Tent Storage Structure for Attachments
/ Tent Storage Structure for Attachments #21
I'm not sure if you have Costco in the NE, and even if you do you may have missed the annual supply of portable garages, but theirs is fairly high quality, cheap ($250-ish?), 10x20, and does indeed open in the middle. You could load from either end and the middle.
Would you blow snow off regularly to keep it from collapsing under the weight? For a less labor intensive long-term solution, some of the admittedly more initially expensive ideas in this thread may be useful. But Costco has what you want if you still want it.
I have something similar to the ShelterLogic type, but the pitch is much flatter, like 1ft in 12 ft. 10ft span between posts and rafters.(all 1" galvanized conduit.) I added 3/4" pvc pipe between top plates and bowed them up to the ridge pipe. This puffs the tarp up. Helps with rain and some light snow in northern Michigan. BUT I do clean the snow off on a regular basis in the winter. This covers my wood pile. Jon
/ Tent Storage Structure for Attachments #22
Wow. I wish I had something. But all my implements sit on the ground or on 4x4 wood blocks, scattered all around my property (finding somewhat level ground out of the way is near impossible on my property). Remembering what I did with the rototiller is half the challenge of hooking up to it. :laughing:
Seriously though, I am leveling off the 'shop area' and will have all the implements lined up in neat rows... still out in the open.
But I am watching this thread now.
/ Tent Storage Structure for Attachments #23
Attachments cost to much to just sit out in the weather. I figure any type shelter would be better than nothing. My Shelter-Logic vinyl covering should last 3-5 years and then I can either replace the covering or cover with metal roofing.
While you are building the Shop pad, level off 2-3 times more area than you think you will need. Useable flat areas are more important than you think.
/ Tent Storage Structure for Attachments #24
Cover it with a tarp when you set it up. Then just replace the tarp as needed. UV on the ShelterLogic (and all other brands) fabric destroys it rapidly. 3-5 years MAY happen in Alaska, it sure won't here in the California desert.
/ Tent Storage Structure for Attachments #25
we built this in a couple of days for a couple thousand in materials
/ Tent Storage Structure for Attachments #26
Very nice. Looks to be the perfect size. Lumber prices in Alaska are so outrageous that you can't afford to build anything. Our local sawmill closed its doors a few years ago so the nearest mill is 130 miles away.
/ Tent Storage Structure for Attachments #27
If you have the time, can you find an old small building that you can tear down for the free lumber?
I did that years ago, and built myself a loafing shed very similar (not as classy looking) to the one by "cathy liebchen".
20' x 40' = my free time, the cost of a 7-1/2" carbide saw blade + new nails.
/ Tent Storage Structure for Attachments #28
I did that years ago, and built myself a loafing shed very similar to the one by "cathy liebchen".
That is a great idea, just about 10 years to late. Getting just to old and decrepit for that kind of project. I could probably still construct a small pole frame shed and metal side it though. The Wife wants the firewood under a roof now too. Go figure.
/ Tent Storage Structure for Attachments #29
Not the best picture, though this picture shows the canopy I was describing above. It is 20 ft long, approx 14 ft wide. I used a 20 ft x 20ft tarp. You can make out the extra pvc pipe puffing out the tarp between the posts. Side posts were only 5 ft tall and the center post maybe 8ft.
Jon
/ Tent Storage Structure for Attachments #30
/ Tent Storage Structure for Attachments #31
Around here, you can get a open sided 18x20 carport installed for $1,425. Add a few hundred dollars for a heavier fame and an extra foot of height. I think their service area ends just short of NH.
Metal Carports, Garages, Sheds, Barns & More | American Steel Carports
That is what I am considering. I get the frame and roof for an 18x31 with 9' height for $2500 installed on my pad. Likely pour an 18x6 pad for the attachments and stone for the rest of the pad. Thinking about adding some tarps for temporary sidewalls. I can add wood or steel sides and doors as I get more funds or as needs dictate down the road. It will be perfect for storing attachments and firewood.
/ Tent Storage Structure for Attachments #32
The carport looks to be a great idea and will meet your needs perfectly. Make sure to have a roof rake to keep the snow off.
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
2013 FREIGHTLINER M2 112 S/A 4X2 DAY CAB TRUCK TRACTOR (A59910)
2013 FREIGHTLINER...
UNUSED RAYTREE RMT48-48" HYD TRENCHER (A62131)
UNUSED RAYTREE...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
John Deere Z960M Zero Turn Mower (A64047)
John Deere Z960M...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
