40x60x14 Shop
/ 40x60x14 Shop #21
Eddie, I didn't measure, but the rebar looks to be every 12", 15" max. No way to work without stepping on it. Has the pex pipe fastened to it. For peace of mind the builder charges the pex with air and a gauge. Monitors it while they are pouring. Not sure he would do if the pressure dropped.
/ 40x60x14 Shop #22
Finally broke ground on my shop last week. Weather has been good, and looks to stay good into next week, so hopefully they can get it knocked out by Thanksgiving.
The original pad last March.
Ovrszd hauled a LOT of fill after the wife decided that she wanted to move the shop farther south than originally planned. I can't remember now how many scraper loads it was, but it was a BUNCH. I was the resident packer. Luckily, it had all summer to settle, and it ended up looking great when they did start on the shop.
Getting the pad ready last week.
Rebar and foam in yesterday. Should get the floor heat ran today, and hopefully pour concrete on Thursday.
How much is a yard of concrete these days in yalls neck of the woods?
/ 40x60x14 Shop
I’ll be honest, I have no idea! My builder gave us a price for a finished building to our specs. Didn’t itemize it for us. Richard has been a lot more hands on with his build, he could probably give you an idea.
/ 40x60x14 Shop #24
Ok that's cool. He did a nice job laying out the rebar.
/ 40x60x14 Shop #25
Looks great. Hope you will keep us updated through the whole process. This is the exact size shop I am looking for. Trying to decide between a pole barn, metal building or stick built.
/ 40x60x14 Shop #26
Same crew remodeled the outside of the house a couple of years ago. Really good at what they do as far as I can tell.
I live close to, by not close enough to an Amish/Mennonite community. I’m not opposed to it, maybe just jealous because I’m not in their commuting zone. I have to make alternate arrangements to enlist their services.
/ 40x60x14 Shop #27
We have groups integrated in our county. Most close enough to travel by horse. But they also hire a lot of vehicular travel. Several are in the construction field. They do excellent work under the guidance of a quality contractor. Left to their own guidance the quality lowers.
/ 40x60x14 Shop
Builder said they they were going to start framing today! Looks like they are dropping off material first thing this morn.
/ 40x60x14 Shop #29
As we talked yesterday evening, I'm surprised he's gettin on the concrete that quick. Hopefully Heath showed up first thing this morning and cut it.
/ 40x60x14 Shop #30
Was wondering the same thing on about starting the framing. I would get the slab saw cut first why nothing is in the way and the concrete still green.
/ 40x60x14 Shop
He set anchors in the concrete yesterday, so he didn’t have to drill today. They did cut the concrete in the center lengthwise and two cuts to split it into thirds. Four walls up, electric, water, sewer, and gas line run!
The boss checking it out!
My view from the northwest window.
Guessing they’ll get the trusses up tomorrow and start putting sheeting on.IMG_2044.JPG
/ 40x60x14 Shop #32
Man this is happening fast for you:thumbsup: Looks great. They'll probably sheath the walls after they plumb everything then set the trusses. 14' walls need sheathing first.
/ 40x60x14 Shop
Yeh I have no idea the order things will go. Two bundles of plywood sheets and trusses are on location. Pretty good chance of rain this eve, and tomorrow, so progress may come to a halt tomorrow.
/ 40x60x14 Shop #34
Jealous. Congrats on the build.
/ 40x60x14 Shop #36
He set anchors in the concrete yesterday, so he didn稚 have to drill today. They did cut the concrete in the center lengthwise and two cuts to split it into thirds. Four walls up, electric, water, sewer, and gas line run!
View attachment 576254View attachment 576255
View attachment 576258View attachment 576259
Guessing they値l get the trusses up tomorrow and start putting sheeting on.View attachment 576260
Just think, a couple more weeks it'll be done and full and you'll start thinking about why didn't I make it BIGGER.. :p
/ 40x60x14 Shop #37
Sure is nice seeing how good of a job that they are doing. Something that I've always felt was a good indicator of a good contractor over one in over his head is how clean they keep their working area. Some jobs you can't walk anywhere without having to step over debris, or the garbage pile is overwhelming.
/ 40x60x14 Shop #38
It is going to be a stick built building. Spray foam insulation on the walls, and blow in insulation in the ceiling. It will have a metal panel ceiling, and we are still working on what the walls will be. Builder wants to do metal panel walls, and we want OSB walls. I think it will help absorb the noise. Builder is super particular about his buildings and hates the look of OSB. So far we have "maybe" decided on plywood stood on end so that it was 8ft high, and then metal liner from there on up.
That's almost identical to my shop except I used fiberglass batts in the walls and the walls are 3/4" plywood around the bottom eight feet with steel paneling above that.
The nice thing about 3/4" plywood is it adds a great deal of strength to the structure and it also makes a very tough and durable wall that's very resistant to damage with the benefit of anything is easily and very securely fastened to it anywheres.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64277)
KNOW BEFORE YOU...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
Quick Attach Backing Plate (A65579)
Quick Attach...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
3145 (A63117)
3145 (A63117)
