Trophyduck
Member
I just bought a bush hog quick hitch. Do I need bushings on my implements? I was told no when I bought it but there is lot of room at the hook. It's a cat1
Need is a bit strong of a word. It's best to use them though. I have them on most of my impliments. My King Kutter tiller cant use them though. There isnt enough clearance between the frame & the pin with them on. I could rebuild things with the pins an inch or 2 further out, but I havent bothered. It's not wearing badly or anything.
Not sure which dimension needs more clearance for your tiller. But you know you can flip the bushing around, so the collar portion is to the outside (or vise versa if you need).
I had to flip them on my brush hog:
You can see the rust on the frame behind the pins from where I tried & failed to hitch up with the bushings on. There is about 2.5" of clearance without bushings which is enough for the hooks to clear. With the bushings on it wont slide into the hooks as they hit the frame.Not sure which dimension needs more clearance for your tiller. But you know you can flip the bushing around, so the collar portion is to the outside (or vise versa if you need).
