Compact Tractors are Designed All Wrong
/ Compact Tractors are Designed All Wrong #241
I've never seen a telescoping boom on a PowerTrac.
And one of the things PowerTrac owners like is that there are NO computers. The brute simplicity of the machine is what most of us enjoy. Keep it simple so it's easy to work on yourself.
/ Compact Tractors are Designed All Wrong #242
Probably because its not much new development in the CUT marked? So it interesting to see what may trickle down from largere machines. Tractors has been very much the same basic idea for a very long time and its quite clear that there are more than the classic way to do it.
Perhaps the real question being raised in this long reaching thread should be: when is a tractor no longer a tractor?
In some regards much of the thread seems to point toward mini-wheel loaders, or things like the Bobcat Toolcat neither of which are marketed as "tractors". It should really emphasizes the point of evaluating the tasks a person wants/needs to do and then identifying the tool to best suited for those tasks, rather than deciding to buy a new tool/tractor and then trying to figure out how to use it to accomplish the needed tasks.
While I partially understand the frustrations with the 3pt hitch, I think I'd attribute much of it to poor implementation on the tractor-side with fixed-length lift (non-telescoping) arms using turnbuckles for sway-braces. Of course I may just be weird (or using a very different technique than most) since it usually doesn't take me much more effort to hook-up a 3pt implement than it does to connect a SSQA attachment on the front. Granted my tractor came with telescoping linkends and sliding/pinned sway braces, which mean it's just a matter of getting "close enough". Which is made easier by raising the lift arms above the hitch point and then lowering them onto the pins, after backing up to a "close enough" lateral alignment. At that point it's just a matter of getting off the seat and making the connections. After reading this thread I'm tempted to time how long it takes me at some point......
What I truly don't understand is the desire/need for some implements to be front mounted or (to my mind even worse in some cases) mid-mounted. I'll grant I haven't needed to spend hours at time looking backward trying to do precision work either, so I really don't have an issue with having to occasionally look backward to ensure a mower (or other implement) is going to clear a tight spot or get as close as I want.
/ Compact Tractors are Designed All Wrong #243
It's a quit bad design to have to turn around to monitor what you are doing, understandable in a historical setting but to day it's not a good solution. More and more tractors has double command and are a way more useful machine.
/ Compact Tractors are Designed All Wrong #245
All good points. Especially about deciding what you want to do before buying a machine.
I'll tell you from my point of view, after 17 years of owning this Power Trac PT425, and retiring my much larger conventional tractor, an IH2500b, and eventually getting rid of it.
First, I'm not saying this is THE BEST machine for everyone, just that it's the best for my needs. I'd just like people to open their eyes to other types of machines that are out there, like these articulated ones, skid steers, tracked skid steers, compact telehandlers, etc... so here goes. ;)
Of course, loader work benefits from being out front. That we all know. But with a machine like mine, I can see the entire bucket when it's on the ground. I can't see in front of a traditional tractor, as the hood blocks the view.
The same thing goes for pallet forks. I can see the pallet (oh, no, did he say pallets?) to slip the forks under it. Can't do that with a conventional tractor.
This ease of view of the business end of the FEL arms makes things a lot easier and safer. A skid steer operator will say the same thing. I can see what I'm doing! :thumbsup:
Mowing a lawn is much easier for me with the mower deck out front. I can get into tight corners better than with a mid-mount, or rear mount. And I can go under trees and overhanging branches, like fruit trees, with much more precision and much less of a chance of knicking the bark with a rear mount deck. You can't mow under things like that with a mid-mount. Rear is better. Front is best.
Brush cutting, I have mowed down very thick 13'+ high thistle without having to drive through it first, or back over it. With the brush cutter on the FEL arms, I can raise it up in the air and mow almost vertically. I can also lift the deck up to about a foot high and take the top off of a bush or shrub, then back up and see how thick the stumps are without having to look behind me. At the end of the day, brush cutting thick brush with the cutter out front is much less fatiguing than having it behind me.
Power angle snow plow on the FEL arms is far superior to back blade. I don't have to drive through the snow before plowing it, and I can stack it 6' high. Just couldn't do that with a rear blade on a similar sized conventional tractor.
