Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #6,941
Fallon, I forgot, what's the cutting width on your flail?
Vendor of the flail I'm looking at says 60hp min. My NX5510 is 55hp (46 pto). I may lose a little time on my first mowing, but subsequent mowings (shorter) ought to make up for that (and overall make up a lot of time over my 6' rotary).
/ Let's talk flail mowers #6,942
[in response to Dave's last post]
I have a fair amount of trees. I'll be pushing it with a 7'+ flail; having hydraulic side shift is the mitigation.
I do mow in different patterns from time to time. Just a lot of uneven ground no matter how I look at it. I have done leveling on some really bad ruts (from skidders): those were dealt with earlier on with my B7800 and a 5' box blade - A LOT OF WORK! I'm pretty much making pasture as I go/can.
Since your shopping you should look at the HINIKER 6 foot towed flail crop shredder. It has no rear roller and the cutting height can be adjusted either manually with a ratchet screw jack or by a hydraulic cylinder. The CV joint allows for tight turns and backing up if needed.
/ Let's talk flail mowers #6,943
Leon, wheels will tend to fall into various depressions/ruts.
Here's an example of my environment (it's actually one of the wider-open places- there's a dog in there!):
/ Let's talk flail mowers #6,944
I have had the same AGL165 for two years, I mow a good bit of rough ground and have not had any problems. I wish you to best of luck with yours. Sometimes one small bad part can cause more than one big part to break.
/ Let's talk flail mowers #6,945
hiniker 6 foot shredder
Here is a picture of the shredder;
/ Let's talk flail mowers #6,946
I am really enjoying mowing with the flail. I like having it offset so the tires are always on cut grass. Makes a nice even cut! Every time I use it I gain some knowledge that helps me keep things smooth. I really appreciate all the tips I have read in this thread.
/ Let's talk flail mowers #6,947
Re: hiniker 6 foot shredder
Yes, I had looked up that shredder. As noted, those wheels are going to be falling in depressions/holes/ruts that I have all over the place. The area in the picture I posted is reasonably smooth; I provided it to note that I have to work around a bunch of trees.
/ Let's talk flail mowers #6,948
I upgraded my flail mower I got a Alamo SHD96 off of Gov Deals auction. The guy told me it was a 88", but when I measured it the cut is 96".
I was not sure if I was going to be able to pick it up without adding weight, but my tractor picked it up without any added weight. My tractor also spun it up just fine, but I had to order knives, but the Y knives for the Alamo are way less than the ducks foot knives / airplane wings on my Ford 917.
PS my tractor asked if it made its butt look wide.
/ Let's talk flail mowers #6,949
Peruzzo Brush Bull 2200. Working width is 7.25'. Recomended HP is 70-110hp, the L4060 has 40. I definitely want more HP at times, but its adequate to get the job done going slow. My 32hp L3200 pulled the 7' Ford 917 ok as well. I appear to be a fan of going wide & slow. Although I don't go to slow as things aren't that thick most of the time. Colorado is dry so we dont have thick grass that really taxes HP. I probably would have a different opinion if I were back in Oregon or what not where they get lots of thick green stuff.
/ Let's talk flail mowers #6,950
Yes, it makes the butt look wide. That Alamo seems identical to my SHD88 which makes a 7.5ft wide cut. I got mine at auction for pocket change.
/ Let's talk flail mowers #6,951
Not sure if I got it for pocket change, but even with gas and buying new knives I have less than $2k in it. Does that sound reasonable?
/ Let's talk flail mowers #6,952
The flail I'm looking at is also 7.25'. I've got the thick green stuff. My NX being 5hp on the shy side of manufacturer's recommendation would you think I should be concerned? First mowing of the year can be pretty tough, in places (5' to 6'); for those I'd still be OK with running the rotary; after that, however, grass height wouldn't really get over 2'.
Slow is pretty much mandatory for me. Lots of trees. Ground isn't real smooth.
