New Construction HVAC decisions. Geothermal vs. alternatives with upgraded envelope.
/ New Construction HVAC decisions. Geothermal vs. alternatives with upgraded envelope. #102
Yeah, cheap residential .. So you are getting a duct board and flex system, which is the cheapest you can get.
Sure hope none of it is in a crawl space or attic. I also hope they are good at putting that duct board together, or it will all fall apart in a few yrs.
Went to a guy's house last week. He called me complaining he doesn't get very good air flow .
Checked out his duct board and flex system and showed him where the duct board trunk line was coming apart at the seams, and air escaping into his basement.. His basement was warm though !
Heck, If you have the room. I would have them go with round metal pipe over duct board and flex. Round should be cheaper than square duct work put together with S locks and drives. And a heck of allot better than duct board and flex
This is why I asked about the duct system. Most residential customers don't know the difference and would never think to ask. We specified all hard duct in ours. There is no flex used anywhere but the fart fans.
Yep, thanks for all of the advice so far everyone. You've really given me a crash course education on this all.
/ New Construction HVAC decisions. Geothermal vs. alternatives with upgraded envelope. #104
the cheapest isn't always the best. Neither is the most expensive.
But, if all they install is duct board and flex. I would pass
/ New Construction HVAC decisions. Geothermal vs. alternatives with upgraded envelope. #105
Just for you. My director of technical services asked me how I edited the photo LOL Do a websearch. It's an original picture I assure you.
well, You win the award ! I thought I had seen just about everything. But, I have never seen this:laughing:
/ New Construction HVAC decisions. Geothermal vs. alternatives with upgraded envelope. #106
I think I'm now understanding why the quote for the radiant floor heating was so much more expensive than the forced air. It should be a few thousand more, but not what you were getting quoted.
Building a new place can certainly be difficult. So many choices at every stage. I remember the process for us. You end up having to put a lot of trust in a few people to do it right or it takes forever. Luckily you seem to have planned on it taking some time. In the end you'll be happier, but until then, you're likely to be pretty overwhelmed. And I'll agree with most of the recent comments about the low and high quotes. It's also the case that the lowest and highest quotes are not actually quoting the same job. The lowest is the person that wants to win with the lowest price and will do everything as cheap as possible. The highest might be the guy that would do it to make you the happiest and keep a reputation for quality.
/ New Construction HVAC decisions. Geothermal vs. alternatives with upgraded envelope. #107
Have no clue where you got that idea, because depending on layout, flooring and boiler, forced air could actually be more.
With radiant heat, you get NO air conditioning whatsoever.
Back up North and new contrstruction, for better homes, it was radiant heat and high velocity for AC.
/ New Construction HVAC decisions. Geothermal vs. alternatives with upgraded envelope. #108
Why would you not have AC? You still have to install all the ductwork for the AC side which is typically the reason radiant is so much extra.
/ New Construction HVAC decisions. Geothermal vs. alternatives with upgraded envelope. #109
My father has radiant heat only. I replaced his boiler in 94, it's still going strong.
Installing a boiler with pex / copper and or even cast iron radiant is going to be cheaper than adding AC onto the job with exisiting heat.
As noted in my previous post, most common meathod I used back in the 90's up north with radiant heat was using a high velocity system for AC. Still cheaper for radiant only though.
The question becomes why spend the extra money on radiant if you don't have to and you want AC as well?
To each their own as long as you're willing to spend what it's going to need to cost.
/ New Construction HVAC decisions. Geothermal vs. alternatives with upgraded envelope. #110
Funny, back in the 70's we actually installed duct work and furnaces with no A/C (heat only) in new construction homes, while homes in the same subdivision got A/C added.
I travel to Texas this weekend to pick up my new system. Depending on weather, Hopefully I can get installed in the next few of weeks.
If all works out as planned, I should save some on my heat /cooling cost.
Thanks everyone. Clear as mud. Just as I expected. I just wish contractors actually wanted to use the best possible products and solutions rather than up charge with sub par materials. Maybe it's just the OCD in me.
