civilian
- Joined
- Oct 3, 2015
- Messages
- 2,167
- Location
- Vanderbilt, MI
- Tractor
- Gravely Pro 16 walk behind, Kubota BX2230, Kubota B26TLB
I'm not sure if you have Costco in the NE, and even if you do you may have missed the annual supply of portable garages, but theirs is fairly high quality, cheap ($250-ish?), 10x20, and does indeed open in the middle. You could load from either end and the middle.
Would you blow snow off regularly to keep it from collapsing under the weight? For a less labor intensive long-term solution, some of the admittedly more initially expensive ideas in this thread may be useful. But Costco has what you want if you still want it.
I have something similar to the ShelterLogic type, but the pitch is much flatter, like 1ft in 12 ft. 10ft span between posts and rafters.(all 1" galvanized conduit.) I added 3/4" pvc pipe between top plates and bowed them up to the ridge pipe. This puffs the tarp up. Helps with rain and some light snow in northern Michigan. BUT I do clean the snow off on a regular basis in the winter. This covers my wood pile. Jon
