PT-1430 Utility Grapple
/ PT-1430 Utility Grapple
The PT made grapple bucket works very well. I just like having the right tool for the job and an open sided bucket or skeleton frame would work better, not sure how much, but better. The 4 in 1 is 66" wide and made for a much heavier tractor and tips the PT forward just by articulating.
Oh, I see now. I used to have a 4 in 1 bucket for the 425 I used to have, and it worked well. The PT mini hoe with the thumb works really well for grabbing ahold of things. You can dig a tree out then pick up with the mini hoe. So actually, it's I guess you could say that I have two grapples now.
/ PT-1430 Utility Grapple #12
My front hoe pops off the Chineese quick attach if I pull to hard. I think I will cut off the SSQA plate and weld a Power Trac blank plate, this will make the visibility better too. I wasn't sure I would like the front hoe, but it is very useful. It shows me how much better the PT quick attach is designed over SSQA. And I am glade the hoses were long enough for it to reach the ground:thumbdown:
/ PT-1430 Utility Grapple #13
Plus you'll save some significant weight if you remove the SSQA hardware from the hoe and the PT, and just use the PT QA, plus gain some visibility.
/ PT-1430 Utility Grapple #15
I kept it with the SSQA because I was concerned with resale value if I didn't like using it. Now I am just trying to figure out if it would be better to cut/weld the plate at 90 deg angle, which is what PT is doing, or at an angle to get more lift height (like most of the PT attachments). Also do I leave it full length or shorten? One reason I didn't by an original PT mini hoe is they are all the same hoe sold for a small PT422 up to the largest tractors with the only difference being the mounting plate. Keeping it longer doesn't seem to hurt the digging power because that comes from curling the bucket and reversing the tractor, it just reduces the lift capacity which even with the SSQA mount and the SSQA to PT adapter, was very acceptable. So it is on the list to dig out the plasma cutter and a new tip.
I am very disappointed with the adapter. The other day I moved an old stump with a fork lift attachment and went to roll the stump toward the tractor and bang, there was the forks, separated from the tractor.
/ PT-1430 Utility Grapple #16
Are you sure about that?
Website lists:
T8 class
$1350
Thumb is $150
T12 class
$1500
Thumb is $150
T18 class
$2300
Thumb is $200
T24 class
$2400
Thumb is $200
I wouldn't think there'd be over $1000 price difference in just a QA plate.
From pictures of the different size PT's, it's hard to tell by looking at the mini hoe if they are different sizes?
This is a link where Sedgewood is talking about the PT Mini Hoe
My Mini Hoe Thumb Attachment
/ PT-1430 Utility Grapple #18
When I was testing out the hoe on the 1430, I casually asked Terry if the hoes were the same except for the mounting plate and was told they were. It probably was an offhanded answer, I filed it away as fact.
2018 Chevrolet Trax SUV (A61569)
2018 Chevrolet...
4'x6' Stack of Sheet Metal (A60463)
4'x6' Stack of...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
1449 (A57192)
1449 (A57192)
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
2013 Case 850L (A60462)
2013 Case 850L...
