Building FEL hay spear, have a question
   / Building FEL hay spear, have a question #11
I have built several overthe years but when I bought the new loader I got one from Titian attachments for around 400 bucks . It's hard to build one that price if you factor in your labor.
   / Building FEL hay spear, have a question #12
Thanks, I was thinking that traveling downhill with no rollback could potentially be an issue...............................
Travelling downhill with the bale in front of you with a B3200 could potentially be an issue itself.
I always have one on the 3-point when moving bales in the bucket.
If I could find someone selling a loader mounted bale spear for Kubota quick attach for $400 I would surely buy one, no question.
   / Building FEL hay spear, have a question #15
I just assumed you had the quick tach or universal quick attach on your Loader
I wish, my dealer/salesman was not very knowledgable.
   / Building FEL hay spear, have a question #17
I vote for extra rollback.
This is my first machine that could use a bale spike. I took off the forks and hung the 3 point bale spear on the fork frame. Soon found out it didn't have enough rollback:
Put an adapter together with a lot of rollback:
It worked great:
   / Building FEL hay spear, have a question #18
why not just buy the attachment and build the QA to your specs I would think the global QA could be easily adapted
I thought about that, but then I would have to modify my bucket to fit ssqa, and have a $300 Kubota quick adapter that I would have no use for.
   / Building FEL hay spear, have a question #20
After m5farms mentioned the global QA I got to wondering what kubota did for a quick hitch,
it looks like they had several different so called quick attaches;
Optional “Bolt-On” Brackets
Work savers may have your QA for your kubota.
good luck
Mobile Transformer and Power Substation Portable Power Supply (A55302)
Mobile Transformer...
1964 Mercedes-Benz 190D Car Sedan (A56859)
1964 Mercedes-Benz...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
New Holland TS6.120 Power Shuttle 4WD 120HP Agricultural Tractor (A56857)
New Holland...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
