Jack Pine Stumpin
/ Jack Pine Stumpin #1
JbirdNC
Hendersonville, NC
Yanmar SA424 TLB
Week one of my new Yanmar SA424, my wife has me pulling out 8 stumps from an area she hopes to garden. The first 3 were the smallest, maybe 6-8” diameter. I did all 3 of those last Saturday. The 4th was a good one... about 16” diameter. I had to dig down pretty deep to cut all the roots I could find with a Sawzall. Even then, it took a combination of some vertical hand-winching with my 4T Comealong along with a good couple pulls with the tractor in a similar direction. I think I need to find a way to get more upward leverage on these stumps. They stay pretty thick all the way down and have very deep and solid taproots. I need to pull them UP not sideways. Any ideas? 60562323852__7B5D3F51-44DB-4623-B44B-83FE6DF0E333.JPG60557404292__0A08D0CB-64FF-4A9A-AF6D-7AF046679A71.JPGIMG_1716.JPG
/ Jack Pine Stumpin #2
Next time it may be easier to pull the stump out first and then cut the tree down. :greenthumb:
/ Jack Pine Stumpin #3
/ Jack Pine Stumpin #4
I've done something similar to that video with a 4' stout log on end next to the stump.
/ Jack Pine Stumpin #7
What about the old tire rim trick. Get as big of a rim as you can find and drape the chain over the rim to redirect the pull upwards.
/ Jack Pine Stumpin #8
/ Jack Pine Stumpin #9
I made this "A" frame out of 1.5 X 3/16 angle iron for pulling out some large bushes before I had my tractor/loader. It worked pretty good but it is only about 5' tall. I think taller one would do the work a little faster.
/ Jack Pine Stumpin
I just emailed my dealer to see if he has an old rim I cans use! Thanks!
/ Jack Pine Stumpin
I like the metal approach but I’m not a welder. Using the big wooden posts might be more my capability though! Thanks!
/ Jack Pine Stumpin #13
I would have kept digging with the hoe. But maybe there's a goal I don't see?
/ Jack Pine Stumpin #15
Jack pines do have a pretty substantial tap root.
/ Jack Pine Stumpin
I went to Lowe’s and bought a few 4x4s and bolted them together with threaded rod. The middle one is cut 6” short to and capped with a metal plate to provide a channel for the chain/strap to be kept in and no worry of it slipping off. Tomorrow it will get tested.IMG_1738.JPGIMG_1739.JPG
/ Jack Pine Stumpin #17
Anxious to here the results.
/ Jack Pine Stumpin #18
Nice. If it ends tipping, you could add a couple outriggers
Quick Attach Grapple Bucket (A66285)
Quick Attach...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
NEW Wolverine SP-15-84W Snow Blade (A62679)
NEW Wolverine...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
Livestock Catch Chute (A66408)
Livestock Catch...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