/ Let's talk flail mowers #6,953
I'm sure it is a reasonable value for that investment, if all the bearings are good, etc. Less than half what a new one would cost and the things are made like a tank. I got mine (give away price at public auction, $250 + fees, $300 total.) I had to put on a couple of knives, a new belt, 3 bolts,etc. After some use I had to replace a roller bearing and decided to replace both of them though only one was obviously bad. That cost me $150 per side with tax. Total in the thing now $600 plus spare knives and clevis's and pins. I have a Deere dealer only 20 miles from my farm with a full parts availability for the Alamo because the dealer supports the local State Road people. While parts are high there, the availability and location make up for it. Even there knives and small parts are reasonable.
I had never owned a flail before and did not realize how very useful it would be for my situation (80% clipping pastures.) I'd pay $2K for one in useable shape now but that's because of experience and learning from my inexpensive entry to the idea.
/ Let's talk flail mowers #6,954
What matters is whether you're OK with the costs. You have already shelled out for what you have in which case I figure that you believe so. And the longer it does the job for you without any significant costs then it'll only be more "reasonable." New quality flails of this size are, mostly, $4k and up.
I bought a 6' rotary, a BH26. It looked like heck (still does :laughing:). Was used commercially (a guy did lots of clearing- the unit saw LOTS of rocks). Paid $800 for it. Had some repairs done and had to buy a new PTO shaft. Probably have close to $1,300 in it. Can't touch anything like this new for under $3k (closer to $3.2k). Used 6' rotary cutters (other than really flimsy ones) are very rare around here. Market demand and availability matter vis a vis price/cost.
/ Let's talk flail mowers #6,955
I can tell you what works for me in my circumstances. Unfortunately I dont know what that means for your circumstances. It will probably work. I'm WAY under the HP ratings on my flail, you are pretty close.
A flail takes more HP than a rotary, all things being equal. Every time material hits a blade it ears HP. As flails mulch much better re-cutting material as the rotor moves over & as the material flys over the top. Much better mulching action & a smooth carpet of clippings with no clumps, but it does eat a little more HP.
If a 5-6' rotary tops out your HP, a 7' flail really will. You can go slow or do partial passes to compensate. But thick grass really takes flails as there is just a lot of mass to plow through & especially to re-cut repeatedly.
/ Let's talk flail mowers #6,956
With the exception of the first mowing and in the tallest stuff, my NX can pretty much drag and cut with the 6' rotary at any speed I can tolerate traveling at (given the fact that it can become quite the bumpy ride).
/ Let's talk flail mowers #6,957
Well I gave $100 for my Ford 917 and have use it for 10 years, but the hood is rusting out.
If I can get 10 years out of the SHD96 the money will have been well spent. Since the 2k divided by 10 years is only $200 per year.
/ Let's talk flail mowers #6,958
10 years is good. My years are different, though. Figure "dog years," so 10 years for you would be 70 for me :D
/ Let's talk flail mowers #6,959
I only got 4-5 years out of my $100 917. Put about $400 worth of knives, PTO shaft, belts & bearings into it. Hood is severely cracked & patched. Still keep it as a backup. The new Peruzzo has MANY years to go before it comes close to the same great ROI the 917 gave.
/ Let's talk flail mowers #6,960
I'm jealous. I wanted an 8' offset Alamo like that. None to be found. Settled for a 88" without offset. Still an awesome mower, but I could really use the offset for mowing my ditch, The county doesn't like to mow my ditch, and I don't blame them.
(1) 420/70-24 TIRE W/ 6 LUG RIM (A64280)
(1) 420/70-24 TIRE...
2004 Lincoln Town Car Limousine Sedan (A61574)
2004 Lincoln Town...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A64279)
2020 CATERPILLAR...
Rightline LP5C-C5B0-A 42in Hydraulic Side Shift Forks and Frame Forklift Attachment (A61572)
Rightline...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
2002 WACKER RD25 ROLLER (A59912)
2002 WACKER RD25...
