Sixteen Dollar Tractor Bridge
   / Sixteen Dollar Tractor Bridge #1
BrokenTrack
Maine
Tractors, Skidders, Bulldozers, Forestry Equipment
I have been redoing an old house that I have, and redid the driveway with gravel and such. It was no big deal, but I wanted a way to get across the new ditch. I thought about a culvert, but they are ugly, and cost money, so I decided to go with a bridge instead.
I admit that it took me 8 hours to build, but in the end it holds up my tractor/truck just fine, and only cost $16.50 for the long spikes I had to buy. Gathering up the logs did not take too long, but sawing the logs into lumber kind of did, taking the most time. But by noon I was starting to build the bridge.
It is 8 feet long, and 12 feet wide, the bridge resting on cedar supports, with the main beams being 5"x10". These I spaced at 5'-6" wide because my tractor has a 5 foot wide wheel base, and my truck has a 6 foot wheel base, so I split the difference. Over that I put down 3"x6" Hemlock planting, with a 2x4 hemlock spanning the outside edges to keep them from flexing. Over that I put 1 inch spruce boards so I know where to drive and have the main beams under me.
Overall, it was a rewarding project that turned out nice (I think anyway). I have used it now almost daily for a few months and have had no issues with it.
So if anyone has a stream or ditch they need to cross, his might be a cheap and easy way to do it.
   / Sixteen Dollar Tractor Bridge #2
Never thought of a culvert as being ugly. LOL
Your bridge looks nice. Do you have any humidity there?
   / Sixteen Dollar Tractor Bridge #3
Culvert ugly?
I wonder how that wood will hold up in a year or two and start coming apart, how will it look?
   / Sixteen Dollar Tractor Bridge #4
Is that the only access to the property? Just thinking down the line if you ever need a septic or fuel truck with a 20000 lb axle.
   / Sixteen Dollar Tractor Bridge #5
thats a 5 yr bridge tops in our weather here - nice job and resourceful
   / Sixteen Dollar Tractor Bridge #6
Looks nice man!
   / Sixteen Dollar Tractor Bridge #7
Cedar base will last (relatively speaking) with moderate weights...... excellent performance, esp. given how little $ you have in it.
Counting your time, of course it's worth more, but most of us don't pay ourselves on projects like this :).
Things I don't like about small dia. culverts:
1) Debris, dead critters etc..... often easily accumulates, sometimes not easy to clear out.....
2) Early Spring Melt - often the culvert is frozen solid, to the top.
Your bridge BT, much like what would have been farm-built years-past, does the job for low dollars, and mostly bypasses the problems I just listed.....
:thumbsup: Rgds, D.
   / Sixteen Dollar Tractor Bridge #8
That will save time getting from point A to B also crossing ditch by foot with items...plus winter use.
   / Sixteen Dollar Tractor Bridge #9
Hey BrokenTrack good day Sir ! I hope you didn't get that handle building $16 tractor bridges . :D I hope it last Ya's (wooden bridge) and serves it temporary purpose ! I really LIKE your TRACTOR :thumbsup: ! However just a question ? What happened to the top part of your ROPS ? Play Safe
   / Sixteen Dollar Tractor Bridge #10
I like that and it is a nice job especially seeing that you sawed out your own lumber. I build stuff out of wood too. Never a bridge yet though but I could use a couple. Wood doesn't last forever but it lasts longer than you would think. These open culverts are good on woods roads because are easy to keep clean.
gg
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
BUYERS PREMIUM & PAYMENT TERMS (A53426)
BUYERS PREMIUM &...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
2020 KENWORTH W900L DAY CAB (A52472)
2020 KENWORTH...
