SSQ Bucket falls off
/ SSQ Bucket falls off #1
Atchuuu
Gold Member
Kubota L4330 HSTC
The SSQA bucket on my Kubota wont stay on when I put any back pressure on the bucket. The bucket doesn't appear to be bent or damaged. The loader arms don't look damaged.
I'm thinking that the metal slot the locking rod goes into is bent some OR the locking rod is sliding up under pressure and popping out of the slot. Anyone experience this issue. Any recommendations?
Here are a couple of photos of the bucket.
/ SSQ Bucket falls off #2
Does your pin go fully into the slot beyond the beveled end when the bucket is mounted? On my MX 5200 I have had the bucket pins not seat properly because there was a tiny bit of dirt some where that kept the loader frame from fully engaging the bucket. Your pictures do not show what lies underneath the top piece above the pin slot? Is your bucket or loader portion of SSQA warped in any way? It probably is something very simple that is keeping all of the pieces from seating properly..W.Jones
The pins do not go in all the way. The pins are tapered at the end and go only part of the way into the tab/slot shown above. I don't think they can go in any further. I don't really know if the SSQA bracket can go into the top of slot or not.
/ SSQ Bucket falls off #4
I have had to jump up and down in the bucket to get it to go up against the quick attach all the way. It will act like it’s on all the way but the pins don’t go down all the way. I do it as habit when I swap from the hay spear to the bucket and it always latches correctly.
I'm starting to wonder if maybe I greased the pins too much. They were hard to operate originally but I never had a problem with the bucket falling off. Today it happened 7 or 8 times. Thinking that maybe the pins are too free to move and partially backing out. I will have to try anchoring the handles next time to see if that solve the issue.
/ SSQ Bucket falls off #6
When the handles go down it puts spring pressure over center on the pins. Grease shouldn’t make them pop back up unless the are not locked down all of the way. Can you post pictures of the quick attach hooked to the bucket. It looks like the pins aren’t latching down all the way. The circle part of the pin should almost be at top of the bottom plate so there would be alittle or any wiggle room. The taped part of the shaft should stick out below the plate about an in or more. From the first pictures you posted it looks like the pins are going in their hole alittle or they are hitting the plate instead of going in the hole. If the last is the case, hopping on the bucket lip or lifting the bucket with a load of dirt in it would help to get the pins seated.
/ SSQ Bucket falls off #7
Show us a picture of the bucket mounted like this. There should be no gap where the 3 arrows are especially between the tapered part of the pin and the bucket catch and between the slanted part of the SSQA plate and the bucket catch. Grease shouldn't hurt unless it is full ot trash it picked up.
gg
/ SSQ Bucket falls off #8
sounds like the pins are not going in far enough to get past the hole and are sitting/riding on the back edge of the slot/taper portion of the pin so they will pop right out in that case - had this on my skidsteer quite a few times over the years, in my case each and every time, there was dirt somewhere that was keeping it from getting into position whether in the pin slot, pin lock arm binding pin, pin slot on QA, dirt up under the top lip of bucket, plenty of places to look for dirt ;-)
/ SSQ Bucket falls off #9
It should make no difference how much grease is on anything. The linkages should go over top-dead-center when you flip them the whole way. That alone should not allow anything to push the pins back up.
/ SSQ Bucket falls off #10
The slots where the QA pins seat look like there is some wear or something different about the rest of the slot. I am wondering if that area is starting to show taper wear and when you put down pressure on the bucket it is allowing the pins to wedge out.
/ SSQ Bucket falls off #11
Are you locking the lock arms all the way down? Make sure they are full down.
It is easy to check if the pins are fully engaged. If they aren't going in enough, put the bucket in full dump then engage the bucket blade in the ground and put pressure on it. This will ensure that the flanges are fully engaged and allow the pins to go fully in. IF they still dont fully engage, you may have to take a rotary file or other tool to enlarge the slot on the bucket somewhat so the pin will drop in without any issue.
/ SSQ Bucket falls off #12
It sure sounds like you don't have the levers pushed down to cam them into locked position.
/ SSQ Bucket falls off #13
Are you locking the lock arms all the way down? Make sure they are full down . .It is easy to check if the pins are fully engaged. If they aren't going in enough, put the bucket in full dump then engage the bucket blade in the ground and put pressure on it. This will ensure that the flanges are fully engaged and allow the pins to go fully in. IF they still dont fully engage, you may have to take a rotary file or other tool to enlarge the slot on the bucket somewhat so the pin will drop in without any issue.
Great answer Gary . . . OP needs to make sure those pins are fully seated.
/ SSQ Bucket falls off #14
another thing that can happen if you are pushing down relatively flat backgrading or with larger rocks/debris i have had things push up on one of the pins enough to disengage them also
/ SSQ Bucket falls off #15
Looks to me like that bucket is worn out where the SSQA wedge is sopossed to hold it.
Once you verify you SSQA pin, spring and lever operation, you are going to need to repair that bucket or your problem will persist.
/ SSQ Bucket falls off #16
You're seeing something I don't see when it comes to bucket worn out and repair required!
/ SSQ Bucket falls off #17
If you zoom in on the first pic, it looks to me like the area where the wedge holds is rusted, slightly bent and worn down.
I could be wrong though....
/ SSQ Bucket falls off #18
Gordon's pic is an excellent example of a properly fitting bucket. His arrow to the right is pointing out a critical area. Hopefully the OP will follow Gordon's lead and post a similar pic.
/ SSQ Bucket falls off #19
Not only does the pin have to be in the pocket, the lever has to have spring tension adjusted so it (the lever) goes over center and stays there, as been suggested several times. The bucket has to be snug against the quick attach plate or the pin will not be in the correct position (all the way down).
Arms are locked all the way. I confirmed this. Your suggestion about putting the bucket in the ground is an excellent one. I had to do this yesterday on a couple of occasions.
Don't disagree with you. It would seem that way but they are in full down position. Where the pin connects to the lever is as low as it will go on both sides so this isn't the issue.
Bucket fell off 7 times today. Nothing is hitting the pins and pushing them up. In fact, the pins are still in the down position when the bucket falls off.
You might be right. I am now thinking that maybe the top wedge is allowing forward movement of the SSQA plates. The forward movement might allow the lock pins to pop up, out of the slot.
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2018 Ford Explorer SUV (A64557)
2018 Ford Explorer...
John Deere 825I (A64127)
John Deere 825I...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2007 DRAGON 150...
