Utility Trailer Question
/ Utility Trailer Question #31
Clutch adjustment when I switch controls around is a real pain.
Do you mean when you turn the bars around to use a front-mount implement? When I do that on my 732 it always snags the clutch cable on the gear shift linkage, keep meaning to re-route it.
Wide turning radius makes use in the orchard difficult.
I put a spring clamp on the safety switch so I can steer holding one bar at a time - (does that make sense?)
Board for a seat was a lousy idea as I keep sliding around on turns and slopes.
You must have really uneven ground Phil. I've been using the same piece of 1x6 for years.
Keep at it. :thumbsup:
Thanks to all for your advise and pictures. While the utility trailer does work as "advertised", it has proven to be unusable on my rough and hilly acreage. Turns are just too wide and with any load in the trailer (plus me) it cannot climb my hills. I took the coupler off the trailer this morning and put back the original pieces to tow it behind my old TroyBilt mower. What I really need is a Kawasaki Mule or a Polaris Ranger, but those are all out of my price range. Even used ones are too expensive and the only ones I could afford are rust buckets or in need of a motor rebuild. Will just have to make do for now.
Thanks again everyone!
/ Utility Trailer Question #33
Join the club,I have made do for so long it has become habit and I hardly notice any longer. :confused3:
/ Utility Trailer Question #34
As someone who has owned 2 different Polaris Rangers (the first 2x4 was stolen and we bought a 4x4 to replace it), I'd advise anyone to avoid a Polaris. Reason being, the body integrity is crappy plastic that tends to crack wherever a screw goes through it. We contacted Polaris when the cracks in the floorplan started to show up around 7 months into ownership and were told that the warranty was only 6 months. 8500.00 and they wouldn't consider replacing the plastic floor pan that was obviously a design flaw. We swore we would never buy a Polaris again. Also, the clutches have buttons and ramps that wear and are super expensive to replace. I just replaced the secondary clutch myself with a Polaris part and it was nearly 500.00. That doesn't include the primary clutch which costs an additional 600 bucks. Inknow a bunch if people like them, but the next time I buy a UTV it will be a Kawasaki Mule or a Kubota.
Update: I solved my problem by purchasing an ancient Kawasaki Mule 2500. Looks a little rough but runs great and went up and down all my trails with no problems at all :)
/ Utility Trailer Question #36
That sounds a lot nicer than being dragged around by a 2-wheeler :thumbsup:
I'm not familiar with the Mule but it sounds good - 600cc, 2WD?
Sorry for the delay in replying. Kawasaki Mule 2500 is 2WD with a 600cc motor. Really looking forward to spring and using it again.
/ Utility Trailer Question #38
freedomlives,
I am not aware of any powered trailer for the BCS machines, but I will look around. Might be expensive though and I am on a very tight budget.
There are. They require a synchronized PTO and the tractor and trailer must have same size tires.
/ Utility Trailer Question #39
Yes he's sitting on the edge. It's a 3" wide lip, comparable to the comfort of a bicycle seat. It would be very easy to attach a 2x8 to the lip for a more comfortable seat - there's a good 5 inches of flat just around the corner from the front lip and adding a bench wouldn't be an issue. At times I stand on the coupler for extra weight on the drive wheels - might be nice to add a standing platform to that, maybe attach through where the hitch pin is.
It works great on _dry_ hilly uneven land. I can add more articulation if I please, I would have to mill or grind a slot rather than use the clearance in the pin hole.
On a wet hill with a full load, traction is definitely an issue. I've had to get off and push. Wheel weights or engine weights would help.
It's actually very easy to steer with all that leverage on the handle bars too.
What direction are you worried about it tipping over? Sideways I think you'd have a hard time tipping it unless your load is very top heavy. Center of gravity is really low on both the BCS and the trailer. Tipping like BCS wheels off the ground shouldn't happen with the length of the coupler and the weight of the BCS.
I hadn’t thought about standing on the tongue. Thanks for the tip!
KBH Tender Trailer (A56438)
KBH Tender Trailer...
2016 Dodge Grand Caravan Van (A59231)
2016 Dodge Grand...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2022 John Deere 1025R (A53317)
2022 John Deere...
1977 Heil 6,300 Gallon T/A Tanker Trailer (A59230)
1977 Heil 6,300...
2018 FORD F-450 XL SINGLE CAB FLATBED SERVICE TRK (A59823)
2018 FORD F-450 XL...
