Pull from the front or the rear?
/ Pull from the front or the rear? #141
Ok. Mostly two tractors pulling back to back. At 1:14 the tractor went over backward - no ROPS - then the driver was crushed under the tire.
1:40 similar but an adequate ROPS. Hope he had a seatbelt because the tractor then rolled to the side. In that one the tractor balanced upright on its 3-point arms for a moment before going over.
/ Pull from the front or the rear? #143
I agree with everyone else, if there is no option, pull from the drawbar.
Trying to pull from the front is not advised.
If you try pull from the front you risk damaging your loader if you try to pull off the loader body. Or damaging the bucket if load is
focused on the cutting edge.
Do not attempt to pull via the front axle, it was not designed to take this type of load.
In either case pull with extreme caution, high speed, jerk motions are a recipe for disaster. Better to get a tow truck,
/ Pull from the front or the rear? #144
For me this has been an interesting discussion. I not only learned something about flipping tractors, it also helped with my understanding of intelligence, visualization, and education.
Trying to picture the changing forces as something rotates is really tough using nothing but words.
Not everyone is equally good at picturing things in their mind, although most of us think that we are.
I think a lot of the misconceptions have to do with the limited visualizations that are a part of a primarily written forum like TBN.
If we were all in a room together while talking and sketching out the loads and forces, I think we would arrive at the same conclusions rather quickly.
Thanks all,
rScotty
/ Pull from the front or the rear? #145
.. The traction is perfect, (always, or assumed?) so it didn't come from slipping the wheels backwards. The chain presumably didn't stretch, either ... I haven't been to a tractor pull in a long time, but it seems to me that just about every tractor there either keeps the front wheels on the ground OR they float a foot off the ground. Floating signifies to me the actively balanced situation that is a compromise between solidly on the ground and the nose straight up. As the torque brings the wheels up...
Yes but ... I think in a real-world scenario the drive tires can hop and move backward. Then assuming nothing breaks, pouring torque into the ring gear will continue to 'climb the ring gear' and walk the tractor over backward if tire slip is insufficient. That torque has to go somewhere. Aside from tire slip, where else can it go? ...
Yes, vector analysis is very helpful to attempt to maximize your tractor's capabilities. Any of these assume constant pull, constant power, constant positioning, even constant weight. The problem is that none of the forces are constant. Wheels might grab on a rock, or the ground is more firm. The bounce of the front end might set off wheel hop. I used the term active balancing :)thumbsup:'Bikers do it!) on purpose to try to describe it. Unfortunately, there are forces that we can't necessarily see or predict that throw the balance off.
In theory, a pulling tractor should not be able to flip backward. ... There is still momentum to be considered - that's why I said virtually impossible. In addition most pulls limit front tires to rise no more than 24 inches above the ground. If they do the driver gets a red flag and their pull is over.
What??? Could that even happen if 'pulling' tractors are hitched per rules? :eek:
I ask if the tires are the point of pull and not the axle, why does our paper-only vector analysis only refer to the latter?
It's been mentioned before that tongue weight influences rotation about the axle.
Do our vector analyses ever account for that?
Regardless of where hitched in the Indian videos (obviously too high and causing front end lift) slipping tires DO keep a loser's front end up in the air. (Thanks, CalG!)
Once again,
...vector analysis is very helpful to attempt to maximize your tractor's capabilities. ... Any of these assume constant pull, constant power, constant positioning, even constant weight ... The problem is that none of the forces are constant... Unfortunately, there are forces that we can't necessarily see or predict that throw the balance off.
(Thanks, Ray!)
/ Pull from the front or the rear? #146
It is a simple vector analysis. Sum of the moments must be zero or the tractor will flip over. Pivot point is where the rear tires meet the ground. Opposing moments are tractor CG in front of that pivot point. Opposing that is pull at height above ground. Using English units assume CG is 2 feet in front of wheel contact point and tractor weighs 5000 pounds for 10,000 ft-lb moment. Assume drawbar is 2 feet above ground level. At 5000 pounds pull which is 1 to 1 coefficient of traction, possible with tractor tires, the front wheels lift off the ground. If the hitch point is 2 feet behind the tire contact point assume it drops to 1 foot as the tires lift. The CG will only move back by the cosine of the lift angle. Or now 9,000 foot pounds trying to hold it down vs 5,000 ft pounds trying to flip it over. When the drawbar hits the ground the flipping moment reaches zero. Centerline of the axle is not involved. When a free body diagram is drawn the outside forces acting on the body are the ones that are involved I.e the ground contact point and drawbar height, distance behind the ground contact point to the hitch point.
/ Pull from the front or the rear? #149
It does not matter whether the point of attachment is above or below the axle. It matters how high it is above the ground. Lower is better. The drawbar pulls backwards and the bottom of the wheel pulls forward. This produces a torque on the tractor that could flip it over backward. Next you have to know where the center of gravity is of the tractor and the tractor's total weight. Then do the math or do the experiment. With a little luck the wheels will slip before the tractor flips backwards.