/ New Construction HVAC decisions. Geothermal vs. alternatives with upgraded envelope. #112
Not everyone is an AC fan. We just put in a cheap window unit for the maximum 10 days of the year we want it. My parents just put in a mini split. The only time we bother with using the AC is when we have nights where it doesn't get below 70. That's 5-10/year. We saw AC as a huge waste of money. Obviously, we are not in a hot area of the country.
Last time I traded in a vehicle, the sales guy asked if the AC worked. I said, I wasn't sure since I never use it. Everyone's different. Glad you pointed out a downside of what I was saying. I have heard different comments though on GEO and radiant. One guy was saying that it could act as AC.
/ New Construction HVAC decisions. Geothermal vs. alternatives with upgraded envelope. #113
1 - Ductboard is not subpar material. What size (1" / 1.5" / 2" ) ductboard did they spcifiy and what R value flex?
2 - What warranty did the contractor offer on the duct system? Anything newly installed IMO should be covered by a lifetime warranty by the contractor unless it's voided by an act of God (house burned down, flood, tree came crashing in...). No matter what the contractor installs, you should be provided safe assurance that their work is good and they stand behind it.
3 - Did the contractor give you any examples of what type of work they do per images along with contact info for you to call? They should be proud of their work and references should be provided even if they aren't asked for.
The reality is, ductboard is used in some areas, and it's used well if the guys know how to install it. A duct board ductwork system inside a house has about the same chances of being destroyed as a metal duct system. The reality is, if ductwork needs to be changed for any reason, ductboard is actually easier if you know what you're doing.
I don't like ductboard ductwork systems for the same reason why I don't like lined metal ductwork - fiberglass fibers in the air stream. That however is nitpickey. I have 3 separate ductwork systems, all fiberglass lined. I live with it even though it's not my first choice due to cleaning. A properly sized, lined wrapped metal duct system will cause no more noise than a lined system per residential applications.
/ New Construction HVAC decisions. Geothermal vs. alternatives with upgraded envelope. #114
I don't like duct board and flex for the reason in a crawl space, if cats, rats, etc, get under there. They will destroy your duct work and flex. Seen it too many times.
IMO, It is an inferior material vs metal for crawl space installation.
In an attic possibly, if it's put together with staples and taped with a good tape and mastic over all joints to prevent it from falling apart. And you can keep the rodents out of your attic. I have seen plenty of it fall apart here in the south in a hot attic
Of course, your metal should be sealed for air leakage at all seams
Any duct work installed here must be leak tested and a report given to the customer
We can't afford to have it done right the first time. But we can afford to have it all torn out and done correctly
/ New Construction HVAC decisions. Geothermal vs. alternatives with upgraded envelope. #115
Ken
I didn't know what a crawl space was until I moved south of the Mason Dixon line. One of the requirements for our new home when my new wife (at the time) went looking for a house was a basement LOL
I haven’t asked for references yet. I only know one person personally who had them install a similar system a few years ago and they’re happy.
Here is, verbatim, the quote I received from them:
1 – WaterFurnace NDV049 5 Series Two Speed Geothermal Unit with Hot water generation. Installation will include an FC1-FPT Pump Pack, 15KW Electric Heat Package, Hi-Def touch screen communicating thermostat with electric heat lockout and lifetime warranted electrostatic air filter.
This system will take care of the first floor needs of the home with some air in basement. A fiberglass/sheetmetal duct system will be installed.
Pricing is for horizontal application with no excessive rock and need for screening. In cases with heavy rock and/or need for screening, additional cost will apply or be determined that vertical will be a better choice. In case of vertical application an additional $3,850 would be added. Casing should not be needed but if absolutely necessary it is extra. Digging is for a one time only rough backfill done at the time of the loop installation.
Price as Described
$24,250
UPGRADE TO THE MOST EFFICIENT HEATING AND COOLING SYSTEM AVAILABLE!
Upgrade to the 7 Series NVV036 Variable Speed Geothermal Unit
Simply the most efficient, most comfortable system available, anywhere!
Add $3,800
OPTIONAL ADD ONS
Symphony Integrated Control System. This system allows us both to monitor the system and notify us both if there are any problems with the geothermal unit.
