Box Blade alternatives to EA?
/ Box Blade alternatives to EA? #41
Here is my first box blade a 4' Brinly from 34 years ago:
And the same one now with the 3pt removed and drilled angle iron added:
/ Box Blade alternatives to EA? #42
Compare weights on BB if you can. BB are usually one of those things you can look at and tell how HD is is from the thickness of the steel etc.
I have a landpride with hyd rippers that is very heavy and well built but, I also have a unknown brand 8 ft'r thats not as well built thats done everything ive wanted it to do that was 1/5 the cost of the landpride.
/ Box Blade alternatives to EA? #43
So since I haven't seen it asked yet: what would be the intended use of this box blade?
I ask as I've recently re-relearned that some of the lighter/cheaper ones do actually have their usefulness (for example: spreading, or gathering already loose material) -- if it's of quality construction, and was built to roll the material (with appropriate curves/bends to do so). The weight per foot really becomes more of a consideration for use where the material being moved isn't already loose, and the box blade will need to loosen as well as roll the material.
Box blade stuff, I guess.
Regrading parts of my mature lawn once I install new drainage, fixing neighbor's gravel and dirt driveways, whatever else I can think of.
/ Box Blade alternatives to EA? #45
In that case I'd agree he recommendations of going with a heavy, well built one are right on.... and the only brands I haven't seen already mentioned are:
Monroe Tufline Tufline | Well Built, Performance Driven Implements
Titan Implements Titan Products
and the King Kutter models that Rural King offers
Implements | Box Blades | RK Tractors
The latter two look to be a slightly lighter than I'd personally like, but I'm also have to deal with a relatively high clay content loam (so considering getting a heavier-per-width EA floating gate box blade). However, I'd think all three are worth considering along with the other brands mentioned. Just for clarity the only box blade I've used is the 6ft EA Category I & II Severe XTreme Duty Tractor Box Blade - Everything Attachments ...which has worked well enough that their wait times are understandable (as well as their moving to a larger production facility).
..and just to muddy the water a bit if the regrading of the lawn won't involve more than back-filling trenches, it might be possible to do by back-dragging with the bucket -- which would open the options up to include either a land plane (optimized for fixing roadways) or rear scrape blade (which works well where spilling around the ends isn't an issue -- or is actually desired).
Personally I tend to appreciate the utility of a heavy scrape blade as that's what was primarily used by my grandfather to maintain the family road back in Minnesota. Whether it was removing snow, or re-grading the sand/rock/gravel to eliminate washboarding, and reshape/reclaim material from the shoulder the scrape blade he had was got used to good effect. However, when it comes to ripping up stuff (to include vegetation) and dragging dirt from one spot to another it's hard to beat a box blade as a single 3pt implement.
I'd have ordered the EA box blade by now if he wasn't on a 12 week wait (and that's a maybe according to whomever I talked to there)
/ Box Blade alternatives to EA? #47
Just bought a CK4010 HST (came with a loader, backhoe and rotary butter) and a Box Blade is my first needed implement. I called EA and they're 10-12 weeks lead time on anything they sell so I'm looking for suggestions on alternative brands. I'm looking for a fixed tailgate unit, 72". I want something quality so not really looking at the Tractor Supply type brands unless there is one you'd recommend.
Thanks in advance.
Last Summer I was going to buy some equipment from them and they were 6-10 weeks out from being able to process my order as well. Sorry to hear they are even further out now. Not sure how a small operation stays going with times like that. I ended up buying a Land Pride box blade also and it was extremely well built. I've had an EA box blade and grapple in the past and they were excellent. But when you need an attachment, there aren't a whole lot of people out there who can wait 2-3 months for it. When you need it, you need now.
/ Box Blade alternatives to EA? #48
We stay going because of increasing demand and we stay behind because demand has grown faster than our ability to build the product...
This was written by Ted a couple of months ago and posted in the Everything Attachments Channel group.
Good morning to all the EA group. I just wanted to share a little bit about how lead times are working...
I know this is a painful subject but needs to be addressed. Growing pains are real and they hurt both of us. We lose orders and our valued customers are not getting what they need when they need it. There was a day a few years ago when we had a pile of attachments and just hoped we could build the EA brand up to sell them. I will never cut corners to be able to keep up production or make it easy to build. I have been using every attachment we build from many of the best brands from the time my dad would let me on a tractor. Besides the lawn mower when I was about 6 years old, my first start was on a YM135 Yanmar in 1972. I was 8 and loved it. Through the years, I destroyed many attachments and 3 point hitch parts at my dads expense. Now, it is my goal to build the best attachments on the planet so you guys don't have to worry about destroying them. This does not mean they cant be bent or destroyed if not used correctly, but we engineer them to have the best design for the intended use. It is our intention to make them out perform all others and be as affordable as possible.
The sad thing is... We have the equipment and just paid for the old factory we were leasing that is just sitting full of lasers and every thing needed to do twice as much, BUT WHERE DO WE FIND GOOD SKILLED WORKERS THAT WILL WORK. ?? There is little room to train a worker to make YOUR attachments to our standards. It seems no one these days wants to work. We are constantly hiring at Everything Attachments, but between people that can't do the job and won't come to work, that is our biggest challenge. We start no one below 15 dollars per hour and most make 20 plus plus.
