Echo vs Husqvarna
/ Echo vs Husqvarna #21
I have a Stihl 291 with 24 inch bar, dang good saw. Recently bought a Echo with 20 inch bar. At first I didn't like the echo, was different. What little I've used it I like it more and more every time I pick it up. I have a beat to heck 14 inch bar Homelite I bought refurbished off ebay for 49 dollars or something like that about 10 years back that leaks bar oil but start every time and what I used the most. If I replace this Homelite it will more than likely be with another Echo. Echo is a good saw.
I'll say this, if I have a problem with a saw, I hope its a Stihl, there is a Stihl dealer on every corner is East and South East Texas. Not as many Echo dealers but I am sure there are enough to get a saw fixed.
Thanks, Billy
/ Echo vs Husqvarna #22
Thanks, Billy
Try the CS310 for a 14" bar and you wont look back. Light and powerful.
/ Echo vs Husqvarna #23
I've always heard great things about Echo, I got a SRM2100 weedeater free from work that didn't have a cutter head, found a 3 tooth blade at a garage sale for $.25, went to the lawn mower store near work and spent $1 on left hand nut for the shaft, wouldn't start so changed the regulator diaphragm in the carb and it still didn't start so I found the front crank seal was sticking out, pushed it back in and have probably put 10 gallons of gas through the thing... the shaft liner is FRIED and makes a heck of a racket but for a 21cc engine it will out do any other 30cc homeowner trimmer...
I don't have any non box store saws so no experience in that world...
/ Echo vs Husqvarna
This is the one I am considering. My husqvarna 345 is very similar. Might spend the extra $30 and go to 18” bar. Still on the fence.
/ Echo vs Husqvarna #25
With it only being 34cc, I'd keep the 16" bar. If you need a longer bar, I'd go more CC. My Stihl MS250 rips pretty good with a 16" bar and it's 45cc. I opted for an 18" bar on my Echo 501P.
/ Echo vs Husqvarna
I use my saws mainly to clear branches, saplings and occasional firewood. I leave felling big trees to the pros.
/ Echo vs Husqvarna #27
That looks like a CS 352. I have one. It's a nice little saw, light and very easy to start. I use it for brush cutting. 18" is too long a bar for it. Did I mention how easy it starts? I think that's it's best feature. When I am cutting brush I'm constantly stopping the saw to pull brush out of the way (it's pretty thick). The Stihl 025 I had was giving me "golfers elbow" due to how hard it pulls.
The CS352's air filtration is not that good. I find fine material inside the carb every time I take it apart to clean it. I added a piece of oiled foam filter material on one side of the air box where the larger holes are. It helps some. But the air box is not sealed and takes in air from many directions. Wrapping the stock filter with oiled foam would work better but I have yet to find the right size foam and glue that will work.
The CS352 comes with a catalytic converter muffler. It's somewhat restrictive and puts heat into the engine. I bought an extra muffler and gutted the cat. (wear breathing protection when you do that). Then I removed the carb limiting tabs so I could retune the carb as it comes set very lean. Of course modifying the saw may cause the dealer or Echo to not honor the warranty. BTW you can get it for about the same price from a real dealer if you wait for one of Echo's sales promotions. Echo is known for being stingy on the warranty. A real dealer will at least try, I don't see a box store doing much for you on that.
My pro Stihls have needed zero mods, they just work perfectly out of the box. They cost more up front though and there isn't anything in their line quite like the CS352.
/ Echo vs Husqvarna
Thanks for the input. My husqvarna was/is an easy starter, been a good saw. Started leaking bar oil and, at certain angles, fuel. Does not idle well either. It has hundreds of hours cutting on it, just getting a little tired. I plan to keep it as a backup, especially since I am in hurricane season. The only experience with Stihl was when I was with the fire dept. Powerful saws, but unlike you I found them hard to start. Not sure why. Was a bit concerning because we needed them quickly, no time to waste.