$750
INFLOOR RADIANT HEAT OPTIONS
WaterFurnace NSW025 Geothermal Heat Pump Water Heater
80 Gallon Geo Storage Tank
(This also produces nearly all of the domestic hot water)
Hydronic Circulator Board for Basement InFloor Radiant Heat
ADD $12,500
Additional infloor zone for Garage
ADD $3,875
2” Insulation board will be needed under basement/garage slab (Provided by Builder). HGI will install infloor piping.
HUMIDITY
Aprilaire 800 Series Steam Humidifier
$1,185
Aprilaire 700 Series Humidifier
$675
Zoning Option with Intellizone2 Zoning Control
This allows for separate thermostats to control different areas of the house. With the 7 Series, even small zones like master suites can be zoned with no air noise! Up to 6 zones total!
1st Additional zone - $2,950
Additional zones afterward - $1,950 per zone (up to 4 zones with 5 Series and up to 6 zones with 7 Series!)
Warranty will be 10 years parts on the package units
5 years parts on pumps and thermostats
Labor warranty for 5 years on everything
Pricing Good for 90 Days
Please Contact us if you have any questions.
Thank You
/ New Construction HVAC decisions. Geothermal vs. alternatives with upgraded envelope. #117
I haven稚 asked for references yet. I only know one person personally who had them install a similar system a few years ago and theyæ±*e happy.
A couple of notes. We have the Aprilaire 800 Series. Very nice unit that has served us well. If your in a cold climate where low humidity is going to be an issue it's well worth adding. Set your humidity level for the winter and forget it. I also see you quote shows hot water generation from your geo unit but do not see any mention of a buffer tank. It's pointless to have the hot water option without a second buffer water tank. The buffer tank does not need to be a high end tank. We use a marathon main tank and a standard tank for the buffer. Finally I don't see anything in the quote for an HRV or ERV for your home. If you are building right to stop air infiltration and it sounds like you are you will need a system for fresh air to be brought into the home. Our contractor stated we did not need one and we ended up adding it after the fact when I started monitoring co2 levels in the home.
/ New Construction HVAC decisions. Geothermal vs. alternatives with upgraded envelope. #118
Yes, after getting an energy audit on our new house, they said it was too tight. They warned that a house that was too tight would likely have illnesses being passed from one occupant to another. Interesting that you went to CO2 monitoring and see it. Interesting thought.
/ New Construction HVAC decisions. Geothermal vs. alternatives with upgraded envelope. #119
Good gosh man ! Just for the first part without any add on's or up grading to anything, you're at 24K for the system. I don't know anything about those systems, But sure hope the unit last long enough to pay for itself.. Or, at least last long enough for you to see any pay back over what you pay out for the system
Ain't no way I would pay that much to heat and cool my home. It would take a life time to make my money back and start to see any savings. I just don't believe it will last that long
/ New Construction HVAC decisions. Geothermal vs. alternatives with upgraded envelope. #120
Kenmac there are a few things to consider, one being the 30% tax credit until the end of this year before it starts scaling back. That takes the system cost in his quote to $16,800. There are sometimes local rebates as well. Just remember that tax credit does not include the ductwork on the system so you will need your invoice broken out for the credit. Other considerations are a system that is comfortable and quiet do to the low volume delivery of geo. In our home for instance my wife has a plant that sits next to a floor vent. Seeing the leaves move is the only way that I can tell our system is running. It really is that quite. Units also sit inside out of the weather. Not sure how much that will add to the life.
Here was the breakout on ours. two - 4 ton modine 2 stage units, water to air. Desuperheater. Backup heat strips. All metal duct, fiberglass lined. Horizontal ground loop. Total of 6 zones heating 4,400 square feet.
Total Cost = $34,000. Breakout was $7,000 ductwork, $27,000 geo.
Govt Tax Credit = 8,100
Local utility credit ($750 per ton) = $6,000
Final install cost after credits = $19900
After all of the rebates we were only about $3,000 more than an electric heat pump system.
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
TOWABLE HYD WOOD SPLITTER (A60430)
TOWABLE HYD WOOD...
Year: 2019 Make: Freightliner Model: B2 Vehicle Type: Bus Mileage: Plate: Body Type: Conventional (A59230)
Year: 2019 Make...
