work done, I guess I was shaking a little. :laughing: Now I have to decide if I want RimGuard or wwf for ballast. I would definitely recommend the electrolysis method for removing rust. I'm thinking of doing the front wheels next year. It will be quicker because I should be able to put both wheels in the stock tank, instead of 1 rear wheel at a time.
/ Anyone have good luck using electrolysis to remove rust from wheels? #76
^^^^ Looks really good!
I came across a bunch of cast iron pots and pans I need to cook up and get the rust off of.
2014 Nissan Rogue SUV (A59231)
2014 Nissan Rogue...
2007 Ford F750 Bucket Truck (A60352)
2007 Ford F750...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
Bobcat MT85 (A60462)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
12' CONTAINER (A52706)
