Cleaning dead snakes out of a dug well
/ Cleaning dead snakes out of a dug well #21
My dad’s house gets his water from a dug well from the 1800s. Drinking water comes from a different drilled well. His dug well is feed from rain runoff.
The well is inside a well house. I’m sure snakes get in. But that water isn’t for drinking, although I used it for brushing teeth.
20 years ago I put a submersible pump in his drinking well, that is only plumbed to kitchen sink, so they didn’t have to hand pump their drinking water. In the country, this type of water system is common.
When the county put in a water line 40 yrs ago nobody was forced to join. I wish now he had a tap as it’s hard to maintain the old system.
covering a small spring shouldn’t be anywhere near the cost of digging a well.
/ Cleaning dead snakes out of a dug well #22
Well - I just guess I'm in the minority here. My water supply is a 26 foot deep spring. It was originally developed and used by the homesteader in 1892. It flows at a tad over 150 gpm. In 1982 we moved down from Alaska and I had my contractor dig out and improve this spring. It's now four foot diameter precast concrete rings - stacked one atop the other. The bottom one is perforated. The top ring pinches in and has a heavy duty three foot diameter lid. The spring water comes in from one side and exits thru the opposite side. The bottom is heavy cobble and gravel. Water depth is eleven feet.
Anyhow - it's a fantastic supply of fresh, clean water. In all my years here - 39+ - I've had one snake in the spring.
I'm part of that same minority I guess, though my well isn't nearly as deep as yours (maybe 10'). Best tasting water I've ever had, way better than some neighbors who have drilled wells. It sits uphill about 20' from the house so I don't need a pump...gravity does it all. Not tons of pressure, but adequate for anything we need to do.
The only problem we have is that it silts up every 10-15 years.
I was thinking the same thing. I wonder if the OP has priced drilled wells lately.:eek:
/ Cleaning dead snakes out of a dug well #23
Very few pristine surface water sources left. When a professional in-depth analysis is made usually not good. If correction involves water purification systems and maintenance costs a sanitary well might be less cost long term.
/ Cleaning dead snakes out of a dug well #24
Yup !!!!
/ Cleaning dead snakes out of a dug well #25
Our spring water consistently tests better than water from nearby wells...
/ Cleaning dead snakes out of a dug well #26
Testing is the key. If the Spring Water tests "Safe" then it should be protected and enjoyed. Drilled wells are expensive and there is no guarantee of good water or any water at all. I know a lot of people that have spent $10-20K on dry holes.
Wow, I've created a monster! OR is it a serpent? :D
As mentioned previously the water comes out of the ledge in 3 places, although I'm sure that surface water may get in at certain times. She has an ultraviolet sterilizer and had the water tested this spring. With an 8x12 foot concrete enclosure, a varmint proof cover is going to be a little work, but doable. The snakes most likely get up on the concrete to sun themselves, fall in and can't get out. I can pump it dry, get in there and clean it out; I just don't know how well I can clean up partially decomposed carcasses which have seeped into the crushed stone. I will have somebody around when I do so, as the last thing I need is to fall off the ladder when getting back out and have it fill back up with 10 feet of water again.
Then she would have to buy even more bleach… :laughing:
I've been pushing her to drill a well for several years now, but my parents were always frugal and what they have worked. Reality is that she won't be there many more years, and the property will likely be sold and subdivided when she's done with it.
/ Cleaning dead snakes out of a dug well #29
Just curios. Better how?
Less or lower levels of bacteria etc. or whatever it is they commonly test for...A neighbor is a disaster relief worker (retired head of engineering dept. at a major US university) and he tests both the springs we use and his drilled well...
/ Cleaning dead snakes out of a dug well #30
I used to send my wife down to muck out the well (36" galvanized culvert) but now we use a homemade "Brumby" type air pump to blow out any crud or build-up. All it uses is an air line and the water that is already in the well. Blows out sand, small gravel and any muck.
Savage 5740 (A60462)
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
Root Rake Loader Attachment (A61567)
Root Rake Loader...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
WANCO LIGHT TOWER (A60736)
WANCO LIGHT TOWER...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
