Lag bolts that don't break?
   / Lag bolts that don't break? #21
GRK style structural screws are the best solution. Top quality, no pilot holes. I haven't used those 19th century style lag bolts for a long time.
   / Lag bolts that don't break? #22
The 19th c. type actually requires two pilot holes for proper installation. One size hole for the threaded part which has a diameter big enough to take the core. Then for the wood that is getting tightened down, a second pilot hole the diameter of the lag bolt shank. Nobody does this and it usually doesn't matter with softwood. But with hardwood it makes a big difference.
Dipping the old type in oil or soapy water will make it about 10x easier.
   / Lag bolts that don't break? #23
I go to Menards and buy Spax power lag bolts, looks like the CTX bolts, drives with torx bits. The Spider lag bolts also good - uses an 8 point torx like bit, prefer standardized stuff myself.
If screwing into cement, I like Tapcon
cement screws - Bing video
   / Lag bolts that don't break? #24
FWIW - all my cabinets in the entire house were held on the walls with three inch Phillips head screws. That was done 39 years ago. Not a single one has fallen off any wall.
Lag bolts to attach kitchen cabinets/shelves - might be a bit of an over kill. However - pretty sure they won't fall off either.
   / Lag bolts that don't break? #25
I don't buy hardware from Lowes and HD. Try getting what you need from Fastenal or a good fastener distributor. The quality is much better.
Ouch...... Fastenal is extremely proud of their prices. I use them for quick small purchases because they are close to my shop.
If I need bulk anything, then there is Star Bolts across town. They have the same products, same quality, but are half the price.
MC, pre drill the holes and soap up the threads
   / Lag bolts that don't break? #26
   / Lag bolts that don't break? #27
+1 on GRK or SPAX screws. I haven't used a regular lag in years as these are light years ahead in strength and driveability. Generally no need to predrill unless going into hardwood or something thin that might split. I've pulled plys of LVL beams together in a tight beam pocket with them and they just don't quit. No need to go to Fastenal and pay their inflated industrial prices, as all the Big Boxes have GRK and/or SPAX.
Yeah you're right. I am using them on the brackets too so in reality I'm sure the four 3" screws that I could use on the brackets would support hundreds and hundreds of pounds. I guess weak shelves is a pet peeve of mine.
So yeah the job is already done and they're all secured with lag bolts but for future jobs I'll go with those torx screws.
   / Lag bolts that don't break? #29
The reality is that if they are typical cabinets, the back is nothing but 1/4" pressboard stapled to the sides (and glued, if you sprung for the high end stuff). The screws aren't ever going to be the weak link. You overload the cabinet, and the back will remain attached to the wall, but the rest of the cabinet (and contents) will be sitting on the countertop or floor. It'll just peel the back right off.
   / Lag bolts that don't break? #30
Agreed. Even good custom cabinets built from actual plywood would fail before a reasonable amount of 3” good screws failed. I’ve never seen cabinets put up with anything besides screws. Lag bolts are way excessive. Save the lag bolts and heavy duty structural screws for a deck ledger board. The majority of people just use regular screws which won’t pass code. That and they just toenail the joist which also won’t pass code.
2014 Ford F-550 (A55973)
2014 Ford F-550...
Kubota LX2620 (A53317)
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2013 Chevrolet...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
2025 GPS Trailers (A56859)
2025 GPS Trailers...
Electric tri scooter irgc40 (A56859)
Electric tri...
