Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #6,081
Looks like your typical Alamo SH88.
/ Let's talk flail mowers #6,082
My new Caroni TM1900 arrived on Tuesday, 1 day ahead of schedule from Agri Supply, but I was not able to bring it home until Saturday. I was not able to lift it out of the back of my pickup with my tractor (I could have, with some finagling if I had put some ballast on), so I called my neighbor and he came over with his 50HP TYM and forks.
He's retired road crew and was very interested in the mower - he used boom mounted flails to trim road sides. He just wouldn't leave - made me get it off the pallet, set up on the tractor, and when the PTO shaft was too long took me back to his place so we could cut it down. Helped me adjust the skid shoes, took off the scraper blade and lowered the roller too. Also topped up the gearbox even though the level was acceptable, at the low end of the range.
So far (a short half hour or so test session) I am totally amazed. This mower has much lower HP requirements than my old RFM. I was mowing thicker/taller grass than I would have ever dreamed of with my RFM, and this mower is a foot wider, and I was able to maintain faster speed (as fast as comfortable on my no-quite-golf-course terrain) except for maybe two small areas where it was super thick.
Link to short video:
https://scontent-lga3-1.xx.fbcdn.ne...=cbad9b53c3548613ff5d457bace41994&oe=5DB7192C
One quick question: he suggested leaving the roller 1" higher than the skid shoes. However I am getting lots of torn sod in the corners, I assume that lowering the roller would help and that would be the normal recommended position (roller and shoes at the same height). I did not find any manual with the mower.
/ Let's talk flail mowers #6,083
Alamo Industries flail mower/Reggio Retail Group as far as I can tell.
/ Let's talk flail mowers #6,084
2040 Reggio Rey Italy as far as I can make out
G 94 may well be the plant(G) and the build year(1994)
Alamo industrial has several plants in the European Union and headquarters in Great Britain/England
/ Let's talk flail mowers #6,085
Hello and good morning dnw64,
I want to welcome you as the newest resident member of the "Flail Mower Nations) from the Great State of Vermont.
Your neighbor means that the roller needs to be one position lower(creating a higher cutting height) than the skid shoes.
The torn sod is a result of the side weldments digging into the ground as you turn while the Flail Mower is in the float position
The skid shoes are there to protect the flail mower rotor, flail mower knives and each mounting station from impact damage
in the event the mower tilts forward with no top link control i.e. if a length of logging chain is used to allow it to follow the contour
of the ground closer.
Now;
You need to make sure that the gearbox is level on the three point hitch so if you have a small bubble level or torpedo level you can
be sure that the flail mower is level from front to back by adjusting the top link in or out.
About greasing; You have to be careful to not over grease it as it will blow out the inner seal and
you do not want that to happen ever.
Four or five pumps of grease every eight hours of continuous mowing in the Flail Mower Rotor Bearings and
five pumps of grease in the Flail Mower Rear Roller bearings every 8 hours of mowing.
You will need to remove the V belt guard to look at the V belts and brush away any rubber dust, grass dust and wipe up any grease
to keep it from building up on the side weldment.
Please make sure that there is a grease fitting on the snubber pulley as I believe it has a bronze bushing/bearing-I have not looked at the manual for a long time so I am going by memory here. If you cannot find a grease fitting on the back side or on the front of the pulley it has a sealed bearing.
Use a good flash light to check for any grease fittings.
The left Flail Mower Rotor Bearing can be greased while the guard is on the mower from what I remember of it.
The Flail Mower Rotor Bearing on the right side of the Flail Mower has a guard protecting the grease fitting so you have to do a little
maneuvering to get the grease gun hose on the fitting.
As far as the V belts go you only have to worry about them if they burn up or start slipping and screeching as by that time you
will have almost surely caused the rubber to become glazed.
As long as the Flail mower sounds like a high end vacuum cleaner/shop vacuum it is creating the pressure gradient(suction) to provide enough lift
to lift the clippings over the flail mower rotor and back down to the ground.
You will be able to make a second pass and recut the clippings once more if you wish and they will dissolve more quickly into the sod.
