Rounded off drain plug
/ Rounded off drain plug #921
I put some Kroil on a part that was hopelessly rusted stuck but it wouldn't budge so l forgot about it. On a lark l checked a month later and it came apart easily. So, even when Kroil won't work, it's still working.
Kroil is expensive stuff....there is nothing quite like it (except maybe 50/50 ATF & Acetone or laquer thinner).
Kroil, in my opinion, is definitely worth it's high cost!
Kando,
Did I miss the pic of your new tractor?
Hadn't posted one, but:
/ Rounded off drain plug #924
Purty......If it was trailered over to a shop and got it back in the spring should be good for another hunnert posts on how yah shouldah towed it, trailered it, and then nuther hunnert posts on the welder shoot fire we could bust a new record.......say wasn't there a rumor about new toaster or oil plug for the 1,000 post??? :cool2::drink:
/ Rounded off drain plug #925
That's the wrong tractor!
The rounded off drain plug is in his 960.
/ Rounded off drain plug #929
What is my life coming to? Everyday I have to check and see if the drain plug is out. And later will ask, how he got it out. And will be people that say, this way must have broke it loose.
I wonder if he could just take a torch and cut out a 4 inch circle, drain the oil, and then weld it back in. He could even take a rag and wipe out the bottom of the pan.
/ Rounded off drain plug #930
Don't think that will work on his cast iron transmission :thumbdown:.
/ Rounded off drain plug #932
He could use a large hole saw. And put it back in with jbweld.
/ Rounded off drain plug #933
OR, he could just get a good pipe wrench and remove the drain plug,.. wonder why no-one thought of that!:rolleyes:
/ Rounded off drain plug #934
I have two good ones. I would give him my old cheap ones that I got before I could afford good tools.
I've got cheap ones, I've got a couple ridgid to use too. Only missing dedicated time.
/ Rounded off drain plug #936
Well, don't use the good ones until after another 50 posts :)
/ Rounded off drain plug #937
Actually 57 from this point. But I’m pretty sure that’s happening regardless from this point.
/ Rounded off drain plug #938
No less than the one about battery chargers. :)
Maybe if you hooked a trickle charger on the plug the electric current would loosen the plug. Or you could weld the plug and pretend it wasn’t supposed to be there. Being serious now I’d probably vacuum the oil out and forget about removing it since this is probably the last time it’ll need changed.
Why would it be the last time i change it?
/ Rounded off drain plug #940
How often do you plan on changing it? Most vehicle rear ends never get the oil changed and transmissions especially a manual don’t get much more care.
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
(2) UNUSED 12-16.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 12-16.5...
2024 Ford Transit Box Van, VIN # 1FDRU6ZG8RKB10273 (A65563)
2024 Ford Transit...
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
JOHN BLUE TANK SUB FRAME (A63291)
JOHN BLUE TANK SUB...
LOOK! (A63111)
LOOK! (A63111)