Hydraulic post hole digger on the FEL arms not only allows for easier alignment with the point on the ground where you want the hole, as you can see the spot on the ground from the operator's seat, it allows for power down, which a 3pt doesn't have, and it allows for reversing the auger if it gets stuck, which a PTO on a 3PT doesn't have.
Power brooms, mini-hoe, trencher, grapple bucket, stump grinder, power rake, cement mixer (mix and pour with the FEL arms), tree shear, post drivers.... all of those tasks are better accomplished out front where you can see them vs a conventional tractor.
Think about a snow blower on the FEL arms. Not only do you not have to turn around and watch it, you can lift it 6' in the air and tackle the tallest drifts.
One of my favorite tools is a 2" trailer hitch receiver tube mounted to a quick attach plate. I slip in a ball hitch, and I can drive right up to a trailer, see it right in front of me, put the ball in the socket, lift it up and push it anywhere I want with much greater accuracy and less fuss and no turning around if the ball was on the 3pt hitch. The operator just can't see that on the front of a conventional tractor.
Anyway, those are just some of my observations made over the past years.
If I had to plow dirt, or pull stumps, or operate large batwing mowers, or bale hay, then this machine wouldn't be for me. But I don't have to do any of those tasks. And I never have to change a 3pt implement again.
It takes me just a tad under 15 seconds to unlock and drop an implement and pick up another one and lock it into place and be on my way, and I don't have to get off the seat. If it's a powered implement, then I have to set the parking brake, unbuckle my seat belt, get off and hook up two hydraulic hoses, which adds about 30 seconds. I'll take that over a 3pt hitch any day. :)
/ Compact Tractors are Designed All Wrong #246
A PowerTrac seems to be more of an implement carrier than a tractor. The design is not optimized for pulling. So rather than saying "compact tractors are designed all wrong". Your position really is that compact tractors are designed all wrong for you. Many people who buy actual tractors do so because they need to pull things that are hard to pull.
/ Compact Tractors are Designed All Wrong #247
Not for me. For my needs. And for most other homeowners, estates owners, landscapers, golf courses, municipalities, landscape supply yards.... :laughing: They don't have to pull stuff.
I've said it numerous times and am in complete agreement that these machines are not for pulling. Plowing fields? Nope. Pulling stumps? Nope. Pulling haying equipment? Nope. 15' batwing mower? Nope..... although there was a member that had commercial mowing contract at estates and pulled two 60" self powered finish mowers behind the PT425 with it's 60" mower, for a total cut width of 3x60". So that's 180", which = 15' of cut, minus some overlap, of course.
https://www.tractorbynet.com/forums/owning-operating/11472-power-trac-425s-mowing-season.html
So yes, if you need to pull stuff like that, get a pulling machine. If you don't need to pull stuff, there's better options out there than a conventional tractor.
/ Compact Tractors are Designed All Wrong #249
What Moss said. Having owned 4 conventional tractors, a standard CUT is not ideal for most people who do not farm/plow.
Now one feature I wish I had was not only articulated steering but also front wheels that turned - would come in handy at time. It can be easy to get yourself into an awkward situation with an articulated machine - I sometimes have issues when using the forks to pull a pallet out of a tight spot while not having room to just back up straight.
Ken
/ Compact Tractors are Designed All Wrong #250
Compact tractors are designed poorly regardless of the intended use. They’re the most versatile and the most common design which is a big plus for them. All tractors are a poor loader platform, and compact tractors don’t have big enough tires and often have the wrong tires and transmission to be a good pulling machine.
/ Compact Tractors are Designed All Wrong #251
Fully agree, getting an awareness of what's available is definitely a good thing -- though it's not always easy. In fact the only way I found out about the machines made by Multione was through stumbling across it while researching mechanized methods of fruit/nut harvest (for potential future uses).
There's definitely no arguing the visibility differences either, since it's really a function of where the engine in placed relative to the operator. So about the only way a single vehicle is going to offer good-to-great visibility both fore and aft would be for the operators seat to be mounted over the engine. Which can introduce challenges of it's own (not to mention it'd reduce the effectiveness of using engine's weight as ballast/counterweight).
