Loader JD 2020 FEL WEIGHT????
   / JD 2020 FEL WEIGHT???? #1
bodin1968
Montgomery, AL
1968 John Deere 2020
help... anyone know the approx. weight of a 1968 JD 2020 FEL?? thanks
(50 yr. old manual says tractor total weight for this 2020 (without FEL) is 4,930 lbs. see pic in profile to left....
   / JD 2020 FEL WEIGHT???? #2
I can't make out from the picture what model loader you have, but a safe guess would be 1000 to 1500 lbs, depending on what size bucket or attachment you have installed on it. At least that is the range of newer similar sized loaders.
   / JD 2020 FEL WEIGHT???? #3
I think FEL is a model 143 so I'll make a wild guess @ 5700-6000#s for both.
   / JD 2020 FEL WEIGHT???? #4
Without knowing what loader you have it is impossible to say. Many 2020痴 in the Northeast had model 48 loaders. Some had aftermarket brands installed. Also you need to know if the tires are filled.
Without knowing what loader you have it is impossible to say. Many 2020ç—´ in the Northeast had model 48 loaders. Some had aftermarket brands installed. Also you need to know if the tires are filled.
tires r not filled... small 40 inch bucket...... thanks fellas
   / JD 2020 FEL WEIGHT???? #7
Photo wouldn't load for me. Maybe no photo load caused by my slow computer!
   / JD 2020 FEL WEIGHT???? #8
Not for me either. Message invalid link.
ok try these.......
1989 CAT D30D Articulating Dump Truck (A59213)
1989 CAT D30D...
John Deere Gator (A53317)
John Deere Gator...
19088 (A55758)
19088 (A55758)
2017 Ford F-150 XLT 4x4 Crew Cab Pickup Truck (A55973)
2017 Ford F-150...
SCAN TO RECEIVE TEXT UPDATES (A58375)
SCAN TO RECEIVE...
Harley Davidson (A56859)
Harley Davidson...
