Bin forks?
/ Bin forks? #1
ottawarob
Ottawa, Ontario
BCS, MF 1540
My local TCS has some Agri Ease 3 point "bin forks" on sale. Are these basically pallet forks?
The price is good, I'd love to get a set of 3 point pallet forks, I have this idea of putting a lot of heavy stuff on pallets so I can move it around easier.
Braber Equipment - 2 LB Bin Fork
/ Bin forks? #2
They look like pallet forks to me. Since the tine spacing is fixed you'd want to make sure that they'll fit your pallets.
/ Bin forks? #8
Interesting, definitely looks like the same thing. Just wanted to make sure a bin fork wasn't substantially a different thing. I do notice there isn't much of a back stop for them.
The only issue I see with the AgriEase ones is the pinch point where the top link fastens. If you lift high, your top link may bind as it hits underneath.
/ Bin forks? #10
I had a set of round bale forks I cut down from 48" to 40" for the back of my 22hp Yanmar which didn't have a front loader. Moved all kinds of stuff over the years on pallets, move lots of logs, even built a ramp to back up to a log deck to in feed my sawmill. While a FEL is way more handy, if you don't have one, these are great pc of equipment to own.
Still use them from time to time to move something heavier than my FEL forks are capable of handing.....that photo of the tote above is a good example. Filled with water, it would be more than my loader would handle easily, but those rear forks would have no problem.
/ Bin forks?
I'm pretty jazzed for this very reason! Generally it seems like a pretty cool way to move heavy stuff around. I have a BCS walk behind, each implement is between 100 and 250 pounds, real nuisance to move around. I plan to make a skid for each, and some other stuff for easy moving.
/ Bin forks? #13
Understand.
Don't be put off by the length on these either....as I said, I cut mine down from 48". Brother-in-law bought one for back of his tractor and left them 48".....I'd watch him trying to pick up pallets, and looked a LOT more awkward with the 48" length. Since the "angle of attack" is sorta fixed by the top link, that extra 8" gave him trouble. Hard to explain, but once you see what I talking about, it becomes obvious....the shorter forks are simply easier to work with.
Also, since you don't have an easy way, short of loosening the top link after you get a pallet on, you have to watch how much you pick up the rear lift....if you pull the handle all the way up, the pallet will be at a steep angle, like 30-40degrees to the ground, as you have no leveling control like with a front loader. You get a front loader, it's like you went to heaven.....but in the mean time, these forks are a great way to go.
One other thing....if you plan to build your own pallets, use 6" 'runners' instead of 3-4" that standard pallets use.....LOT easier to hit that taller opening between deck boards while looking over your shoulder.
/ Bin forks?
Understand.
This is all super helpful info, thanks TnAndy! :)
/ Bin forks?
Have one on order, will post up impressions when I get it. Hoping to get a hydraulic top link soon, to help with tilting the load on the fly (and for box blade goodness too).
/ Bin forks? #16
That makes a huge difference, I made one from a regular cylinder and it makes it much easier to pick up pallets and not make a mess.
Aaron Z
/ Bin forks?
Can't wait to get both of these, I was thinking I can probably make a reasonable ballast box that slides onto the forks. Looks like I might be waiting for a while from TSC for them. 4 days in and their order state hasn't moved. :/
/ Bin forks?
I finally got the forks. They are indeed what I was looking for! Used them for one or two jobs, working great.
2024 Schulte 5026 Batwing Rotary Cutter (A63118)
2024 Schulte 5026...
FORKLIFT (A56857)
FORKLIFT (A56857)
CUSHMAN REFRESHER GAS GOLF CART (A63276)
CUSHMAN REFRESHER...
UNUSED RAYTREE RMBD72S - 72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
UNUSED WOLVERINE QC5-26-2DG QUICK ATTACH (A62131)
UNUSED WOLVERINE...
KUBOTA BX2360 TRACTOR (A62130)
KUBOTA BX2360...