Call Agrisupply on Monday and ask for Rodney Barbour and tell him you did not receive a an owners manual/parts manual for your mower in the crating.
Have the serial number/information on the identification plate in your hands when you call to
avoid all the issues with identifying it in detail. Make several good copies of it to have on file and in the mules tool box if it has one.
You could download the manual it but its better to have the original manual for it as it avoids any potential
issues with the diagrams not being complete and legible.
Happy Mowing.
/ Let's talk flail mowers #6,086
That is my tentative conclusion as well. Alamo archives manuals and sent me PDF copies covering the most likely model(s.) Best I can home in on is around a 1994 SHD88.
The 88 being inches cutting width, I measured inner wall to inner wall and that is 90" and with a 1" margin on each side that fits with a 88" mowing width.
Leonz also says "Alamo Industries flail mower/Reggio Retail Group as far as I can tell." That probably fits in that the word "Italy" is one of the few plain things on the scratched up nameplate. Reggio being in Italy ? MATTER OF FACT, now that you mention Reggio, I can make out Reggio on the nameplate on the same line just prior to "Italy." There are a few letters between Reggio and Italy but I cannot make them out. (image on my post #6080.)
Anyway probably a Reggio Group Alamo model SHD-88 until proven otherwise.
/ Let's talk flail mowers #6,087
Now;
Is this just to make sure the gear oil level is proper?
The closest thing I have to level ground is the road in front of my house, if the mower is supposed to be level other than for gear oil checks, I have no idea how that can be achieved since the tractor holding it will never be level. If it is only supposed to be level fore and aft, I guess setting it with the tractor on a slight side slope that doesn't have much front/rear pitch would work.
Thanks
/ Let's talk flail mowers #6,088
The flail mower should be resting on the rear roller, with the skid shoes off the ground slightly, but parallel to the ground beneath them. This is for best cutting. Ideally, the gearbox would be level when you have the top link adjusted to make the skid shoes level to the ground.
As for gearbox oil level, they really should be anywhere from a quarter to a half full, or oil running out of the check plug on the side. Mine has a self-venting pressure fill cap, so if the oil gets really hot it can escape. Some certainly has escaped, my gearbox was almost dry. I was in the field and the only thing I had was chainsaw bar oil. I filled it back to about a third full and it seems to be fine.
/ Let's talk flail mowers #6,089
Couple questions
Curious if anyone can recommend sources for blades and how many blades I should buy to handle our pasture/field grass?
I have two working machines both are Mott. One is a five foot Mott PTO drive and the second is a self powered 4 foot Mott. All of the blades are needing replacement.
Is this project likely to take a full day?
Thanks
/ Let's talk flail mowers #6,090
Couple questions
Thanks
Flail Master - Your BEST Choice for Quality Mower PartsFlail Master | Your BEST Choice for Quality Mower Parts
Depends on if you have fine or course cut mowers.
/ Let's talk flail mowers #6,092
/ Let's talk flail mowers #6,093
Thanks
I have 32 blades stations on my tow behind, 2 blades per station. Took me roughly 2.5 hr to remove>double side sharpen>re mount them. Just swapping sides or replacing will likely take me an hour, now that I know what I am against. I'll just get it up on my scissor lift so I have better access from underneath, instead of laying on the side.
/ Let's talk flail mowers #6,094
Couple questions
Thanks
Flail Master - Your BEST Choice for Quality Mower PartsFlail Master | Your BEST Choice for Quality Mower Parts their website sucks. Have to find & download their catalog or just call them up. They are the best source for good & economical flail parts though.
It took me an afternoon to do my Ford 917. Likely a similar undertaking on others.
/ Let's talk flail mowers #6,095
Couple questions
Thanks
Alamo and the third-party manuals people are pretty good about explanatory photos and drawings. On my SHB-88 Alamo the manuals show what the flail knives are like for smooth cut, for coarse cut and then for the heavy cast iron wood cutter knives. Takes time, just study the manuals and it becomes obvious what you have. Not familiar with the self-powered unit but your 5 ft Mott should be VERY much like a comparable Alamo.
