Quick Hitches Bushings or not?
   / Bushings or not? #1
Trophyduck
Maryland
LS XR4145 (45hp HST)
I just bought a bush hog quick hitch. Do I need bushings on my implements? I was told no when I bought it but there is lot of room at the hook. It's a cat1
   / Bushings or not? #2
I would use bushings. The sloppy fit without them would bother me. You don't need the expensive 2-diameter pin-on bushings. Just use the cheap category adapter bushings.
Bruce
   / Bushings or not? #3
The more surface contact the less wear. Land Pride (now a branch of Kubota) makes a complete set of various lengths for top and bottom pins. I have bushings on each implement so they are there when needed and not in the grass somewhere.
Ron
   / Bushings or not? #4
As Tractor Seabee said. ^
I, too, have bushings on all of my 3PH implements for use with my JD iMatch quick hitch (I'm Cat 1 also). They eliminate most of the 'rattling around' due to a more snug fit and not all 3PH implements are built quite to "standard" dimensions... and the same can be said for the various makers of 3PH quick hitches.
Pick a couple of sets up at either your Dealership or a rural supply store and try them out.
   / Bushings or not? #5
I was told the same thing, that they are not "needed". I guess most folks don't use them? I dunno about that, but my dealer said I was the first one that he's had that ordered extra sets. I bought them for each of my attachments, plus a couple of spare pairs. Because that is a *lot* of slop, and it would bother me to run them that way. They were a pain to get the roll pin in the bushing (at least mine were), so I started the roll pin in the bushing hole by using my hydraulic shop press to press the roll pin into the hole until it was just short of entering the inside of the bushing pin hole. That helped a lot, as I just had to use a ball peen hammer to drive it the rest of the way through once I had it on the 3 pt hitch pin.
   / Bushings or not? #6
Need is a bit strong of a word. It's best to use them though. I have them on most of my impliments. My King Kutter tiller cant use them though. There isnt enough clearance between the frame & the pin with them on. I could rebuild things with the pins an inch or 2 further out, but I havent bothered. It's not wearing badly or anything.
   / Bushings or not? #7
Here is what I use. Inexpensive compared to the adapters. 20191107_180432.jpeg
   / Bushings or not? #8
Not sure which dimension needs more clearance for your tiller. But you know you can flip the bushing around, so the collar portion is to the outside (or vise versa if you need).
I had to flip them on my brush hog:
   / Bushings or not? #9
I use the bushing/adapters on all my 3pt attachments with my Quick Hitch just because it helps snug everything up and at 5.50 a pair at fleet farm it was not to expensive to do. I bought the 5 pair they had because the price was so cheap.
   / Bushings or not? #10
Only my (free :thumbsup:) JD ballast box required that type of bushing... it was probably designed for a Cat 0/1 so the pins were a wee bit short.
All of my other implements use the type that Citydude posted.
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A53843)
2012 NORAM POWER...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
