Sixteen Dollar Tractor Bridge
/ Sixteen Dollar Tractor Bridge #1
BrokenTrack
Maine
Tractors, Skidders, Bulldozers, Forestry Equipment
I have been redoing an old house that I have, and redid the driveway with gravel and such. It was no big deal, but I wanted a way to get across the new ditch. I thought about a culvert, but they are ugly, and cost money, so I decided to go with a bridge instead.
I admit that it took me 8 hours to build, but in the end it holds up my tractor/truck just fine, and only cost $16.50 for the long spikes I had to buy. Gathering up the logs did not take too long, but sawing the logs into lumber kind of did, taking the most time. But by noon I was starting to build the bridge.
It is 8 feet long, and 12 feet wide, the bridge resting on cedar supports, with the main beams being 5"x10". These I spaced at 5'-6" wide because my tractor has a 5 foot wide wheel base, and my truck has a 6 foot wheel base, so I split the difference. Over that I put down 3"x6" Hemlock planting, with a 2x4 hemlock spanning the outside edges to keep them from flexing. Over that I put 1 inch spruce boards so I know where to drive and have the main beams under me.
Overall, it was a rewarding project that turned out nice (I think anyway). I have used it now almost daily for a few months and have had no issues with it.
So if anyone has a stream or ditch they need to cross, his might be a cheap and easy way to do it.
/ Sixteen Dollar Tractor Bridge #2
Never thought of a culvert as being ugly. LOL
Your bridge looks nice. Do you have any humidity there?
/ Sixteen Dollar Tractor Bridge #3
Culvert ugly?
I wonder how that wood will hold up in a year or two and start coming apart, how will it look?
/ Sixteen Dollar Tractor Bridge #4
Is that the only access to the property? Just thinking down the line if you ever need a septic or fuel truck with a 20000 lb axle.
/ Sixteen Dollar Tractor Bridge #5
thats a 5 yr bridge tops in our weather here - nice job and resourceful
/ Sixteen Dollar Tractor Bridge #6
Looks nice man!
/ Sixteen Dollar Tractor Bridge #7
Cedar base will last (relatively speaking) with moderate weights...... excellent performance, esp. given how little $ you have in it.
Counting your time, of course it's worth more, but most of us don't pay ourselves on projects like this :).
Things I don't like about small dia. culverts:
1) Debris, dead critters etc..... often easily accumulates, sometimes not easy to clear out.....
2) Early Spring Melt - often the culvert is frozen solid, to the top.
Your bridge BT, much like what would have been farm-built years-past, does the job for low dollars, and mostly bypasses the problems I just listed.....
:thumbsup: Rgds, D.
/ Sixteen Dollar Tractor Bridge #8
That will save time getting from point A to B also crossing ditch by foot with items...plus winter use.
/ Sixteen Dollar Tractor Bridge #9
Hey BrokenTrack good day Sir ! I hope you didn't get that handle building $16 tractor bridges . :D I hope it last Ya's (wooden bridge) and serves it temporary purpose ! I really LIKE your TRACTOR :thumbsup: ! However just a question ? What happened to the top part of your ROPS ? Play Safe
/ Sixteen Dollar Tractor Bridge #10
I like that and it is a nice job especially seeing that you sawed out your own lumber. I build stuff out of wood too. Never a bridge yet though but I could use a couple. Wood doesn't last forever but it lasts longer than you would think. These open culverts are good on woods roads because are easy to keep clean.
gg
No, I was clearing land on a mountainside, and went to back up and my left track went zinging back and piled up on my bulldozer blade. I was at the highest point on the mountain of course, and with a 700 John Deere, so it was no small feat to get that tractor fixed. hence the name: BrokenTrack.
But the ROPS did not fit inside my sheep barn! I had to take the ROPS off my bulldozer too, but then, you have to really work hard to flop a bulldozer over!
I have never had to use it though. I did roll the tractor over once, but not enough to flop it on its side. Slowest roll over I ever had. I literally just stepped off the tractor as it laid over. I just hooked on to it with the skidder and put it rubber side down, and I was off running again.
/ Sixteen Dollar Tractor Bridge #13
BrokenTrack thanks for response . Thanks for shareing experience and pic (yikes ) , glad your ok ! :thumbsup:
/ Sixteen Dollar Tractor Bridge #14
here i one i rebuilt two summers ago, i was able to obtain old light poles for material then took them to a sawmill and they make them into 5 inch thick slabs to put down as the floor across the steel beams - this old bridge is on an abandoned road that connects land that used to be my mothers when she was a child and was sold after her parents died, i am fortunate to have gotten to use the land and maintain it for the lady that now owns it for many years - this was very neat for me to get to do as its kind of sentimental and i was able to take my mom down to the old creek/bridge where she used to play as a kid 70 yrs ago - yes we cried and hugged in the middle of the bridge ;-)
15 x 13 feet i believe it was and it was about 12 feet deep in the deepest spot from the bridge to the creek bed.
side view creek bed.jpg side view of creek bed before i started
cleaning old bridge decking and dirt.jpg cleaning dirt and rotted timbers off old deck/beams
cleaned bridge beams.jpg cleaned and ready for new timberts/deck
laying planks.jpg laying new planks
laying treads.jpg installing treads
painted treads.jpg treads painted
graded out.jpg graded out
/ Sixteen Dollar Tractor Bridge #15
With concrete abutments and steel support beams, searcyfarms, you were halfway there! I wish my project was starting from that same point...I need abutments, beams and deck, so a lot more work. Your finished bridge looks really nice.
/ Sixteen Dollar Tractor Bridge #16
LOL, exactly what I thought when I saw his post!
/ Sixteen Dollar Tractor Bridge #17
Using Brokentrack's accounting method, I have zero dollars in this bridge. :)
/ Sixteen Dollar Tractor Bridge #20
Thanks Guys. It was a great family day in late February at the Farm.
2015 Ford Focus Hatchback (A59231)
2015 Ford Focus...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2015 DODGE RAM 3500 4X4 CREW CAB PICKUP TRUCK (A59904)
2015 DODGE RAM...
2016 Ford F-150 Crew Cab Pickup Truck (A59230)
2016 Ford F-150...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
2018 PJ Trailers 14ft T/A End Dump Trailer (A59230)
2018 PJ Trailers...