When it comes to hydraulic augers, the points are all valid though it's also worth noting there are also 3pt mounted units capable of providing down pressure, and use of hydraulic drive is an option for 3pt boom units (which is probably a development that is a direct result of hydraulic augers gaining popularity). In fact depending on the manufacturer (and hydraulic output of different pieces of equipment) it's entirely feasible use the exact same hydraulic motor mounted on either a front mounted plate, a 3pt mounted boom, or excavator mount (and likely many others). Personally the thought has crossed my mind that getting both SSQA & 3pt mounting options with a hydraulic auger wouldn't be the worst idea since it'd allow greater flexibility in placing useful tools at either end of the tractor/machine ...of course I suppose getting the 3pt boom with hydraulic auger, and a 3pt to SSQA adapter (but that might start to get a tad crazy & unwieldy) :D
While I'm not quite as fast as that 15 second hookup time, I'd also be surprised if it takes me more than a minute to hook-up the 3pt with my tractor - and after having seen videos of fixed end lift arms, and used a quick hitch I've decided I'll never buy a modern tractor without telescoping link-ends on the 3pt (buying an older one with the old Farmall fast hitch is something I'd very much consider though). In all I may really need to time how long it takes me at some point.... though for me it's tends to be a relatively relaxing activity (plus it allows me to make a quick/casual visual inspection of the item before I start using it).
So I guess in my mind really it comes down what tasks a person wishes to perform and where the greatest visibility is needed/desired (which can partially be personal preference for some things) ---- and (potentially) in some cases if they are willing to use a proprietary/unique connection system for implements.
Wrapping things up on that note, despite any and all flaws (real and/or perceived) with either 3pt hitches or SSQA as attachment interfaces, the fact that they both are such widely used standards allow for innovation to occur on the part of implement/attachment manufacturers at a cheaper cost and larger market potential -- which in turn gives me as a purchaser flexibility in expand my capabilities through different implements at a lower cost if the tasks I need to perform changes - or superior options for performing existing tasks become available. Granted not everyone needs/wants such flexibility, but it's something else that would need to be considered (ideally before making a purchase :thumbsup: )
Really I don't think there is an overall "best" machine that can accomplish every task (hence the variety of different machines), so it really comes down to learning what's available and deciding what's best for the situation (mini-wheel loaders, compact excavators, and additional tractors all remain on my list as potential future purchases .... and that doesn't preclude other types of machines that I may stumble across in the future).
/ Compact Tractors are Designed All Wrong #252
What really surprises me about 3pt hitches is the lack of a standard quick attach these days. It has to be purchased separately. If I still had a 3pt, I'd definately convert all of my stuff to use a quick attach.
So let me ask you this... While you are good at changing 3pt implements, and it takes not too much time, do you look forward to changing implements? Do you plan your projects so that you don't have to change implments? Or do you in the back of your mind think, crud, I've got to change an implement again? :laughing:
I know a lot, and I mean a LOT of people have multiple tractors just so that they don't have to switch implements.
I know when I had my IH2500b, I did not enjoy dropping my brush hog and switching to my box blade and vice versa. If the thing wasn't set down on even ground, it was going to be a pain. And that's back when I was big and strong and could just pick up the end of the box blade, or grab the side of the brush hog, lift them up and move it over to where I needed it. It was still a pain in just the aggravation VS the Power Trac's quick attach.
There used to be a product called the Delta Hitch. That looked promising. But I can't find them anymore. Don't know if they're still in business.
/ Compact Tractors are Designed All Wrong #253
It is "Delta Hook": Alexander Equipment - Home
And an old thread: https://www.tractorbynet.com/forums/attachments/118718-introducing-delta-hook-rapid-hitch.html
/ Compact Tractors are Designed All Wrong #255
Compact tractors are designed poorly regardless of the intended use. They豎*e the most versatile and the most common design which is a big plus for them. All tractors are a poor loader platform, and compact tractors don遞 have big enough tires and often have the wrong tires and transmission to be a good pulling machine.