I LOVE MADE IN THE USA, BUT IT IS A REAL CHALLENGE. MY GOAL IS TO SAY IT WILL SHIP IN LESS THAN 3 DAYS. We will not quit till we get there. I have been working harder than ever in my life to 6 AM till 4 or 5 PM then go home a think the rest of my day on how to fix this great problem. Thanks to all of our awesome EA CUSTOMERS!!!
Ted Corriher.
How it begins...
Flip any box blade over and compare it to this. Check out the triangular bracing, horseshoe plates of steel under the tube and plate added to the leading edge for wear resistance.
The best USA tubes are laser cut and welded by people inside our factory.
Very strong ripper shank attachment points. It isn't as cheap or easy as most others, but it is stronger.
Welded hitch is also more expensive to make, handle and ship for us, but no corners are cut.
Strong, solid, continuous welds. This is art.
We build them and we use them.
Another big reason for our being behind. Around 300 people are in line for a Wicked Root Rake Grapple at any given moment.
I hope this helps to explain the situation we're dealing with. We understand if you can't wait, but, all the time, people tell us that the wait was well worth it.
Travis
/ Box Blade alternatives to EA? #49
In EA,s defense its NOT JUST THEM I waited 7 weeks for my woods box blade.Reel it in a notch and know what your talking about before you post..
/ Box Blade alternatives to EA? #50
I can't quite understand why the immediate need for a box blade.
Poor planning on the part of the buyer?
EA stuff is SO well made,....... it is definitely worth waiting for.
/ Box Blade alternatives to EA? #51
Ted Corriher.
How it begins...
Travis
AMEN..I work as a contractor for the local power company to check out new construction job sites for new homes to install power.I hear the SAME THING from local contractors WE can"t find anyone who wants to work.Mind boggling to say the least
Ted Corriher.
How it begins...
Travis
I think everyone understands the logistics. Most of us are venting due to plans that probably were created without enough forethought. Like the man once said... "Lack of planning on my part doesn't constitute an emergency on yours"
Growing pains in business is a common theme. I've been through it and EA is in the midst of it now. Sometimes, it might make more sense to outsource labor or move the business to an area with better hiring prospects.
I hope you guys can get it worked out. This is something that can kill a business. Best wishes.
/ Box Blade alternatives to EA? #53
And where would outsource labor to China,Mexico? I like that Idea EA,s keeps there products here in the USA..
And where would outsource labor to? China,Mexico? I like the EA,s keeps there products here in the USA..
Well..he was using someone in the US to cut the steel previously. Maybe continue to use them?
Additionally, I'd recommend putting a notice on their website explaining the backlog. It's such a long lead time that some will be surprised (as I was). Communication is key.
/ Box Blade alternatives to EA? #55
People lining up to buy your stuff & willing to wait for longer lead times is rarely a bad sign on the selling end of things. Might be a manufacturing bottleneck. All things considered I'd rather have people waiting to buy my stuff than not having anybody to buy it.
/ Box Blade alternatives to EA? #56
I think if you read EA,s post above it explains the delay pretty well.I was not surprised by there delays with some of the today Millennials who are flat azz lazy and don"t want to work.Makes it very Hard to run a business.
/ Box Blade alternatives to EA? #57
Do not over look the used market. Have a brother in law who was almost given a Gannon (price was very low) as the owner no longer had need for it. Great blade. Light weight is really for light work. It takes weight and the right angle to cut dirt.
/ Box Blade alternatives to EA? #58
We have the best tools to cut the steel and a long string of Miller welders to melt it together. The move to our new facility and a big holdup with our paint booth really caused a bottleneck and we're slowly digging out of it. Slowly is the keyword, but it isn't from a lack of effort. I sat back and this thread kept eating at me, so I wanted to provide you guys with an explanation.
Here is the newest addition. This laser is the reason we do not have to outsource tube cutting anymore. When I say outsource, we were ordering USA tubes from a USA company. All of the tubes were already laser cut to the needed length with all of the necessary holes/tabs in place. Now, we can efficiently do it in house. This thing can really keep the round and square tube components stocked.
Travis
It even etches the tubes for precision placement of our drum style plugger spoon holders.
/ Box Blade alternatives to EA? #59
Travis
OUTSTANDING great pics.Thanks to EA for keeping america working..
Been looking at used for a while now...2 months before I even found a tractor. It's mostly TSC junk with people asking 85% of new list. No thanks.
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2003 CLUB CAR ELECTRIC GOLF CART (A63745)
2003 CLUB CAR...
2009 Peterbilt 367 Flat Bed (A64047)
2009 Peterbilt 367...
2017 Ford Transit 250 Cargo Van (A61573)
2017 Ford Transit...
2024 John Deere 6130M Tractor Loader (A63109)
2024 John Deere...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63118)
2004 Cadillac...
