Yanmar YM2000 Fuel Pressure/ hard starting
/ Yanmar YM2000 Fuel Pressure/ hard starting #232
My project this week is figuring how to adapt the cross member from the 336D fitting YFL1500 front loader to fit my little YM2000BD.
After searching a few pictures and some sent over by California, I think I致e got a plan figured out.
Also, I致e found that the tach/hour meter cable did in fact break internally, so I am waiting for the new one to get here from Hoye.
This is posted from my phone. See the wacky contractions.
And just like that, the cross member for a 336D now fits a YM2000BD!
Even though I had some 3/8 plate available, I had to resort to using 1/4” due to available tooling.
I am going to the metal yard in the AM to source some metal to make some tie ins from the cross member back to the rear draw bar assembly.
/ Yanmar YM2000 Fuel Pressure/ hard starting #234
Even though I had some 3/8 plate available, I had to resort to using 1/4 due to available tooling.
where there's a will, there's always a way !:thumbsup:
/ Yanmar YM2000 Fuel Pressure/ hard starting #235
That looks great!
Interesting - you have bolt holes to support the loader in the sides of the bellhousing, just ahead of the clutch cross-rod. My YM240 doesn't have those holes. (photo). The similar downforce bears only on two bolts threaded upward into the bottom of the transmission. I like yours better.
Good work!
That looks great!
Good work!
I was contemplating also making a mounting to those 4 holes in the bottom of the transmission, but I am pretty confident that with this way I won’t need to, also going to add in the supports back to the draw bar, which should completely tie it in.
Alright, well here she is!
Once I get it final bolted in place I’m going to make a cross piece to tie in the straps on the rear.
/ Yanmar YM2000 Fuel Pressure/ hard starting #238
My 3110 doesn't have braces that attach to the rear like this. I only have a mounting bracket about mid ways of the transmission.
Get all that and then, plumb the HYD system and you should be good to go on the loader !
I hope the loader valve and cylinders are in working order as well
My 31130 doesn't have braces that attach to the rear like this. I only have a mounting bracket about mid ways of the transmission.
The loader valve is pretty much a goner, I ordered the same one Hoye sells from Surplus center for half the price. Cylinders look like they will be OK after new hoses and some grease on the joints.
/ Yanmar YM2000 Fuel Pressure/ hard starting #240
did you order the single joy stick or the double handle ?
2018 Dodge Grand Caravan SXT Van (A59231)
2018 Dodge Grand...
2018 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A59230)
2018 Peterbilt 567...
SANY SY225C9C5KL EXCAVATOR (A59823)
SANY SY225C9C5KL...
2000 GMC C7500 (A60736)
2000 GMC C7500...
2008 HINO 26FT NON CDL BOX TRUCK (A59906)
2008 HINO 26FT NON...
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