"All tractors are a poor loader platform..." - All is a strong statement. Yes, the visibility of on the PowerTrac is a plus, but I can get similar visibility on my tractor by standing on the platform - my controls are all in easy reach. Dollar for dollar, lift capacity and height seems to be in the tractors favor. Universal SSQA on most tractors instead of something proprietary (like PowerTrac) so I can get inexpensive attachments anywhere. I've operated a JD 110 and visibility on that was great even seated.
"and compact tractors don遞 have big enough tires...." And skid steers and PowerTracs do? Are you thinking only of SCUTs or small frame CUTs. How about a Mahindra 4035 / 5035 or Kioti DK45S or DK55. These have skid steer size front tires. My tractor doesn't have huge front tires but they are still as big as many skid steers. Probably bigger than those on a skid steer in the same price range.
"and have the wrong tires and transmission to be a good pulling machine.. " You can get CUTs with a variety of transmissions and tires. Some are not good for pulling. Some are. I prefer gear transmissions.
Now don't get me wrong. I like skid steers and just love the concept of a bi-directional articulated true 4 wheel drive machines with implement carrying solutions at both ends and a loader opposite the engine - and if someone could build one with capabilities, price and accessibility to compete with the best of the CUTs I may be tempted to sell my perfectly good tractor!
I don't plow fields or do anything traditional with my 3pt other than run a rear blade to grade my driveway and occasionally use a 3pt post hole digger. Most of the time, the SSQA stays on my 3pt. so that I can run forks or a material bucket in the back. I do some light logging and my CUT can easily carry over 4,000 pounds for miles and be perfectly stable with both ends loaded. Can't do that with any PowerTrac. And a skid Steer is too slow for transport.
PowerTrac is the closest to getting me out of a traditional tractor design. If PowerTrac went to SSQA, increased lift height a foot or two, had larger tire options, more gear options (both lower for more pulling force without burning anything up and higher for roading) and something in the back to skid logs - like maybe a rotating log grapple on a boom. I would have checked them out more. The value proposition just wasn't quite good enough the way they are designed now.
I do agree that many CUTs have artificially high hoods, seats that are too low and front tires that are too small. But this is individual machine design, not a fault of the category.
/ Compact Tractors are Designed All Wrong #256
I stick to my original statement. The basic design is terrible. They have the engine and the hood between the operator and the bucket which makes poor visibility and puts the weight at the wrong end. They put the weak steering axel on the loader end. They put the pivoting axel under the loader which makes stability much worse than it could be. They put the small tires under the loader end. No dedicated lifting machines have all those design flaws. If you want a dedicated pulling machine you want a geared transmission with no toque converter, and big ag tires. Those aren’t desirable features for a loader machine.
/ Compact Tractors are Designed All Wrong #257
I stick to my original statement. The basic design is terrible. They have the engine and the hood between the operator and the bucket which makes poor visibility and puts the weight at the wrong end. They put the weak steering axel on the loader end. They put the pivoting axel under the loader which makes stability much worse than it could be. They put the small tires under the loader end. No dedicated lifting machines have all those design flaws. If you want a dedicated pulling machine you want a geared transmission with no toque converter, and big ag tires. Those aren稚 desirable features for a loader machine.
Jack of all trades, master of none. CUTs are not optimized for loader work only. But some are surprisingly good.
/ Compact Tractors are Designed All Wrong #259
From the factory or do I have to fab it up myself at my expense?
/ Compact Tractors are Designed All Wrong #260
how come no one has mentioned the avant? they also have an all electric version. and 190+ attachments
e series – Avant loaders
i believe they have most of the original boxes ticked depending on the model, i'm sure they are expensive
i work part time in the summer putting up tents we use my little kubota b2650 to put up and take down as well as pull stakes. there is another company that does lots of tents and they have an avant to do the same things. with some practice i can do everything they can, though it is tougher to see. however when i'm done i can still go home and cut the grass.
i agree with gladehound and others that a tractor is more versatile
More info coming soon (A61569)
More info coming...
Caterpillar Service Manual Reference Kit for Motor Graders, Wheel Type Tractors, and Equipment (A63117)
Caterpillar...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
CASE TV450B SKID STEER (A64279)
CASE TV450B SKID...
2025 Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
2025 Kivel Quick...
