Which trailer to buy?
/ Which trailer to buy?
That trailer appears to have house trailer wheels/axles.
If so, they are rated for a very limited life usage.
No, go to the Hudson trailer website and look at the HSE-18 trailer. They still use these axles and wheels on them today. The mobile home axles have thinner tubes and no camber bend. Equipment trailer axles have heavier tubes with a camber bend in them. The tires are equipment tires, not mobile home tires.
/ Which trailer to buy? #43
It is not possible to determine the axle type just from your pictures.
The tires certainly may be equipment trailer type.
The wheels do appear to be standard house trailer wheels however.
The HSE-18 trailers shown on the Hudson Trailer website, most definitely are not shown with the same style wheels as those in your picture.
/ Which trailer to buy? #44
You might want to look at their "PRO SERIES - HSE DELUXE 4 TON" found at: Hudson Brothers HSE DELUXE 4 TON
628906d1573954916-trailer-buy-hudsontrailer-jpeg
Those are Dayton style rims, that is also the type used for mobile home tires, but they are not necessarily mobile home tires. I would bet that those axles have bolted on (vs welded on) brake backing plates and all parts are serviceable.
Aaron Z
Aaron Z
Aaron, Thanks for posting up that picture from Hudson's website. That is my trailer just like the picture that I put up on here. YES, the "RIMS" on these trailers and mobile home trailers are one and the same. The tires however are not. Mobile home tires are clearly marked "FOR MOBILE HOME USE ONLY". If anyone doesn't believe that just go look at some. My springs are also serviceable with replaceable brass bushings which is another plus as I am going to update them with grease-able bolts. I don't think anyone is going to fork over $6,000.00 for a new trailer like this if it came with non-serviceable brakes.
/ Which trailer to buy? #46
What’s the logic for building a trailer with hubs like that? There’s no way I’d want a trailer with those hubs even if everything else is fine . Mostly because of what we have going on here. Second is if they’re anything like the Dayton hubs on my dump truck they’re a pain to take on and off.
/ Which trailer to buy? #47
Price, weight capacity and height.
IIRC, those are 6000# axles and until the last few years there was little or nothing available in a similar price range that could carry that much weight and keep the trailer deck that low (important when running something like a paving roller up onto the trailer).
Aaron Z
Aaron Z
One thing I noticed about my trailer is that the loading ramps are much longer than the standard ramps. Hudson's website does list optional longer loading ramps.
/ Which trailer to buy? #49
Somehow/someway /someone suggested that the TIRES were mobile home tires?
Not me!
I mentioned nothing about tires, or brakes!
In my post #40, I only suggested only that the axles and wheels might be mobile home type.
From the picture, the wheels are mobile home type!
If you read some history on mobile home wheels you will find that due to the different (cheap) wheel construction style, the mobile home wheel itself will often fail, before you can stop after a high speed blowout.
On a tandem trailer, that failure is sometimes followed by a second tire/wheel failure on the same side.
Regular 8 hole steel wheels are much safer!
Perhaps the $6000 new trailer cost you reference, is for a gold plated 10K-18' equipment trailer?
I have a nice new 14K-20', PT deck, equipment trailer that I bought from a dealer, for $4,400.
/ Which trailer to buy? #50
Somehow/someway /someone suggested that the TIRES were mobile home tires.
Not me!
In my post #40, I only suggested that the axles might be, and that the wheels ARE!
BTW, a new 10K 18' equipment trailer should not cost $6000.
I have a new 14K-20' equipment trailer that I bought for $4,400.
They MIGHT be. They make that style wheel and tire in a "trailer" non-mobile home trailer tire as well as in a mobile home rated tire.
Here is a Kenda Load Range G in that size for a "trailer tire" (ie: not a mobile home tire): Kenda 8-14.5LT Bias Trailer Tire - Load Range G Kenda Tires and Wheels AM1289
Here is the same size and rating Kenda Load Range G "Mobile Home" tire: Kenda K391M Mobile Home Tire - 8-14.5MH - Load Range G Kenda Tires and Wheels AM1327
Aaron Z
Here is a Kenda Load Range G in that size for a "trailer tire" (ie: not a mobile home tire): Kenda 8-14.5LT Bias Trailer Tire - Load Range G Kenda Tires and Wheels AM1�289
Here is the same size and rating Kenda Load Range G "Mobile Home" tire: Kenda K391M Mobile Home Tire - 8-14.5MH - Load Range G Kenda Tires and Wheels AM1�327
Aaron Z
Thanks Aaron for those links. Anyone reading this and looking at the tire links will notice the MH after the tire size which means Mobil Home and the LT after the trailer size for Light Truck/Trailer. Here are some more pictures of the tires, axles and backing plates on my trailer. The backing plates are held on by five studs, I think. I wasn't laying down on the ground to make sure. The axles are sprung in the center for wheel camber. Aaron ?? for you. Are the 7-14.5 and 8-14.5 mounted on the same width rims? I have 7-14.5's on my rims. I found where the 8-14.5's are one inch taller. My guess is that the tires are the same width. I can't seem to find any information on rim sizes for these tires.. I'll keep looking though. My ramps have an added section 2 feet longer than standard. They are 6 feet long total. They will be getting the helper springs added to them for easier lifting.
/ Which trailer to buy? #52
Aaron Z
Seems like this discussion keeps going round and round about TIRES.
If the tires say "trailer only" or "LT", and are of proper size and weight rating, they are just fine.
My post#40 intent was to discuss the style/type of AXLES/WHEELS....ONLY!
/ Which trailer to buy? #53
They make that style of axle/wheel in both non-serviceable "mobile home grade" (cheap, undersized bearings, oddball spindle size, welded brake backing plate, straight axle tube, etc) which are intended to be used once or twice and serviceable "trailer grade" (full sized bearings, standard trailer spindle size, bolted backing plates, cambered axle tube, etc) which are intended to be used day in and day out.
Both are generally rated for around 6000# per axle, one is made to be used once, the other is made to be a heavy duty low profile axle.
One is junk, the other is not.
Aaron Z
Not me!
The $6K price I quoted was from what I found on the internet for the same trailer that I bought. I almost drove to PA to buy a brand new PJ 20 foot with the beavertail for $4K out the door. They didn't have that particular one at their Northeast store. I have seen new trailers like I wanted for as low as $3195. The shipping on it would kill that deal. When I read some of the reviews on other brands I crossed them right off my list. The prices are all over the place on trailers. One local dealer wanted $860 more for the same PJ trailer in PA. I liked the way the Hudson is built. The single side rails cut down on the overall weight of the trailer. Plus I didn't have to spend $4K plus on a trailer that I am rarely going to use. I may use this once or twice a year if I am lucky. I can very easily do a swap out of the hubs if I wanted to go over to six lug wheels. Used trailer tires and wheels around here are cheap.
/ Which trailer to buy? #55
Nice looking trailer..
Adams Weight Hopper (A63688)
Adams Weight...
New 11'x19' Steel Carport with 10' open sidewalls  (A62679)
New 11'x19' Steel...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2015 Isuzu NPR HD Septic Pump Truck (A62613)
2015 Isuzu NPR HD...
2023 Freightliner Cascadia 116 S/A Day Cab Truck Tractor (A61573)
2023 Freightliner...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
