Loader JD 2020 FEL WEIGHT????
   / JD 2020 FEL WEIGHT???? #1
bodin1968
Montgomery, AL
1968 John Deere 2020
help... anyone know the approx. weight of a 1968 JD 2020 FEL?? thanks
(50 yr. old manual says tractor total weight for this 2020 (without FEL) is 4,930 lbs. see pic in profile to left....
   / JD 2020 FEL WEIGHT???? #2
I can't make out from the picture what model loader you have, but a safe guess would be 1000 to 1500 lbs, depending on what size bucket or attachment you have installed on it. At least that is the range of newer similar sized loaders.
   / JD 2020 FEL WEIGHT???? #3
I think FEL is a model 143 so I'll make a wild guess @ 5700-6000#s for both.
   / JD 2020 FEL WEIGHT???? #4
Without knowing what loader you have it is impossible to say. Many 2020痴 in the Northeast had model 48 loaders. Some had aftermarket brands installed. Also you need to know if the tires are filled.
Without knowing what loader you have it is impossible to say. Many 2020ç—´ in the Northeast had model 48 loaders. Some had aftermarket brands installed. Also you need to know if the tires are filled.
tires r not filled... small 40 inch bucket...... thanks fellas
   / JD 2020 FEL WEIGHT???? #7
Photo wouldn't load for me. Maybe no photo load caused by my slow computer!
   / JD 2020 FEL WEIGHT???? #8
Not for me either. Message invalid link.
ok try these.......
WHISPERWATT DIESEL POWERED GENERATOR (A53843)
WHISPERWATT DIESEL...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
Adams 6Ton Hydraulic Lime Spreader (A57024)
Adams 6Ton...
10 STAINLESS FLOW TUBE (A55745)
10 STAINLESS FLOW...
