Jack Pine Stumpin
/ Jack Pine Stumpin #1
JbirdNC
Hendersonville, NC
Yanmar SA424 TLB
Week one of my new Yanmar SA424, my wife has me pulling out 8 stumps from an area she hopes to garden. The first 3 were the smallest, maybe 6-8” diameter. I did all 3 of those last Saturday. The 4th was a good one... about 16” diameter. I had to dig down pretty deep to cut all the roots I could find with a Sawzall. Even then, it took a combination of some vertical hand-winching with my 4T Comealong along with a good couple pulls with the tractor in a similar direction. I think I need to find a way to get more upward leverage on these stumps. They stay pretty thick all the way down and have very deep and solid taproots. I need to pull them UP not sideways. Any ideas? 60562323852__7B5D3F51-44DB-4623-B44B-83FE6DF0E333.JPG60557404292__0A08D0CB-64FF-4A9A-AF6D-7AF046679A71.JPGIMG_1716.JPG
/ Jack Pine Stumpin #2
Next time it may be easier to pull the stump out first and then cut the tree down. :greenthumb:
/ Jack Pine Stumpin #3
/ Jack Pine Stumpin #4
I've done something similar to that video with a 4' stout log on end next to the stump.
/ Jack Pine Stumpin #7
What about the old tire rim trick. Get as big of a rim as you can find and drape the chain over the rim to redirect the pull upwards.
/ Jack Pine Stumpin #8
/ Jack Pine Stumpin #9
I made this "A" frame out of 1.5 X 3/16 angle iron for pulling out some large bushes before I had my tractor/loader. It worked pretty good but it is only about 5' tall. I think taller one would do the work a little faster.
/ Jack Pine Stumpin
I just emailed my dealer to see if he has an old rim I cans use! Thanks!
/ Jack Pine Stumpin
I like the metal approach but I’m not a welder. Using the big wooden posts might be more my capability though! Thanks!
/ Jack Pine Stumpin #13
I would have kept digging with the hoe. But maybe there's a goal I don't see?
/ Jack Pine Stumpin #15
Jack pines do have a pretty substantial tap root.
/ Jack Pine Stumpin
I went to Lowe’s and bought a few 4x4s and bolted them together with threaded rod. The middle one is cut 6” short to and capped with a metal plate to provide a channel for the chain/strap to be kept in and no worry of it slipping off. Tomorrow it will get tested.IMG_1738.JPGIMG_1739.JPG
/ Jack Pine Stumpin #17
Anxious to here the results.
/ Jack Pine Stumpin #18
Nice. If it ends tipping, you could add a couple outriggers
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
7' Road Blade (A62613)
7in. Auger Bit (A65640)
7in. Auger Bit...
2019 KENWORTH T680 (A65643)
2019 KENWORTH T680...
Reddick Crop Sprayer (A62613)
Reddick Crop...