If you pull off a couple of the knives on your cutter and go in to the dealer who sells and services them (often for the State Road people) you can compare,match them up and discuss.
For example in north central WV a Deere dealer sells parts for Alamo cutters and has many parts in stock. Seems like Flailmaster is the dominant source via web or phone orders, they are very responsive by phone and you can Google them and find their catalog on-line.
If ALL the flails really need replacement you are in for several hours work but not a whole day. Get the thing up where you can get at the cutters easily and just refine your remove/replace routine to minimize lost motion.
/ Let's talk flail mowers #6,096
Thanks everyone for the great help. I did call the flail vendor and he also had not ever heard of a Mott tow behind self powered unit with a adjustable height link and shocks on both sides. I described our grassy terrain and he identified that I needed fine cut blades to cut field grass. I ordered enough new blades, cotter pics etc for both machines to have all new blades. I plan on hiring teens to work with me to replace all of these blades. I thought elevating the flails so that we can quickly remove the old blades and install the new ones. I tried to use these old blades for one more season. I should have replaced them along time ago. thanks again
/ Let's talk flail mowers #6,097
If you have course cut units and you ordered fine cut blades you will not mow very well. There will be gaps between the blades. The course cut blades cover about 2"+ and the fine cut only cover about 1". Unless, that is, you replace your course cut blades with the scoop blades.
Course cut and fine cut mowers look the same on the outside until you look underneath. The course cut and fine cut use a different rotor, hence the gap if you use the wrong blades.
If you have fine cut mower then you need to make sure you get the correct fine cut blades, because there are 2 ways to mount the blades and 2 different blade lengths based on the mounting style. Both fine cut blades use the same rotor, just different mounting styles. If your grass gets longer before you cut I'd recommend the shorter blades with the link and hangers for mounting. If you keep the grass short I would use the longer blades that mount with only a pin.
/ Let's talk flail mowers #6,098
@dnw64 Congrats on the new Caroni. I also got one recently - same model. I ordered it in Feb and it arrived in late May. I've used it for about 4 hours of cutting so far and I am amazed. I've got hilly, rocky fields and it cuts really well. But I did manage to break 2 of the clevis and lost those blades due to hitting rocks. Luckily, I had orders some spares with the new unit, so I swapped them in. At the suggestions I read here, I went ahead and called Flailmaster. JD is sending me a sample set of blades and clevis since they don't have a model explicitly listed for the Caroni. But the suggestion I'd read here a while back was M-100761 Clevis and M-108381 Blades. I should get the sample set in a few days, I'll make sure they fit and then order a full set to replace the factory parts. I have a feeling I'm going to go through a fair amount of these - at least until I figure out where all the nasty rocks are.
BTW, I agree with others - the roller should be lower than the skids. The decks rolls on the roller and the skips only tough when the ground is uneven.
/ Let's talk flail mowers #6,100
@dnw64 Congrats on the new Caroni. I also got one recently - same model. I ordered it in Feb and it arrived in late May.But I did manage to break 2 of the clevis and lost those blades due to hitting rocks. ... at least until I figure out where all the nasty rocks are.
I use both a big old (believed to be Alamo SHD88) flail and a Bush Hog 7ft rotary cutter. Experience so far with the flail is that I learned to stay away from rocks and limbs and woody stuff more than an inch or so thick. The big old Bush Hog will sometime eat up and spit out a head sized rock or a 3" thick limb I ran over without intent. Never hit anything that ever disabled it. The flail is far more fragile than the hog (even though the flail is a heavily made and very solid old machine.) Sometimes you get away with rocks here and there. Sometimes you hit a 2 or 3 inch limb and grit your teeth and get away with it. But if you try that very much you are going to be off to the side repairing the flail mower. Mine is a coarse cut model using so-called heavy duty flails. Does a good job but you just need to avoid rock and limbs using it -- Ones that you could just ignore or not worry about using the hog.
2018 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2018 CATERPILLAR...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
