that will look good with lights in your living room
That gives me an idea. I have a really good looking pine I've been meaning to pull up.
ok, so I'm a little early for X-Mas trees but Ma said she wanted this pine gone and me, just finishing installing some chain hooks on my loader I said NP ! The 54D just plucked it up out of the clay like nothing......so far having a blast with my new machine.
That was the easy part. Now you have to make the hole in the ground look like there was never a hole in the ground.
Good job!
....now you have to get rid of that root ball.
"Shake it, shake it, shake it, shake it,
Shake it like a Polaroid picture!
Hey ya!"
I've found that having it sit out in the weather combined with 4 to 6 bonfires over a 3 year period does the trick.![]()
...or bury it.
Something that I learned the hard way, if the hole fills up with water, be sure to get all the water out of it before trying to fill it up with dirt. If you leave the water in there and fill it up, it will appear dry and solid, but it's really quicksand that will swallow up your tractor when you forget where it's at after the grass has filled in.
My ceilings aren't quite high enough for that one, but it is a good idea. Are you sure that is a pine? It looks more like a spruce...or maybe a fir?
Shake it like a hound with a groundhog.Good job!
Hey ya!"
...or bury it.
Now that is cool ! Hey, mom says a HUGE rose of Sharon tree that is too close to the house and has to come out next (he-he-he).......
for the OP...What was the reason for taking out the pine?...first thought might be to replace it with something more ornamental...unless it was to not have to mow around it?