This is wrong!
/ Pull from the front or the rear? #150
Does that analysis include the torque that the pinion gear is exerting against the ring gear?
/ Pull from the front or the rear? #151
Wow. I can guarantee none of those dudes did any vector analysis. Half of them are pulling from well above the axle. At least one of them is dead for sure.
When BOTH are pulling high, Is there increased danger to either? **** vectors!
/ Pull from the front or the rear? #152
Those Forces are COMPLETELY taken out internally. You know, Cast iron, with bearings and the like. The TIRE contact is the ONLY resolvable force. Don't get confused, The pinion cannot climb the ring! It can only apply a force. If not reacted upon by the TIRE contact, There is nothing....
/ Pull from the front or the rear? #153
So the tires will lose traction before the tractor is standing vertical even when the drawbar isn't long enough to reach the ground at any point? Seems to me the resistance to going over will lessen, not increase, as the tractor approaches vertical.
/ Pull from the front or the rear? #154
Tires losing traction is not in my play book. I'm not sure where that theme comes from.
What is wanted, is a lever arm that opposes the turning "torque".
Imagine a lever arm EXACTLY the same length as the tire Outside radius.
The tire turns one way, the lever arm opposes.
Could the tractor over turn by tractive forces alone?
No inertia etc.?
No! It could not.
/ Pull from the front or the rear? #156
When a tractor turns over backwards when pulling from a fixed draw bar below the rear axle, the axle of the tractor actually moves backwards (towards the immovable object) as the tractor rotates around the tires. The rear tires aslo roll backwards towards the immovable object. When this happens, it happens very fast because the tractor is rotating around the rear tires while the rear tires are rolling backwards so that draw bar (where attached to the pulling line) stays the same distance from the moving object as it moves down and forward with respect to the rear tires.
This can and does happen. I've seen it happen with a John Deere Model A. Big Ag tires, and a light front end (typical old field tractor design) makes it very possible to roll over backwards when pulling from the draw bar below the axle.
Small diameter R4 and turf tires and much more forward weight distribution make this scenario all but impossible with a modern CUT or SCUT.
Now if you pull from the top of the ROPS, you're likely to lift the front but it will lift very slowly so it's easy to react to. If you pull from the fix draw bar below the axle you are unlikely to lift the front and even less likely to roll over backwards, but if it does start to happen, it will happen very, very fast. To counter this, when pulling from the fixed draw bar, pull very slowly.
/ Pull from the front or the rear? #158
As CalG says there is no actual 'climbing a ring gear'. (post #152) The term is folklore and figurative, as if whether the wheels wouldn't spin when a tractor would/did flip over backward by 'climbing'. Still, I wonder about tire slippage 'or not' ...
So looking at these pictures .. is it just me, or ...
Is there a clear view behind any of their the rear tires, or perhaps a visible hint that there could be at least some slippage? (even mere single digit %s)
Are the hookups to sled/load more or less considered to be a) connected below the axle centerline b) of common or 'class' length and .. 20"/20" height/distance?
btw, Can we, or not, see our vector analyses demonstrated here? Are all/any we mentioned clearly illustrated? :scratchchin:
Disclaimer: The following pictures are in the public domain, and shared here without permission.
/ Pull from the front or the rear? #159
It is important to note that the "rapidity" of the over turn is proportional to the load.
A rather light pull at the ROPs will turn the tractor over rather slowly, while a very STRONG resistive force near the axle location will turn a tractor over backwards quite rapidly. (or restore equilibrium at some :front wheels off the ground attitude)
Back to vectors.. they have both direction, and magnitude!
/ Pull from the front or the rear? #160
Basic physics - even known when I got my engineering degree and available through every states dept of agriculture. Modify your tractor so the coefficient of traction approaches infinity and it’s going to flip backward. The diagram I posted is from a basic tractor engineering book. Pivot point is bottom of rear tires. Multiply force times lever arm to get the opposing moments. Pull times pull height is opposed by mass at CG times lever arm. If the traction is poor the pull cannot reach the point where the front end will lift. If the traction is high the front end will lift, just like shown in all these tractor pull pictures. Same thing in the picture I’m sure everyone has seen of the driver who chained logs to his wheel. Every time a log hit the ground the tractor front raised.
Friesen 240 Seed Tender (A63116)
Friesen 240 Seed...
2006 Chevrolet Silverado 1500 Pickup (A63116)
2006 Chevrolet...
UNUSED ATS EJ 11000 ELEC.JACK (A62131)
UNUSED ATS EJ...
PAIR OF 2'X6' DIAMOND PLATE RAMPS (A62131)
PAIR OF 2'X6'...
2013 John Deere 1790 Planter (A63109)
2013 John Deere...
2025 Ram 4500 Mechanic/Service Truck, VIN # 3C7WRKAL6SG570509 (A61165)
2025 Ram 4500...
