Building FEL hay spear, have a question
/ Building FEL hay spear, have a question #11
I have built several overthe years but when I bought the new loader I got one from Titian attachments for around 400 bucks . It's hard to build one that price if you factor in your labor.
/ Building FEL hay spear, have a question #12
Thanks, I was thinking that traveling downhill with no rollback could potentially be an issue...............................
Travelling downhill with the bale in front of you with a B3200 could potentially be an issue itself.
I always have one on the 3-point when moving bales in the bucket.
If I could find someone selling a loader mounted bale spear for Kubota quick attach for $400 I would surely buy one, no question.
/ Building FEL hay spear, have a question #15
I just assumed you had the quick tach or universal quick attach on your Loader
/ Building FEL hay spear, have a question #17
I vote for extra rollback.
This is my first machine that could use a bale spike. I took off the forks and hung the 3 point bale spear on the fork frame. Soon found out it didn't have enough rollback:
Put an adapter together with a lot of rollback:
It worked great:
/ Building FEL hay spear, have a question #18
I wish, my dealer/salesman was not very knowledgable.
why not just buy the attachment and build the QA to your specs I would think the global QA could be easily adapted
I thought about that, but then I would have to modify my bucket to fit ssqa, and have a $300 Kubota quick adapter that I would have no use for.
/ Building FEL hay spear, have a question #20
After m5farms mentioned the global QA I got to wondering what kubota did for a quick hitch,
it looks like they had several different so called quick attaches;
Optional “Bolt-On” Brackets
Work savers may have your QA for your kubota.
good luck
Towable Light Tower (A60352)
Towable Light...
2014 Dodge Grand Caravan Van (A61569)
2014 Dodge Grand...
MGY Shop Heater (A60463)
MGY Shop Heater...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
Hydraulic rail grinder (A61307)
Hydraulic rail...
