Loader JD 2020 FEL WEIGHT????
   / JD 2020 FEL WEIGHT???? #1
bodin1968
Montgomery, AL
1968 John Deere 2020
help... anyone know the approx. weight of a 1968 JD 2020 FEL?? thanks
(50 yr. old manual says tractor total weight for this 2020 (without FEL) is 4,930 lbs. see pic in profile to left....
   / JD 2020 FEL WEIGHT???? #2
I can't make out from the picture what model loader you have, but a safe guess would be 1000 to 1500 lbs, depending on what size bucket or attachment you have installed on it. At least that is the range of newer similar sized loaders.
   / JD 2020 FEL WEIGHT???? #3
I think FEL is a model 143 so I'll make a wild guess @ 5700-6000#s for both.
   / JD 2020 FEL WEIGHT???? #4
Without knowing what loader you have it is impossible to say. Many 2020痴 in the Northeast had model 48 loaders. Some had aftermarket brands installed. Also you need to know if the tires are filled.
Without knowing what loader you have it is impossible to say. Many 2020ç—´ in the Northeast had model 48 loaders. Some had aftermarket brands installed. Also you need to know if the tires are filled.
tires r not filled... small 40 inch bucket...... thanks fellas
   / JD 2020 FEL WEIGHT???? #7
Photo wouldn't load for me. Maybe no photo load caused by my slow computer!
   / JD 2020 FEL WEIGHT???? #8
Not for me either. Message invalid link.
ok try these.......
2016 Toro Groundsmaster 7200 72in Zero Turn Mower (A55851)
2016 Toro...
2018 MGB 2500HP QUINTUPLEX FRAC PUMP (A55745)
2018 MGB 2500HP...
2005 Peterbilt 387 with Wet Kit (A55314)
2005 Peterbilt 387...
2017 Dodge Ram SLT (A57024)
2017 Dodge Ram SLT...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
SHOP FAN (A55745)
SHOP FAN (A55745)