/ Echo vs Husqvarna #29
I've never had a Husky saw as a comparison point, but I sure like my Echo CS370 with an 18" bar..
it has plenty of power and is silky smooth. Bear in mind I'm not a professional, but I need a capable saw for occasional pruning or a downed limb.
This model fills the bill just fine.
/ Echo vs Husqvarna #30
Your huskky isn't idling well due to leaking fuel lines. I guarantee you if you replace the lines, it will run much better. I've seen it too many times with my small equipment.
/ Echo vs Husqvarna #31
Never owned a Husky saw, have both Stihl and Echo. Both good says. I'm sure they are all good, just what you like. I think I will buy a small Echo with 14 inch bar and mount on my tractor. I get tired of having to go back to the shop to get saw. I am putting on my tractor and leave it.
/ Echo vs Husqvarna #32
Just be ready for cleanup, all saws leak bar oil.
/ Echo vs Husqvarna #33
IMO Husqvarna, Jonsered, Stihl, Echo are all #1 in quality serviceability etc.
AS LONG as you purchase from a certified dealer and NOT the BOX STORE versions.
All the manufacturers have both 'consumer grade' and 'professional grade' versions.
Just try to get a box store saw serviced and you'll appreciate why, worst still are rebranded (i.e. Sears saw) for parts etc.
/ Echo vs Husqvarna #34
i have a Husqvarna 357XP that does not leak bar oil. I might find a very small bit if I come back the day or two after I set it down, but if I move it to a new spot after that, nothing more comes off the saw. I suspect that initial little bit is just oil that is already on the bar or soaked up in in the sawdust under the clutch cover. Once that has dripped off, I don't see anything further until I run the saw again.
My Jonsered 2152, however, has leaked oil since the day it was new. Leave it sitting anywhere for a day or two, and there's a puddle under it. Move it to a new location, and there is a new puddle. A friend with the same model saw has no leaking problem. I found a YouTube video about fixing a common source of leaking bar oil on the Husqvarna 353 (the twin sister saw to the Jonsered 2152). I believe the parts in question on the two saws are the same. I've been meaning to try it on my 2152, but haven't gotten around to it yet.
/ Echo vs Husqvarna #35
Jonsereds are Husqvarna's in a different color...
They come right down the Husky line in the Husqvarna factory...
Everyone who runs my Jonsered really loves it including me!!
SR
/ Echo vs Husqvarna #36
I have a 357XP and it leaks oil pretty badly. Other than that it's been a great saw. I did replace the oil pump to see if it would help as it has 1000s of hours on it. I got it from a logger who used it to lib with. Until I got my Dolmar it was my go to saw for pretty much everything. Unfortunately it's the older version of the saw with a different style jug and piston and they no longer make parts for it. Someday it's time will come. Until then it lives on an upside down storage cover for a plastic tote.
/ Echo vs Husqvarna #37
The bar oil leak may be a seal or o-ring. Poor idling could be as simple as a carb adjustment.
I have a stihl 025 that is remarkably hard to pull over for a 45cc saw (common for that model). And a MS660 clone that's a beast to pull. The other Stihls start pretty easily.
/ Echo vs Husqvarna #38
Any saw I have ever owned leaked oil, in the summer they leak a lot more because the oil gets thinner, the saws I have, have adjustable oilers, before I put them away I close the oiler..
/ Echo vs Husqvarna #39
I put a piece of cardboard under my saw if I store it someplace where I worry about fluid spills. The only time that I had a really bad oil leak was with my 254 after cutting ice for beaver trapping. We used to run them without oil to keep it out of the water and I ended up ruining the pump.
/ Echo vs Husqvarna #40
I recycled my wife's worn out or rusted baking sheet pans. They go in the saw cabinet under the saws to catch the oil.
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
2018 FORD F-150 (A65643)
2018 FORD F-150...
2024 Bobcat T650 (A64126)
2024 Bobcat T650...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
