Digging Trench with Pressure Washer
/ Digging Trench with Pressure Washer #1
nimblemotors
Sacramento, California
Case 530 CK Sold, Ford Ranger DIY Project
So I needed to run power cable from the utility box to the barn, and this time I made a shortish video on
doing it using a pressure washer.
I had not seen anyone make one, though lots of people asked on forums about doing it.
I think I've had a whole 10 views on this video, so maybe worth letting more people know. or not. :)
Digging a Trench with a Pressure Washer - YouTube
/ Digging Trench with Pressure Washer #2
Not to rain on your parade but no way would I bury a power wire that shallow. My well has a ground rated wire buried but it was done by the electrician and I wasn't there so I don't know how deep it is. If I were doing it I would go at least 3 feet down and put it in conduit.
/ Digging Trench with Pressure Washer #3
I have shot a hole with a pressure washer under a sidewalk to run a conduit but I've never used it to dig a trench to bury wire.
/ Digging Trench with Pressure Washer #4
A-men on that.
Anyone taking bets that wire will need to be replaced in less than 2 years?
B. John
/ Digging Trench with Pressure Washer #5
I had gophers chew through the insulation of 6 gauge aluminum wire running to pump house. Had the original installation been put in conduit, (by others), I'd be 1k richer.
/ Digging Trench with Pressure Washer #6
You might want to check codes in your state. Here power cables must be underground rated, at least 18" deep and in conduit.
/ Digging Trench with Pressure Washer #7
I've hand dug channels for UF wire to out buildings. Just a few inches. Just a few problems once where it crossed the barnyard. I reburied the portion that popped up. I once also ran UF wire across a lawn to get electricity where I wanted it. I found the wire lay flat and was covered over by the turf. I know it's there - electricity still runs, but I can't see it anymore. I run the mower over it all of the time. It holds up to rain, snow, frozen ground, tractor traffic.
Now I don't recommend this to anyone! But it has worked for me! Good thing the safety police are not doing their job via hi-resolution satellite imagery!
/ Digging Trench with Pressure Washer #8
Reminds me of the trench I dug and encountered bedrock close to the surface. Tried a 7.62 FMJ NATO round or two! That didn't work at all, but it would be more fun than the ungodly mess of using a pressure washer.
I saw a huge vaccumme truck yesterday doing excavation. My thought is always how long it takes those guys.
/ Digging Trench with Pressure Washer #9
He did dig to 18". Not sure what type of wire used or if conduit was also used. I do like the idea of how you can cross other pipes or wires with no damage.
/ Digging Trench with Pressure Washer #10
18" deep hare also, **** I used and hose with a screw type nozzle duct taped to a broom handle to run pex under our sidewalk for a lawn sprinkler 25 years ago when we lived in suburbia.
/ Digging Trench with Pressure Washer #11
It did make a nice narrow trench but wouldn't work here. My trench would be substantially wider. I can't dig anywhere without hitting rocks. I had to dig up rocks to put in a T post for the end of a cordwood stack. I tried about an 12" diameter around my chosen location. Nope, rocks.
/ Digging Trench with Pressure Washer #12
Years ago my farmer neighbor showed me what I thought was an easy way to dig a trench. We took a scrap metal bar, about 1/2"X3" about 4ft long, drilled two holes in it to bolt to back of my tractor. Then a post hole dug about 2ft. down, put bar into it and bolted to tractor. Then I just drove it along.
/ Digging Trench with Pressure Washer #13
If you aren't careful you can damage the insulation on cables especially if you are using a high pressure high volume pressure washer. Once you are close to the buried cable it's prudent to reduce the line pressure quite a bit (as long as it still chews away the dirt) and after the cable is visible keep the water stream off the cable as much as possible. Just a little bit of advice from an old experienced power Lineman; we used to make extensive use of hydrovacing to expose all sorts of buried services.
/ Digging Trench with Pressure Washer #14
There is a professional company called "Hydro-Trench" that we used in Canada a lot for trenching where we knew that there was underground pipelines. They use high pressure water jets to dig and a vacuum truck to remove the water and mud. There is no danger of breaking a pipe or electrical line using this equipment.
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A65583)
New/Unused...
2021 John Deere 4044M (A64126)
2021 John Deere...
Landhonor Quick Attach Hydraulic Pallet Forks (A66408)
Landhonor Quick...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
Dueling Tree (A65640)
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
