Cleaning dead snakes out of a dug well
   / Cleaning dead snakes out of a dug well #31
Wow, I've created a monster! OR is it a serpent? :D
As mentioned previously the water comes out of the ledge in 3 places, although I'm sure that surface water may get in at certain times. She has an ultraviolet sterilizer and had the water tested this spring. With an 8x12 foot concrete enclosure, a varmint proof cover is going to be a little work, but doable. The snakes most likely get up on the concrete to sun themselves, fall in and can't get out. I can pump it dry, get in there and clean it out; I just don't know how well I can clean up partially decomposed carcasses which have seeped into the crushed stone. I will have somebody around when I do so, as the last thing I need is to fall off the ladder when getting back out and have it fill back up with 10 feet of water again.
Then she would have to buy even more bleach… :laughing:
I've been pushing her to drill a well for several years now, but my parents were always frugal and what they have worked. Reality is that she won't be there many more years, and the property will likely be sold and subdivided when she's done with it.
When you are pumping the water out use the outlet of your pump to churn up the sediment then suck it out to discharge, as it refills churn it some more and using your pump suck it out repeat till clean.
As far as keeping the snakes and other critters out cut and clear any vegetation for a 3-4 swath and spray it to keep it from regrowing.
And this will get a lot of people going, but just a bit of diesel fuel misted around will stop most snakes from entering.
Get a good tight cover on and tar up all the seams.
As far as drilled wells being better then dug because dug wells draw from shallow water, all water comes from the surface one place or another.
My drilled well that is below bedrock artesians most years how much and how fast depends on the weather from 3-5 years ago.
   / Cleaning dead snakes out of a dug well #32
Maybe your UV system is already on a maintenance schedule. Typically the unit needs cleaned once a year and bulbs replaced. Quartz sleeve replace every 2 years. If the water hasn't killed her by now it probably won't. Plus they're only effective at controlled flow rates. If anyone visits treat it like Mexico - Don't drink the water.
Whole house 5 micron filter is also inexpensive. Maybe there's a market for bottled snake water?:shocked:
   / Cleaning dead snakes out of a dug well #33
Very few pristine surface water sources left. When a professional in-depth analysis is made usually not good. If correction involves water purification systems and maintenance costs a sanitary well might be less cost long term.
Op said it was a spring, not surface water
   / Cleaning dead snakes out of a dug well #34
Most natural springs are typically shallow sources susceptible to contamination from surface conditions. This is why 100% of bottled spring water is filtered and purified by some means. All bottled spring water is pumped because natural springs can't deliver the gallons needed. All also has a sanitary well at the spring to eliminate surface water infiltration at the pump site.
Oh! But what about the picture of the beautiful mountain spring on the bottle? Ha Ha! Would anyone buy it if it said bottled well water with some minerals that's been filtered and purified ?
   / Cleaning dead snakes out of a dug well #35
Springs are referred to as "surface water"...as compared to drilled or dug wells etc...
   / Cleaning dead snakes out of a dug well #36
Sell it and pay for the drilled well. Snake River Springs.
Many years ago, I once read how many kidneys your clear glass of water has likely gone through in a place like New York.
I always hated working in old houses with cisterns. All seemed to have the same weird smell.
   / Cleaning dead snakes out of a dug well #37
... All bottled spring water is pumped because natural springs can't deliver the gallons needed....
That's kind of an odd statement.
All bottled spring water is probably pumped because how else would you get it into the bottles? There are plenty of springs in the U.S. with huge flow. Here's a list of some huge springs just in the Ozarks.
List of Ozark springs - Wikipedia
   / Cleaning dead snakes out of a dug well #38
More than 90 percent of the city’s water supply comes from the Catskill/Delaware watershed, about 125 miles north of NYC; the other 10 percent comes from the Croton watershed. The watershed sits on over a million acres, both publicly and privately owned, but highly regulated to make sure contaminants stay out of the water.
From here:
What’s So Great About New York City Water? | 6sqft
   / Cleaning dead snakes out of a dug well #39
What about all the estrogen and other medications supposedly in much drinking water?
Did New York finish that other masive tunnel? Maybe the one in the Die Hard Movie.
2020 WABASH DRY VAN (A59575)
2020 WABASH DRY...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
