YM2210 injectors, fuel pump, problem??
/ YM2210 injectors, fuel pump, problem??
Hey sorry for the delay in my reply's, Im at work and working on this.
/ YM2210 injectors, fuel pump, problem?? #102
And you are sure it can't suck air where the fuel supply connects to the IP correct? Just want to eliminate anything that might be easy and cheap before you send the IP out for rebuild.. I am not familiar with this particular system but you only have a few components to do a process of elimination on..
there is a oring on the bleeder i will look at one more time just to make sure.
/ YM2210 injectors, fuel pump, problem?? #104
Just a heads up, a line, o-ring etc can suck air without leaking fuel, best to check..
I understand that and that why i said i will look at that one more time, most of the time, something on the intake side will suck in and something on the pressure side will leak out.
/ YM2210 injectors, fuel pump, problem?? #108
For that much air It's more than a pin hole. Gravity will push fuel out of a pin hole. It's under pressure and will get pushed out. Your see it. In or out of the pump..
you would think..
/ YM2210 injectors, fuel pump, problem?? #110
/ YM2210 injectors, fuel pump, problem?? #111
The bleeder DOES NOT take an Oring.. it takes a crush gasket.. Maybe we found something.??
/ YM2210 injectors, fuel pump, problem?? #112
I assumed when he said O-ring he was talking about the copper washer but IDK.. Even if it is a crush washer, they don't last long loosening and tightening it if that has been done several times.. Troubleshooting mine, I went through three of them..
On my pump, the bleeder has a O- ring on it, maybe it needs a copper washer, I have some I do believe.
Thanks for the help!
Well ****, I will change it.
Thanks for your time and help TPG!!
/ YM2210 injectors, fuel pump, problem?? #116
Any IP breeder I have seen has a copper "crush washer" that's fairly soft.. Has to be a perfect fit, those washers have burnt me more than once..
With any luck that is why you are getting so much air into the IP..
Man that makes sense, I ordered new gaskets for bleeds and they sent o-rings, witch I wasn’t happy about because I have a bunch of
o-rings and thought they needed to be at least nylon washers ..
Thanks for your input!!
/ YM2210 injectors, fuel pump, problem?? #118
I thought the same thing. But before posting I looked at Hoye's diagram for YM2000 and found what looks like a rubber o-ring at the bleeder screw so I didn't say anything.
I would expect a leak there to dribble instead of suck air, however. It's a simple gravity-feed environment.
Ding ding ding ding ding ding , I believe we have a winner !!
Well I didn’t have a new copper washer but I did have a old one and put that on and I would say 95% of my air @ the injectors is gone ,unbelievable, so tomorrow I will get a new washer and I’m sure it will be fixed 100% let’s hope .
THANK YOU VERY MUCH!!!!!!!! TPG.
At first I was upset with the vendor that sent the O-rings for the seals and that probably explains why there was a o-ring on it when I got it, the guy who I got the tractor from used the same vender. ultimately there’s only one person at fault and that is ME, MYSELF and I . I know better than to use a O-ring on there and I still did it , I guess it’s like they say if you don’t screw up every now and then you’re not doing anything .
You would think it would especially when it wasn’t running with the amount of pressure that would be there but I guess not , but I guess it has enough vacuum on that 90° banjo bolt that it pulls in air .
Thanks for you help sir!
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
UNUSED WOLVERINE QMP3-16-6T QUICK ATTACH PLATE (A62131)
UNUSED WOLVERINE...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
2021 BOBCAT T66 R SERIES SKID STEER (A62129)
2021 BOBCAT T66 R...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
