Building a bridge?
   / Building a bridge? #31
Depending on maximum flow, what about some 45 gallon drums, cut tops and bottoms out. Place end to end, cover with a layer of concrete, then back fill with soil.
Would an old trailer frame work? I see these on FB market locally for $500 or so. I think they are old mobile home frames?
   / Building a bridge? #33
I cross bridges often with heavy equipment. If you are going to take the time to build a bridge, build a strong one, that will last decades.
A mobile home frame depends on the wall/roof structure to gain strength. Once you remove all that they get pretty wiggly.
This is my little creek. I wonder if it would be best to just cut down the banks and make a crossing that way.20191128_133234.jpg
   / Building a bridge? #36
that creek is dry. why not just fill it in??..
   / Building a bridge? #38
This is my little creek. I wonder if it would be best to just cut down the banks and make a crossing that way.View attachment 630707
If you only plan to cross a couple of times that would work. If you plan to use it on a regular basis in all kinds of weather it will get messy; and in the long run it's better to do it right. The better crossing seems to be about 2/3 of the way up your picture, although it isn't where your trail is. The banks are higher while the channel is narrower.
4' dual wall plastic culvert is $42 per foot governmental cost here is Missouri. The cost of larger culverts is extremely high.
I was replying to a suggestion of concrete. I believe that the 18' bridge I was quoted for was a bit of overkill though. I probably will have a small bridge with a 6'span built on concrete waste blocks, as it's a major access road and will be used for longer than I'm around. I also have some short bridge steel which came out of another crossing a few miles away which will keep the cost down.
Now we have seen some pictures of his crossing, so know more about what he's trying to accomplish.
   / Building a bridge? #39
I paid $750 (including 7% taxes) last spring for my 4' dual wall plastic culvert 20 foot long
   / Building a bridge? #40
A concrete ford doesn't have to be at current creek-bottom level. It can have its downstream edge above that and make a nice waterfall onto large rocks. This lowers the approach angle.
Of add a culvert for low water and a concrete ford for high water.
Bruce
1267 (A50490)
1267 (A50490)
2013 Infiniti JX35 SUV (A50324)
2013 Infiniti JX35...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
1043 (A50459)
1043 (A50459)
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
New Holland TS6.120 4WD Agricultural Tractor (A50322)
New Holland...
