downsizingnow48
Elite Member
GRK style structural screws are the best solution. Top quality, no pilot holes. I haven't used those 19th century style lag bolts for a long time.
Ouch...... Fastenal is extremely proud of their prices. I use them for quick small purchases because they are close to my shop.I don't buy hardware from Lowes and HD. Try getting what you need from Fastenal or a good fastener distributor. The quality is much better.
GRK all the way!
After using these I値l never go back to lag bolts!
No pilot holes, just impact driver and go.
Yeah you're right. I am using them on the brackets too so in reality I'm sure the four 3" screws that I could use on the brackets would support hundreds and hundreds of pounds. I guess weak shelves is a pet peeve of mine.FWIW - all my cabinets in the entire house were held on the walls with three inch Phillips head screws. That was done 39 years ago. Not a single one has fallen off any wall.
Lag bolts to attach kitchen cabinets/shelves - might be a bit of an over kill. However - pretty sure they won't fall off either.
The reality is that if they are typical cabinets, the back is nothing but 1/4" pressboard stapled to the sides (and glued, if you sprung for the high end stuff). The screws aren't ever going to be the weak link. You overload the cabinet, and the back will remain attached to the wall, but the rest of the cabinet (and contents) will be sitting on the countertop or floor. It'll just peel the back right off.
The cabinets I installed had 3/4" plywood backs. I mounted those with screws and washers.The reality is that if they are typical cabinets, the back is nothing but 1/4" pressboard stapled to the sides (and glued, if you sprung for the high end stuff). The screws aren't ever going to be the weak link. You overload the cabinet, and the back will remain attached to the wall, but the rest of the cabinet (and contents) will be sitting on the countertop or floor. It'll just peel the back right off.
So yes my lag bolt use is beyond overkill and maybe those little bolts committed suicide because they couldn't stand the thought of serving a pointless existence for the next 30 years holding up a 7lb shelf in the suburbs.
I agree that 3/4 is overkill as well as when they are nailed and glued. I think 1/2 glued and nailed would be good enough. When shopping for ready to assemble cabinets you can see a lot of different quality levels and kind of choose your paranoia level. Then go above and beyond in the installation stage.Wow. That's an interesting level of cabinet insanity. I mean the 1/4" pressboard you often see is junk but 3/4" ply is beyond overkill. 1/2" ply glued and screwed is kinda the sweet spot. But yeah, I've done it. I made some very heavy duty upper cabinets out of 3/4" to store canned goods and i think that was also the last time I used lag bolts, right before I learned about GRKs. That was like 20 yrs ago. Come to the GRK light....
I read your thread on the renovation (so far). You are far crazier than I. I thought I was nutz, but doing all that with a newborn? yowza. Looks like you've done it all before too. Nice work!
