PT-1430 Utility Grapple
/ PT-1430 Utility Grapple #1
joshlee
Beaver Springs, PA
Power Trac PT1430 Year made 2016
Here is the Utility Grapple for the 1430. After driving around and picking up fallen limbs and smaller size trees, I would just like to fill everyone in on what I think of it.
1. This is a light/medium duty grapple that is made out of 3/8" plate steel, and is very handy for sliding in under brush, trees, etc.
2. By the one picture you can see that it can hold a massive volume of material, and dumping the stuff out of it works really nice too; no hang up.
3. The 29" wide grapple with the open sides is a bonus, because it allows for holding more stuff in the grapple, and it not being so wide makes it nice for not having to get the tractor lined up perpendicular to the trees/brush, etc.
4. The visibility is great. You can see really well while sliding the base underneath whatever you are picking.
5. The cylinder is super powerful compared to the strength of the grapple, and the cylinder can damage the grapple if the operator clamps down on the material too much. So, you really have to be careful or you will bend the base of the grapple!
The base of it seems to have allot of springiness to it. I壇 like to know what it is made out of? It might be mild steel, I am not sure?
/ PT-1430 Utility Grapple #5
Looks nice!! I am on the fence about buying one of those or that small Wicked brush grapple.
This Utility Grapple is how you said it was John. When crushing material inside the grapple, one has to be very careful. For all the more I paid for it compared to other grapples, I could easily reinforce that bottom part if I wanted to. Yeah, those Wicked brush grapples are nice. Did you check out the grapples for mini skid steers on the Skid Steer Solutions | The Trusted Equipment Source website? They have a couple of nice ones on there too. This is the one that I was thinking about getting; Blue Diamond Mini Skid Steer Grapple Bucket | Skid Steer Solutions . I'm glad that I got the one from PT though. The hoses on it could be a few inches longer. I should call down and mention that to them.
/ PT-1430 Utility Grapple #7
Yes, I have been checking out everything that the internet offers. First I have to sell a 4 in 1 bucket that is way too big for the PT, then will have $ to get another attachment. Please keep us posted on all the work you get done with it.
Yep, I sure will.
So, you don t think your grapple works out that well with the 1430?
/ PT-1430 Utility Grapple #9
The PT made grapple bucket works very well. I just like having the right tool for the job and an open sided bucket or skeleton frame would work better, not sure how much, but better. The 4 in 1 is 66" wide and made for a much heavier tractor and tips the PT forward just by articulating.
Correction, the hoses are not to short. There was a wire tie on the one hose where it comes out of the cylinder, and I was thinking it was to free up more hose. I cut it off and now I have an extra 3 or so inches of hose. The length is perfect now.
Oh, I see now. I used to have a 4 in 1 bucket for the 425 I used to have, and it worked well. The PT mini hoe with the thumb works really well for grabbing ahold of things. You can dig a tree out then pick up with the mini hoe. So actually, it's I guess you could say that I have two grapples now.
/ PT-1430 Utility Grapple #12
My front hoe pops off the Chineese quick attach if I pull to hard. I think I will cut off the SSQA plate and weld a Power Trac blank plate, this will make the visibility better too. I wasn't sure I would like the front hoe, but it is very useful. It shows me how much better the PT quick attach is designed over SSQA. And I am glade the hoses were long enough for it to reach the ground:thumbdown:
/ PT-1430 Utility Grapple #13
Plus you'll save some significant weight if you remove the SSQA hardware from the hoe and the PT, and just use the PT QA, plus gain some visibility.
/ PT-1430 Utility Grapple #15
I kept it with the SSQA because I was concerned with resale value if I didn't like using it. Now I am just trying to figure out if it would be better to cut/weld the plate at 90 deg angle, which is what PT is doing, or at an angle to get more lift height (like most of the PT attachments). Also do I leave it full length or shorten? One reason I didn't by an original PT mini hoe is they are all the same hoe sold for a small PT422 up to the largest tractors with the only difference being the mounting plate. Keeping it longer doesn't seem to hurt the digging power because that comes from curling the bucket and reversing the tractor, it just reduces the lift capacity which even with the SSQA mount and the SSQA to PT adapter, was very acceptable. So it is on the list to dig out the plasma cutter and a new tip.
I am very disappointed with the adapter. The other day I moved an old stump with a fork lift attachment and went to roll the stump toward the tractor and bang, there was the forks, separated from the tractor.
/ PT-1430 Utility Grapple #16
Are you sure about that?
Website lists:
T8 class
$1350
Thumb is $150
T12 class
$1500
Thumb is $150
T18 class
$2300
Thumb is $200
T24 class
$2400
Thumb is $200
I wouldn't think there'd be over $1000 price difference in just a QA plate.
From pictures of the different size PT's, it's hard to tell by looking at the mini hoe if they are different sizes?
This is a link where Sedgewood is talking about the PT Mini Hoe
My Mini Hoe Thumb Attachment
/ PT-1430 Utility Grapple #18
When I was testing out the hoe on the 1430, I casually asked Terry if the hoes were the same except for the mounting plate and was told they were. It probably was an offhanded answer, I filed it away as fact.
