Building a bridge?
/ Building a bridge? #42
It will be there long after you're done needing it. :thumbsup:
I hope not, it is still a hundred feet away from what I hope to be its final resting place, I had a heath issue after I brought it home and got it unloaded and moved close to the stream.
Then it was much to wet all season to get it installed by myself.
I thought about hiring it done, but that is not nearly as much fun
/ Building a bridge? #44
LOL, as I did
:laughing:
Actually I sort of hoped he was being facetious
/ Building a bridge? #45
LOL, as I did
:laughing:
Yep, Radios 1 is deadpanning us. Unless that watershed has changed, the only hope is no more gullywashers. Good luck with that...
The area is generally Sandy. I may first try taking the bank down then putting some large gravel in the flow area. This area doesn't generally flood and the flow is fairly consistent.
/ Building a bridge? #47
I saw in the beginning of this thread several comments were made about using a semi trailer which is a little over kill for a 5-6 foot gap. My neighbor had me bring home a flat bed from a straight truck. I was 20 feet long and was light enough to move around with a skid steer. And it was strong enough to hold up the SS.
/ Building a bridge? #48
We have multiple creeks just like yours .on one i use 2 24 in culverts and in normal yrs i may have to repair the crossing once or twice a yr, the other crossing is way to wide so we just cut down the sides, when the weather is dry its no problem crossing , this time of yr foget it.
Unused 2024 Land Pride PF1242 42. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
2016 Toro ReelMaster 5510-D Commercial Reel Mower (A66734)
2016 Toro...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2012 CHEVROLET IMPALA CAR (A66091)
2012 CHEVROLET...
2006 Ford F-350 4x4 Ext. Cab Reading Service Truck (A66736)
2006 Ford F-350...
2011 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2011 CHANDLER TRI...
