Dumb Battery Question.
/ Dumb Battery Question. #21
I like the Rural King Heavy Duty/Commercial batteries. They are made by Exide so there should be other branded labels out there besides RK's. I like them since they are made a little tougher, stronger case, and built to withstand more vibrations (plates) and abuse. I realize these are marketing claims, but they are comparing to their other batteries.
/ Dumb Battery Question. #22
I measured the battery room I had, then bought a size 65 AGM battery from Autozone which fit. I used a 25% off coupon I found on the web. My original battery had 700cca, the replacement has 750cca. The agm batteries are suppose to hold up to rough service and vibration better. So far I'm happy. It's now almost 3 years old. I've read that Johnson Control makes them to high standards.
https://www.autozone.com/batteries-...ery/duralast-platinum-battery/319465_929779_0
/ Dumb Battery Question. #23
This is true, but these manufacturers run also batch-making so that they'll make batch for so & so often to their specs, the single most important factor in pricing is LEAD, so if you see a battery that is substantially cheaper chances are that the lead in the cells will be a lot less than in the more expensive one.
Which is why one indicator of battery quality is the weight of the battery. (It's not the ONLY indicator, however)
/ Dumb Battery Question. #24
I read through this thread and learned a lot about batteries and battery life, including the excellent link provided by DL Meisen.
I'm still trying to figure out what the "dumb question" was.
/ Dumb Battery Question. #26
Ustacould put in a disconnect for those long down times so there was no load on the battery. With all the electronical gadgets and whatnots now, does that harm the machines?
People still do that, and no, it does not harm the various gadgets. However, since many tractors have no "always-on" loads, you may find that it makes no difference whether the battery is connected or not. Also, all batteries self-discharge over time, even with no external load. So your battery will eventually drain. AGM batteries are known for having a lower self-discharge rate than conventional flooded lead-acid batteries.
/ Dumb Battery Question. #27
/ Dumb Battery Question. #28
in a limited size, you can have thicker plates for ruggedness, and longevity, OR, you can have thin, and more plates for more AH, and CCA..:thumbsup:
/ Dumb Battery Question. #29
There is one more component, seldom mentioned by battery manufacturers and that is "Purity of Lead"
/ Dumb Battery Question. #30
Now that this is mainly (or entirely?) being imported, I wonder how pure it is compared to batteries years ago.
/ Dumb Battery Question. #31
I know of only 2 makes that have a 99.9% lead purity and they are Odyssey and NorthStar, there may be others, but I don't know which ones.
/ Dumb Battery Question. #32
there are some John Deere batteries that have Silver included, for more CCA,(less loss)..
/ Dumb Battery Question. #33
The Northstar NSB (perhaps other series as well) have 99.99% purity. These are the same as Canadiantire's Eliminator Ultra XD AGM batteries and they also make Exide's pure lead AGM batteries. IMO are super excellent
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
Roll of Plastic Hose (A64119)
Roll of Plastic...
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
ROLL OF 5' CHAINLINK FENCE (A64281)
ROLL OF 5'...
