Rounded off drain plug
/ Rounded off drain plug #881
Ok, well this thread had done one thing. It has made me order a set of these pliers.
Add me to that list. $88 for the full set of 3 Knipex Cobras. I'm going to have to STOP reading these comments about the latest and greatest tools. I'm a sucker for tools to start with. I just bought a new NOCO battery charger based on these messages. Dang it - I already have 5 battery chargers! Yep - no matter, I still have to have just one more.
Now I have a set of surplus Channel locks. I guess now I need a larger tool box. But - I'm now ready for any rounded off drain plug :)
/ Rounded off drain plug #882
Do you need toolbox recommendations???
/ Rounded off drain plug #883
Not to worry about having 5 battery chargers, you will not pass me.
I have 15 trickle type chargers, and 5 regular chargers.
Your 5 chargers probably put you in the "normal" category.
That NOCO Genius is a nice looking device....I think I "need" one or two.
Nope!
You are NOT... "ready for any rounded off drain plug"!
You still NEED a Rigid pipe wrench!
/ Rounded off drain plug #884
OK, this is easy. Just get rid of the five old school chargers and keep the NOCO Genius. Regular chargers likely do more harm than good.
In fact, buy a second Genius charger and then you'll only have two chargers. :D
/ Rounded off drain plug #886
As well, he should pick up some band aids. Those new J&J ones with the cloth backing work well. Maybe a pair of auto gloves too. He should still farm this job out but if he does it himself there's going to be some degree of blood.
Good point, is there any real wrenching job without?
/ Rounded off drain plug #887
"Regular chargers do more harm than good"?
I don't think the NOCO Genius will help much when trying to start using a weak battery.
Maybe.... if you let the NOCO charge ..... until the day after tomorrow.
My "old school" Schumacher will charge/start at 4/30/60/300 amps.... right now!
/ Rounded off drain plug #888
Forget the chargers. What about the drain plug.
/ Rounded off drain plug #889
/ Rounded off drain plug #891
Not for another 103 posts.
/ Rounded off drain plug #892
Holy dung! I gave up around page 30 and decided to skip to the "last chapter" only to find that this thing is still dragging on!
Not sure if anyone mentioned this, but, ALWAYS LOOSEN up the FILL PLUG FIRST. (if applicable) If you've drained a pan/case and then find that the fill plug self-destructs then you're stuck with a drained chunk of metal.
Penetrating fluid (PB Blaster, or kerosene and ATF) go a LONG way to help. Doing this over the course of several days. Impact force (if possible). Movement to TIGHTEN, but only enough to get a sense that it's transferring good torque. THEN reef it in the unwind direction: I'm not understanding how bolt extractors cannot be used here: there's almost always some way to get an angle to beat something (have to be creative). Perhaps getting operating the tractor such that it's good and warm will help: I know that removal of glow plugs and injectors are much easier with the engine having been warmed up; and, perhaps do this in conjunction with penetrating fluid (do it several days in a row before one then makes the big "final" push at extracting that plug).
It's quite possible that the plug is stripped. Need to have a plan in place just in case. As someone noted, I'd be looking to get better access.
As has been suggested, pumping the case might be the only real "solution." Unlikely it's something that has to be done very often: already spent more time on this than would have been expended by several such operations. I use an oil extractor for oil changes on several pieces of equipment: my cars, VW TDIs, are great candidates; also use it on my Polaris (diesel).
/ Rounded off drain plug #893
This plug has had oil on one side for years. And probably re-installed into oily threads in the past.
Not likely to be rusted in place.
Would penetrating oil really make any difference?
Bruce
/ Rounded off drain plug #894
Wow, 900! As we approach the 1000 post threshold, Kando needs to get that sucker removed. Once he gets it out we can focus our efforts on replacing the plug. Should he use Teflon tape? Old school pipe dope? New tech thread sealer? Go commando and gamble on the metal sealing things? Speaking of metal, should he use a brass or steel plug? Once that's decided, should it be a standard pipe plug like he's removing, or go with a concave plug? Square, hex, or other drive? We have so much advice to offer once he gets that plug out. Thank God this is a transmission drain so we won't get into much of a debate about oil.
/ Rounded off drain plug #895
It's penetrating "fluid." Different than "oil." Thinner and more able to penetrate where regular oil cannot. So, yes, penetrating fluid CAN make a difference.
The "sticking" isn't likely so much "rust" as it is from metal galling. No matter, there will be microscopic spaces, and very thin fluids work very well in being able to get in such spaces. Applying heat and then the fluid will help facilitate the drawing in of the fluid.
/ Rounded off drain plug #896
Speak for yourself. :stirthepot:
/ Rounded off drain plug #897
I kind of started a debate about oil vs fluid, does that count? :laughing:
/ Rounded off drain plug #898
/ Rounded off drain plug #899
Penetrating oil doesn't work well on pipe threads.
Pipe threads seal air, and solvents such as acetone., And gases such as helium and hydrogen. On a molecular level it don't get much smaller. Penetrating oil isn't magic.
Best things to do for pipe, is heat the PLUG, and apply was and watch it wick in.
But as said....stuck really isn't the problem. Its probably just torqued to a nominal level. Gripping the plug to apply that torque is the issue, and penetrating oil is not the answer
/ Rounded off drain plug #900
Pa always told me growing up on farm to figure things out, otherwise take it to town and pay someone to fix it for me...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2005 MACK CXN613 6X4 T/A  DAY CAB TRUCK TRACTOR (A59911)
2005 MACK CXN613...
UNUSED ATS POWER ATS-GAC40Y 40 GALLON (A64281)
UNUSED ATS POWER...
2017 International 4300 Box Truck (A62613)
2017 International...
